HEVAC playing up?
Previously when the cabin was very hot after a spell in the sun, when I switched the engine on, the settings of the HEVAC on Auto, the fan would kick in and work up to full speed quickly. The led screen on the HEVAC control unit shows the max speed reading. A short time later after 10 secs approx, the vents would shoot out blasts of cold air over the fan's full speed, like if a second fan kicked in. This way the cabin could cool quickly and a short time later the fan would gradually reduce speed so that the occupant(s) didn't freeze!
Already last year this extra cold blast didn't work regularly. You could clearly hear it cutting in and out, but now it no longer does it.
Any ideas what could be the problem? Could it be the fan's regulator as I assume the fan has one?
I may scan and see if any codes show up
less or gas leak/bad tank sensors/bad Evap. indoor sensor/malfunction of climate control unit/bad compressor magnet"..!,,
did you diagnose the car..?, any codes of A/C system would help..
-;ZAYED;-
I need to run the diagnosis of the HEVAC from the screen on the dash
https://mbworld.org/forums/c36-amg-c...on-button.html
