Where to buy? Trans oil cooler lines
Old Dec 11, 2019 | 09:31 PM
S6TEN's Avatar
99 C43
Question Where to buy? Trans oil cooler lines
Hey guys,
Does anyone have any leads on where I can buy new transmission oil cooler lines besides @ the dealership?
Old Dec 11, 2019 | 09:38 PM
brad_c43's Avatar
'99 C43, '88 560SL
If you know someone who works in a shop worldpac is where I get most everything for my car, them and fcpeuro.com
Old Dec 11, 2019 | 09:45 PM
S6TEN's Avatar
99 C43
But specifically the oil cooler lines from the transmission to the heat exchanger? have you seen these on any sites? Line 10/20
Old Dec 12, 2019 | 06:03 AM
MattCordell's Avatar
C43 AMG with a tune up
There are companies making custom made hoses, maybe you can get braided at a local shop?
Old Dec 12, 2019 | 06:16 AM
cm60k's Avatar
Prefer to get "OEM" or "Cohline" only, those are pressurized hoses..!
-;-ZAYED-;-
Old Dec 12, 2019 | 08:09 AM
brad_c43's Avatar
'99 C43, '88 560SL
Do you have part numbers for these two lines?
Old Dec 12, 2019 | 08:35 AM
cm60k's Avatar
L&R #: "019 997 82 82"..
-;-ZAYED-;-
Old Dec 12, 2019 | 10:37 AM
vinceC's Avatar
2014 ML350 4Matic
OP, are you referring to the remote transmission cooler for the C43? If so, the drawing you provided is incorrect. For the C43 the hoses come as a set of two. The part number for the lineset is: 202 997 35 82. See ref.# 91.
is: 202 997 35 82.
Old Dec 12, 2019 | 01:23 PM
S6TEN's Avatar
99 C43
Hey whats up zay, long time no talk,
Unfortunately, this is not the line I am referring to
Old Dec 12, 2019 | 01:25 PM
S6TEN's Avatar
99 C43
Thanks Vince, what I'm looking for is what is labeled 70 and 80, I don't remember them being two pieces per pipe/line though, I believe its 2 pipes/lines, one on each side of the tranny, which has securement brackets that get installed with some of the oil pan bolts.
Thnx
Old Dec 12, 2019 | 01:28 PM
S6TEN's Avatar
99 C43
I believe this PN 202 997 35 82 is correct, but I cannot find it on the market with a 100 percent certainty that I am buying the correct lines.
Correction, the correct part number for one side is below
202-270-27-96
Old Dec 12, 2019 | 02:02 PM
vinceC's Avatar
2014 ML350 4Matic
OP. You appear to be referring to the hard lines. The one on the driver's side (left) comes from the bell housing alongside the engine and turns right across the from of the engine ending approximately under the harmonic balancer. The passenger's side (right) runs from the bell housing alongside the engine ending with a approx. 30 degree bend under the alternator. These hard lines connect to the lineset described earlier. Parts numbers for 70 and 80 are visible in the screenshot from the M-B parts information system. The drawing doesn't match the shape of the lines, but it is specifically for a 1999 C43. These discrepancies do occur with limited production cars.
Old Dec 12, 2019 | 06:12 PM
brad_c43's Avatar
'99 C43, '88 560SL
Looks like ecs tuning has them in stock op, or you could always have some custom lines made at a hydraulic shop
Old Dec 12, 2019 | 11:26 PM
cm60k's Avatar
Those are metal pipe lines, usually not affected..!,
what happened to yours..?!?!,,
L: "208 270 02 96"
R: "202 270 27 96"
-;-ZAYED-;-
Old Dec 13, 2019 | 08:55 AM
S6TEN's Avatar
99 C43
Thank you for your valuable knowledge and help Vince! It is greatly appreciated, this is what the Benz community is all about
S6TEN's Avatar
99 C43
Thanks Brad
Old Dec 13, 2019 | 09:01 AM
S6TEN's Avatar
99 C43
L: "208 270 02 96"
R: "202 270 27 96"
-;-ZAYED-;-
Thank you Zayed,
I live an area where there is a lot of snow/salt when I did my swap I noticed there was surface rust on the threads and the pipe its self, I tried my best to wire brush and clean it out, Once I put it back together and drove it around, it started leaking, I would just like a fresh set, especially because I'm planning on rebuilding/replacing my tranny.
Old Dec 13, 2019 | 09:09 AM
S6TEN's Avatar
99 C43
Hey Zayed, why is the left side a 208 part number?
Old Dec 13, 2019 | 09:15 AM
cm60k's Avatar
I see,
don't forget to get (4) pics. of OEM copper O-Rings, as well,
*O-Rings part #: "N007603 014102",,
Good Luck..
-;-ZAYED-;-
Old Dec 13, 2019 | 09:20 AM
cm60k's Avatar
The old part # was "202 270 26 96",,
MB replace it to "208 270 02 96", on Apr/2009..
-;-ZAYED-;-
Old Dec 13, 2019 | 09:28 AM
vinceC's Avatar
2014 ML350 4Matic
One other thing to note. If anyone ever has the replace the lineset chances are very high that you will not be able to remove the connections at the cooler. The lineset fittings are steel; the cooler is aluminum. Galvanic corrosion virtually welds the parts together. I had to deal with this recently. I ended up replacing the cooler along with the lineset. I have run into this several times over the years on M-B diesels that have an aluminum engine oil cooler and steel hot fittings.
