C43 headlight control thingymajigs???
Old Jan 12, 2017 | 06:47 PM
peppyhead's Avatar
2003 Corvette Z06, 1999 E55 AMG
Subject title is weird I know, but like most know j picked this c43 up for 2800 Canadian and it seems pretty solid but requires some tlc.
it has the xenon headlight pkg but in front of each light u see the hood (or sorry behind each light) there are these silver boxes, which looks like they're connected to the back of the headlight. Only problem is that they are literally just sitting loose in the engine bay.
Here is two photos I took. Anyone know where these are supposed to be secured to?
it came like this trust me.
Old Jan 12, 2017 | 06:57 PM
cm60k's Avatar
Is there a part # stamped in it..??
;ZAYED;
Old Jan 12, 2017 | 07:35 PM
KJI3jflarryfe93's Avatar
These ballast modules are for xenon lights D2R,
They are attached to lower section where the inside bumper brackets are in the deep black hole.
Someone unbolted these boxes
Old Jan 12, 2017 | 08:46 PM
peppyhead's Avatar
Well I will try and locate where hey go and secure them accordingly.
I find it weird the things people do, and they do things half *** etc.
Any further advice help from anyone would be appreciated.
Thanks Kowalaski
Old Jan 12, 2017 | 11:34 PM
mickey13's Avatar
1999 AMG C43
i need to check one of mine out and maybe replace it. any idea what is the easiest way to get to it? from under the car maybe?
Old Jan 13, 2017 | 01:40 AM
PJmak's Avatar
I dont think those are oem. They look different but I could be wrong.
They connect on the bottom of the frame in the front of the car.
Old Jan 13, 2017 | 03:22 AM
mickey13's Avatar
1999 AMG C43
is there a plug and play upgrade to the oem ballasts?
Old Jan 13, 2017 | 06:11 AM
sta si ti pusio sinoc?
of course they are OEM, my ballast looks exactly like them
Old Jan 13, 2017 | 11:29 AM
PJmak's Avatar
I swear it looked different on mine.
I might have to double check when I get home
Old Feb 2, 2017 | 09:35 PM
Chest Rockwell's Avatar
Veteran: Navy
2005 E500 4matic wagon, 2006 AMG E55, 2009 Smart Fortwo
I tried looking for pics of where the ballasts mount, but was only able to find a pic showing the driver's side (left facing forward). It mounts in the wheel well, while the passenger side ballast actually bolts to the back of the bumper support bar. As you can imagine, accessing that requires removing the bumper. Not terribly hard, but tricky if you do it yourself.
Old Feb 4, 2017 | 07:41 PM
peppyhead's Avatar
That is a big help, much appreciated!
i ended up finding the actual brackets from Mercedes in the trunk, so I'll attempt to do this next weekend.
Old Feb 6, 2017 | 06:57 AM
DRBC43AMG's Avatar
Removing the front bumber is a one man 5 minute job (4 nuts not forgetting the temp sensor pushed into the bumber support). Use a blanket on the ground to lay the bumber and protect from ground rash.
Reassembly takes a bit more time as you need to find and align the side brackets to slide on. Also a one man job but better with a little bit of help of a friend....
Old Feb 10, 2017 | 12:16 AM
peppyhead's Avatar
No these aren't oem, beg are from china, and we're on the car when I bought it and just laying in the fender well. They seem to work fine so that doesn't concern me
Old Feb 10, 2017 | 01:04 AM
fredtga's Avatar
w202
peppyhead, they're not Mercedes OEM, but they're not cheap chinese for sure. They look like BMW/Mini Bosch units (possible Bosch part number 1307329023)
Old Feb 10, 2017 | 06:39 AM
have you run your VIN to check if your car had zenons from factory.
wonder why PO messed with these ballasts
the sticker on ballast is yellow, bosch use the same decal, i see a STAR and letter L, this is a genuine part.
is the other side ballast stamped with a STAR and letter R
Old Feb 10, 2017 | 12:15 PM
peppyhead's Avatar
I've run the VIN to check the carproof and carfax. the previous owner said the headlights went on him so he ordered these, and trust me they are not bosch. The previous owner was a complete liar at every turn but like I said I got the car for cheap because I knew he needed the money. He was just a hack job that put these ballasts in and just left them there.
also he changed the coolant resevoir tank lower hose and put some ****ty hose he bought at walmart and it's rubbing against the manifold and alternator.
Old Feb 10, 2017 | 12:24 PM
mickey13's Avatar
1999 AMG C43
check here, it gives factory options
http://www.vindecoderz.com/EN/Mercedes-Benz
Old Feb 10, 2017 | 12:25 PM
PO seem to have been a real ****** not worthy of an AMG car!
btw, buy a new alarm siren, the new one is so much better
Old Feb 10, 2017 | 03:19 PM
peppyhead's Avatar
That VIN decoder is awesome holy cow. Yeah the car has the factory Xenon Headlamps.
Anyone know where I can find coolant hoses or a schematic of them? It's the fatter lower one that connects underneath the coolant resevoir and runs to the bottom of the radiator?
I've checked and can't seem to find a diagram.
Old Feb 10, 2017 | 06:12 PM
mickey13's Avatar
1999 AMG C43
I think you want item 41. Part No. 2025015382
