Heating control unit bulb replacement
Old Jan 25, 2020 | 11:58 AM
cwp's Avatar
cwp
yr 1997 280C
My 1997 280C heating control unit has lost its light. How to replace the bulb(s) in this consule? Many thanks.
Old Jan 26, 2020 | 07:35 AM
DRBC43AMG's Avatar
Don't recall exactly (getting old....) but I believe you need some needle feelers (like for the radio removal?) to insert and unclip the unit. Pull it out and the bulb is behind
Old Jan 26, 2020 | 09:18 AM
cwp's Avatar
cwp
yr 1997 280C
Many thanks. I removed the unit-and there is no bulb opening or any cover to remove to get to the bulb! It must be enclosed within the unit-is that possible?
Old Jan 26, 2020 | 10:07 AM
cm60k's Avatar
you will find the bulb under the climate control, (White plastic round pin),,
you can simply remove it by your hand, or with nose pliers, just twist it anticlockwise..
-;-ZAYED-;-
Old Jan 26, 2020 | 10:27 AM
cwp's Avatar
cwp
yr 1997 280C
Many thanks. I wish mine had that option-but there is no such removal screw on the bottom of my unit. It looks like an original mercedes unit-but no white screw cover anywhere!
Old Jan 26, 2020 | 10:31 AM
cm60k's Avatar
Better to forward pics. of your A/C control unit,,
it will helps to see what kind of A/C control unit you have..
-;-ZAYED-;-
Old Jan 26, 2020 | 03:39 PM
cwp's Avatar
cwp
yr 1997 280C
bMany thanks. Sorry-cannot take photo. But the unit is an original mercedes part. Strange that there is no opening anywhere to access any bulb
Old Jan 26, 2020 | 05:37 PM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
cm60k, that is the 98 and newer climate control unit (I have the same one). The 1997 model has the older unit. I don't know how to change that one.
Old Jan 26, 2020 | 06:22 PM
cwp's Avatar
cwp
yr 1997 280C
apparantly the bulb in the older units cannot be replaced. Bummers! Thanks for your reply.
Old Jan 27, 2020 | 08:19 AM
DRBC43AMG's Avatar
That's a bit of a rip-off by MB
Old Jan 28, 2020 | 12:46 AM
cm60k's Avatar
Yeah,
94 till End of 96 comes with an old unit #: "202 830 07 85"
code: "851/F",,
if i'm not mistaken, have to remove (6) Phillip screws, then can pull out the bulb, but really not that sure about that..!!
-;-ZAYED-;-
Old Jan 29, 2020 | 06:11 PM
DRBC43AMG's Avatar
Yeah worth a try IMO
