Manual Swapped C43 Gauging Interest
When you set the instrument cluster to ROW it won't turn on the check engine light for anything because check engine lights and only on the north American market cars. The code will still exist but the light will not turn on
---Adam
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
I'm sure something can be coded out in the vehicle's brain. Happy hunting!
#32
So I never did figure out how to turn the check engine light off. Apparently there is a speed sensor in the auto gearbox that the computer is looking for and can't find, so it trips the Check Engine light. Mercedes was no help because there isn't a space in the computer to switch to this gearbox. They said find someone to rewrite the code in the computer. I found a company in FL who can do it but they needed the car, not just the computer. So I would have to ship them the car, with a blank check, not very appealing.
That's the bad news, the good news is in 2 years the car ages out for emissions testing in NY, so I will just drive with my dealer plates for the next two years then start registering it again once it doesn't fail the yearly NY inspection. It is a blast to drive, so no regrets, just more complicated then I initially imagined.
#33
I would suggest you get in contact with raw 1879 as he has a manual conversion and drives the Nurburgring frequently. I think this question was discussed in one of his threads
#34
I've been thinking of doing the project as well. Was hoping I could disassemble much the shifter to lessen the size and stuff the remaining needed electronic bits under the dash or console.
#35
I have the same exact issue on my 1997 C36 with a 6 speed swap- 97 first year of 722.6. There are CEL's all related to the missing automatic. The stock TCU is plugged in and set to neutral.
From what I gather, you need a STAR or HHT with developer mode to code the ecu and tell it the car has a manual. I recently tried a shop in NJ who was willing to give it a go, but his machines would not communicate with the ecu. Anyone in the Philly, NYC, New England area able to do this work. The NJ shop said the work is not difficult if you can get into the ecu.
I talked to Oliver from Speedtuning and need to open up the ecu and send him a picture of the guts. I have used him in the past for W124 3.6 swaps.
#36
So I sent my ECU out to Josh at Mercedes Swap Shop in CA hoping I can eliminate the CEL's and have it coded for a manual trans. I will post up if it gets sorted out.
https://themercedesswapshop.com/?fbc...P9cVRaqwYxBQac
#37
#39
1999 C43 AMG, 2005 E55 Wagon
As far as I know it depends on the year. Only a 2000+ can have the CEL coded out. Anything before that will require the original transmission shift selector still plugged in but left in Neutral.
#41
It appears that my issues have been resolved. I installed the ECU today and took the car out for a good run.
Josh said that I should be able to unplug the old TCU now that the coding is done. I will try that later in the week.
I forwarded him this thread. He said that he can do the M113K coding that was asked about.
#42
#43
'16 C450, '21 Dad Wagon Pilot, '22 Wrangler 4xe
Sulaco (07-21-2022)
#44
#45
"It is worth noting that you will probably have an ESP light with no traction control or ABS. I’m still trying to figure out which ESP module needs to be in there for it to work right. Cruise will only work if you wire in the Clutch Pedal Position Switch"
So curious if you did anything extra. Does your Cruise Control, ESP and ABS work?
#46
My C36 is a 1997 so there it is not equipped with ESP. The car does have ASR and believe it is disabled now. I am not positive about ABS, but the braking seems normal. Not sure on cruise control as I have never tried using it in any of my cars.
