C43 m113k swap
Old Jun 22, 2018 | 11:49 PM
g60wall's Avatar
2014 E63s
I have a AEM FIC 8, sitting in a box next to the car.
Old Jun 22, 2018 | 11:53 PM
g60wall's Avatar
2014 E63s
Anyone have any insight on Klee-man setups? or HPS, how did those guys do it?
Old Jun 23, 2018 | 03:09 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
see if you can get a hold of a member on here called silence. He had an upgraded HPS kit using a split second MAF scaler and a rising rate FPR on his C43 and eventually swapped it over to a 5L
Old Jun 23, 2018 | 11:56 PM
nkctb7's Avatar
2006 E55 AMG/1996 C36 AMG/1999 C43/55 AMG/2021 Toyota Tundra Crew Max TRD Sport Premium
There's a reason why only one person has achieved the factory 5.4K swap. It took him several years and thousands of man hours in their shop to figure it out. Another reason he's not sharing any info. with anyone. I would do it in a heartbeat if he was local and willing to do it for a decent price. I can only imagine the trial and error of that painstaking process to finally get it right. An enormous amount of time and money have gone into that car. Totally worth it imho!
Old Sep 10, 2018 | 09:06 AM
g60wall's Avatar
2014 E63s
It’s been tough! Before I go ahead and try getting me2.8.1 to work I went ahead and installed a AEM F/IC 8 over the weekend. My buddy ran it into the cabin and I wired it into the ecu.
Now it’s time to start tuning the beast.
Old Sep 10, 2018 | 09:09 AM
g60wall's Avatar
2014 E63s
The
Old Sep 10, 2018 | 10:27 AM
  #32
DRBC43AMG's Avatar
That's certainly not for the faint hearted
Old Sep 10, 2018 | 02:46 PM
  #33
loggato's Avatar
1999 SLK 5.5L 6-speed, 1993 300 SE
You could do a stand-alone ME2.8 setup. I'm working on that now for my V8 swapped SLK. I'm putting a 5.5L from a parts CLK55 that I have and currently have the engine running off the harness outside of the car. I'm hoping to make a harness "kit" that goes from the EIS to the ECU, then you just plug that into your engine harness.
I still have yet to remove everything that isn't needed from the harness so it's still messy.
Old Sep 10, 2018 | 04:35 PM
  #34
Are you referring to Money-one?
Old Sep 11, 2018 | 01:44 PM
  #35
brad_c43's Avatar
'99 C43, '88 560SL
Make a kit and if the price is right ill be your first buyer. I want to see @G60wall succeed and i wish you all the best! If there is anyway I can help please let me know as i want to do this swap myself badly!!!
Old Sep 11, 2018 | 09:06 PM
  #36
G60wall have you reached out to Demetre Taktakishvili on the facebook AMG group? Dude is swapping M113K's into 190E's!!
Old Sep 12, 2018 | 04:24 PM
  #37
g60wall's Avatar
2014 E63s
She’s alive!
ill have all the maps built soon too really open her up.
first WOT pull ever!!
afr 10.3
Old Sep 12, 2018 | 08:47 PM
  #38
g60wall's Avatar
2014 E63s
PULL number 2
Old Sep 12, 2018 | 09:07 PM
  #39
brad_c43's Avatar
'99 C43, '88 560SL
WOW Awesome stuff! How close are you to a finished tune? how does the car feel out on the road????
Old Sep 12, 2018 | 09:10 PM
  #40
g60wall's Avatar
2014 E63s
I need logs from a regular car, so i can spoof the signal better. I am only able to get 8 degree of timing right now. Car is running mint just slow.
Old Sep 12, 2018 | 09:23 PM
  #41
brad_c43's Avatar
'99 C43, '88 560SL
If youre still offering the bluetooth obd ill send you logs from my car
Old Oct 7, 2018 | 12:49 PM
  #42
brad_c43's Avatar
'99 C43, '88 560SL
any updates on how the car is running?
Old Nov 9, 2018 | 10:13 AM
  #43
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
I can get logs in my 55 swapped C43...
I'm totally doing this to my car one day when people like you have the bugs worked out. My chassis has over 300k miles, so this car will always be worthless. But it's completely RUST FREE so it's a great platform for a crazy 55k build.
Old Nov 9, 2018 | 02:10 PM
  #44
loggato's Avatar
I can get you some numbers from my Megasquirt tune on my 55 engine (in my SLK). right now I'm in the high 20's for ignition advance, but what I read from stock engine owners is that they are happy in the low 20's.
Old Dec 14, 2018 | 10:48 AM
  #45
Aydin Aliyev's Avatar
w210 e55
Hi guys I need your help I did almost same ting
i got w210 e55 and swap engine. Now about 8 months stoke with ecu update can you help me out? Thanks!
Old Dec 24, 2018 | 01:07 AM
  #46
w210 e55
11:48 AM
Old Mar 3, 2019 | 01:23 AM
  #47
NA202's Avatar
c230
Any more progress and info that your willing to share?
Hey @g60wall has there been any updates with your timing map? Or any more info that your willing to share? I've been seriously following this build the one thing I'm curious about is how you got the stock cluster to work, assuming it all works besides tach and speedo? Or is that a disadvantage of not staying 2.0 and going after market ECU? Also a question for @loggato running 2.8.1 on the engine/harness outside of the ECU. Any progress with that EIS harness? I will also be your first customer lol plus I'm always willing to brainstorm for free lol. Do you expect your 2.8 build to be able to work with stock cluster? Also when running 2.8 are you making a hybrid ECU box for the tcu plug? I guess that depends what trans you use? Are you planning to use the c43 trans or the 55k trans? Wich trans are you running @g60wall ?
Old Mar 3, 2019 | 12:07 PM
  #48
Sulaco's Avatar
following the build in facebook, he gave up the 113k and has gone to a naturally aspirated 5.4 113
Old Mar 3, 2019 | 12:24 PM
  #49
DRBC43AMG's Avatar
Sorry to hear that another 113k project has hit the dust
Old Mar 3, 2019 | 01:42 PM
  #50
cm60k's Avatar
Really not worth the big headache with much $$$$ for 55K..!?!,,
prefer to go with N/A 5.4L,,
"headers/cams/ported Head with Titanium valves & springs/Ported TB/bigger injectors/Phenolic spacers for head & TB/900Nm gearbox with valve body/LSD diff./custom ECU-remap",
if you do all these perfectly, i don't think you will seeking for 55K swap anymore..
-;ZAYED;-
