I Have A Modded OEM Air Box..
Old Apr 6, 2022 | 01:06 PM
speed43's Avatar
1999 C43 Amg
I Have one for sale for those who may be interested. I normally make them By request but I was able to get one done ahead of time.
If you want more info on me and my modded air box please PM or email me at speed43mods@gmail.com
Or you can google to find reviews. Just type in speed43 air box.
Thanks for looking.
George.
Old Apr 7, 2022 | 03:17 AM
DRBC43AMG's Avatar
I can vouch for George's craftsmanship, and the enlarged box really works very well. It lets the engine really breath fully.
Old Apr 7, 2022 | 11:42 AM
silverc4s's Avatar
99 C43, 73 911 targa
I love mine as well. Nearly 4 years down the road I enjoy the extra oomph every day,,
Old Apr 8, 2022 | 12:38 PM
speed43's Avatar
1999 C43 Amg
Thanks guys for the nice comments. I posted because people that are interested say to me through email they saw a thread in a forum and wanted to know if I’m still doing the boxes.
It’s like they find real old threads so wanted to update that yes still doing them.
Old Apr 12, 2022 | 12:07 PM
Sentinel83's Avatar
W202s, W209s, W204
I concur. George's modified airboxes are fantastic. Here are some comparison pictures for anyone that is on the fence of buying them.
You will get similar performance to the RennTech airbox while maintaining the clean OEM look, at a much more reasonable price:
Old Apr 12, 2022 | 02:17 PM
MattCordell's Avatar
C43 AMG with a tune up
Report back how your experiance was after the first 100 mile drive or so?
Old Apr 12, 2022 | 02:29 PM
Sentinel83's Avatar
W202s, W209s, W204
@MattCordell I've had it installed for ~7,000 miles. No check engine light codes and no issues.
The engine is slightly louder on low RPM and much louder above 3,000 RPM when I floor it. It doesn't make the car sound worse at idle or while driving.
If you like the sound of the M113 engine then it just amplifies that elegant sound and gives a little more horsepower.
It doesn't sound annoying, but it is more aggressive at higher RPM than stock while maintaining the classy Mercedes V8 sound. The engine comes alive in a good way.
If you live in California then you can still pass smog with this because no one can tell that the intake is modified to be 1" larger.
Update: George can produce a 2" and 3" modified airboxes. I purchased the 2" version to avoid fitment issues with the engine wiring harness.
Old Apr 12, 2022 | 02:40 PM
That was a good review.
After fitting airbox, the sound is now more of a muscular V8 rumble heard from the exhaust?
Geezer driving, the intake and exhaust sound I assume is quite normal?
Only when you floor it the sound of the car transforms into a wild beast but in an awesome way for a V8 car?
I do like the M113 sound, I removed my rear cats and mid silencer, sounds very lovely when I drive my car.
No need for the stereo to be turned on anymore.
Old Apr 12, 2022 | 03:02 PM
Sentinel83's Avatar
W202s, W209s, W204
It's my pleasure. I have a 5.4 M113 V8, Eisenmann exhaust, rear cats deleted, and SuperSprint resonator/silencer.
I'm willing to bet that my car's exhaust is quieter than yours because you have the mid resonator/silencer removed.
Here are the responses to your questions:
  1. Exhaust Sound Difference: Yes and no. The upgraded intake manifold's sound improvement comes from the engine. Upgrading your intake will not have a big affect on the low-end sound, but it does allow for a little more airflow through the exhaust. Upgrading your headers and muffler would do significantly more for the exhaust note than upgrading your intake manifold.
  2. Geezer Driving: If it sounds normal with your current setup then it should sound the same with the modified intake. There will be a small improvement.
  3. Sport Driving: Yes, this is where you will notice the biggest difference. It will sound awesome.
Old Apr 13, 2022 | 08:44 AM
In normal situations driving my car, it isn't very loud from the pipes but will still be noticed by bystanders.
When I play with the throttle people do hear the V8 rumble, it's a pleasent sound.
The raised airbox modification, it still holds up from the massive heat in the engine bay?
On hot summer days I can cook a T-bone on top of the intake.
Old Apr 13, 2022 | 11:18 PM
Sentinel83's Avatar
W202s, W209s, W204
When I play with the throttle people do hear the V8 rumble, it's a pleasant sound.
@MattCordell it shouldn't cause any additional heat to your engine bay. People have supercharged their C43s and that adds considerably more heat than the upgraded intake.
My last w202 was a C230 and it had over 400,000 miles on it with an intake installed (not from George). This is not a mod that will jeopardize your engine's integrity in the long run.
Old Apr 14, 2022 | 04:43 AM
DRBC43AMG's Avatar
Denis, if you are afraid of heat getting into the airbox, I covered all the underside in gold sheeting. Looks nice even unfortunately you don't see it unless you look under the box. I'm persuaded it does keep out radiant heat, but in any case as soon as you stop, the heat is going to seep into the intake. After some driving forward the temps inside will go done as the airflow gets moving.
BTW to improve more the airflow to both intake scoops, I cut out the plastic protections in the front of the grille
Gold sheeting on the underside of the enlarged air-box
Drilled holes to make the cutting easier
Protection cover cut away
Old Apr 14, 2022 | 09:19 AM
@ DRB43AMG
I can see you have bling bling gold wrap on the underside of the airbox.
Took some time to cut and put on the airbox.
You made it look good.
Problem with our cars is the cramped engine bay fitted with a big sized engine for the W202 cooking every non metal part like vacuum and intake hoses.
Dry rotted hoses won't hold vacuum sealed tight.
Now and then these rubber hoses needs to be replaced.
Old Apr 14, 2022 | 11:26 AM
speed43's Avatar
1999 C43 Amg
Thanks sentinel83 for the review and pictures. That was awesome you taking the time to do that!
Old May 3, 2022 | 05:42 PM
speed43's Avatar
1999 C43 Amg
Just wanted to write that the air boxes for the c43 are $445 to $545 shipped. 50 more if you live in California.
So hope people read this as I’ve had people asking me how much….
