C43 m113k swap
for those that havent seen, heres my ME2.8 running outside the car.
prefer to go with N/A 5.4L,,
"headers/cams/ported Head with Titanium valves & springs/Ported TB/bigger injectors/Phenolic spacers for head & TB/900Nm gearbox with valve body/LSD diff./custom ECU-remap",
if you do all these perfectly, i don't think you will seeking for 55K swap anymore..
-;ZAYED;-
However modifying the 5.4 n/a will also cost a sizable amount. Getting the same kind of power as the 5.4k is probably possible but at what price. There must be a solution to get the electronics talking the same language, but I think the the demand is too small to get a decent ROI. Just my 2 cents.
Also does anyone have any info on if the tach is can based or not?
Also can anyone link me to the Facebook build this guy quit? Does he share exactly what details he ran into that made him reconsider his build when it seemed fairly close to completion? I'd like to know more details on what went on here if anyone can link me to more data or is willing to talk to me privately I'd really appreciate it! Best of luck to all who tackle this. I swear if and when I make this work I will provide a full write up with all my knowledge and overcoming. Help me get there so we can all get there!
Megasquirt will have no issue as long as you leave the stock ECU in and leave the things it needs to think there's an engine there. (coolant temp, Crank PS, Cam PS, Throttle PS etc.) you can even wire the MegaSquirt to the Throttle PS wire from your stock throttle body - so you will still have the stock ECU controlling idle and cruise control!
