Help Regarding Transmission
Old Aug 24, 2017 | 06:54 PM
nkctb7's Avatar
2006 E55 AMG/1996 C36 AMG/1999 C43/55 AMG/2021 Toyota Tundra Crew Max TRD Sport Premium
Has anyone removed the guide bushing that has a tension spring on the inside of the transmission. It is located in the same area as the parking lock interlock linkage aka the plil? Please refer to the attached pic! Any help is greatly appreciated! Thx
Old Aug 24, 2017 | 09:05 PM
nkctb7's Avatar
Originally Posted by Plutoe
What looney has suggested fooling with your so called spring. Don't FA, what is the real problem!
There's really no choice as my 722.6 transmission was an earlier 99 model that has the o-ring on the guide bushing. It was seeping fluid so I have to change it out. All the seals and other o-rings were brittle as hell and crumbled when replacing them. Any suggestions? Thx
Old Aug 25, 2017 | 03:47 AM
DRBC43AMG's Avatar
Is it a pressed in part, or do you need a special tool to remove and put back in? Guess you need to look in the WIS for more details, or someone on here who has access to the MB workshop information system (WIS).
Old Aug 25, 2017 | 11:54 AM
mickey13's Avatar
1999 AMG C43
i thought i saw a thread on this before. couldnt find it but could swear someone did a write up on something very related if not this issue
Old Aug 25, 2017 | 07:40 PM
nkctb7's Avatar
Thx guys! I was able to figure it out and removed it. The parking pawl pivot pin and circlip need to be removed thus allowing the parking rod sleeve to come out.
Old Aug 25, 2017 | 11:50 PM
DRBC43AMG's Avatar
Great to hear you figured it out Tell us how the O rings looked like?
Old Aug 26, 2017 | 03:20 PM
nkctb7's Avatar
Thx DRBC43AMG,
The large diameter o-ring hat seals the pump housing is in overall excellent condition. No visible cracks or flat spots and feels almost identical to the new one. The o-ring that seals the parking rod sleeve had no visible cracks but much harder than normal. Not overly brittle but, it was apparent as to why it wasn't sealing correctly. The second smallest o-ring seals the breather valve that is located at the top of the bell housing. It was in the worst condition of all as it was completely brittle. The smallest o-ring seals the parking pawl pivot pin. It was in decent condition overall but did crack when I removed it with a seal pick. There is another tiny o-ring that is on the lock pawl pivot pin which is not shown in the diagram. It is recommended to replace it if the pin has been removed. Surprisingly, that one had to come from Germany. The link below will show the parts diagram. Scroll down to page 47.
http://www.all-trans.by/assets/site/...es/722.6.1.pdf
Old Aug 26, 2017 | 03:23 PM
nkctb7's Avatar
I should also add that the front main seal was in terrible condition. Although there was no seepage, it was only a matter of time. The rear main seal was badly seeping and I'll post pics once I've removed it.
Old Aug 26, 2017 | 06:06 PM
DRBC43AMG's Avatar
Good job and good share. Thanks
Old Aug 26, 2017 | 10:15 PM
nkctb7's Avatar
I'm glad that I could share the info. just in case someone else comes across the same issue. There are literally dozens of o-rings of different sizes and part#'s. I decided to replace all of the transmission o-rings and seals as I don't ever want to have to pull my transmission out again. My intention was to only replace the pilot bushing and the PLIL when I noticed the rear main seal was seeping as well as the parking rod sleeve located next to the PLIL. All in all it is a great learning experience disassembling and assembling the transmission. Hopefully this takes care of all potential issues. Thx
Old Aug 27, 2017 | 05:57 AM
DRBC43AMG's Avatar
The link with the pdf file and over 120 pages of technical details is pure 722.6 ****
You can bet I've copied the link to my files
Old Aug 27, 2017 | 09:27 AM
KJI3jflarryfe93's Avatar
@ nkctb7
that's some great info you shared in this transmission PDF link
thanx
Old Aug 27, 2017 | 09:28 AM
Old Aug 27, 2017 | 06:58 PM
nkctb7's Avatar
You're all very welcome! Endless Google searching and days later I stumbled across that link. It truly is mb ****!
