Comfort control module
Also, I believe mickey13 has a pretty good set of the ground points for the w202 if you need help finding those
This is the door control module ( N69/1 )
These are the diag. steps for your driver window
these are the diag steps for your driver side mirror
All have X37 it's in the passanger side footwell under the glove compartment behind the plastic panel by where your right leg would be if you were in that seat. Aside from that, it's simple just change all the motors in the door. Car is old that's all.
