Identify Grill for W210 to W202 Mod
Old Aug 10, 2022 | 04:30 PM
Seed's Avatar
C43 AMG
I bought a “96-99 Mercedes W210 E300 E320 E430 Front Hood Radiator Grille Grill Chrome OEM”
but I can’t tell how to mod this insert to fit my w202 grill frame. Is this the right part?
part number 210 888 0123, same part number as the video here but they are physically different. It has 3 screws on the top and one on the bottom too…..
https://youtu.be/pnOWyYWsa6M
Old Aug 10, 2022 | 05:00 PM
PJmak's Avatar
Can you show both grilles next to each other from the inner side
Old Aug 10, 2022 | 05:04 PM
Seed's Avatar
C43 AMG
What do you mean? Like this?
I also looked at dudes video again and he says, “just so you know, this w210 grill has been modified to fit the w202”. What does that mean? Lol
Old Aug 10, 2022 | 05:17 PM
PJmak's Avatar
Show the back side of both grilles side to side. The top grille is showing the front while the bottom is showing the back.
I feel like its an easy mod I just need to see the back sides of both grilles side by side.
Old Aug 10, 2022 | 05:21 PM
Seed's Avatar
C43 AMG
hows this?
Old Aug 10, 2022 | 05:32 PM
Seed's Avatar
C43 AMG
couple more angles. If I cut the sides how do the 4 clips go on the cutoff w210?
PJmak's Avatar
My guess is it would need to be cut like this.
Once you remove your factory insert from the frame you'll get an understanding of the fitment and you'll realize its not exactly perfect and there is wiggle room.
Old Aug 10, 2022 | 05:45 PM
Seed's Avatar
C43 AMG
alright hope is being restored somewhat. I’ll cut the sides and top like you show. I think the bottom will be ok but I guess cutting less is better to see how it fits.
Old Aug 10, 2022 | 05:49 PM
Seed's Avatar
C43 AMG
I put the w202 grill over the two inserts and feom what I can tell I might get by just cutting the sides. Just not sure on the drop in but will try that first.
Old Aug 10, 2022 | 08:37 PM
Seed's Avatar
C43 AMG
So I just went for it and took my time with a cordless dremel. Came out great. Thanks @PJmak for the support!
Old Aug 11, 2022 | 12:41 AM
PJmak's Avatar
Lo9ks amazing and i glad it worked out.
You should have taken pics. There isnt anything out there on how to modify it
Old Aug 11, 2022 | 12:53 AM
Seed's Avatar
C43 AMG
yeah that’s true lol but I kinda figured I’m one of the last ones to do it so many years later. I tried to find that pdf some guy made so long ago.
if someone finds this thread and bumps it for help I’ll def help out.
Old Aug 11, 2022 | 09:38 AM
x463's Avatar
1998 C43 w/ 55 swap Wavetrac LSD and 6-Speed manual
I bought a new plastic insert directly from MB 2 years ago for my 98 C43. Wasnt expensive either. Are these no longer available?
Old Aug 11, 2022 | 10:48 AM
PJmak's Avatar
Its all good Ill probably do this and document it. I have a brand new old stock factory grille on right now but would love an avantgarde. Where are you located by the way?
Old Aug 11, 2022 | 11:58 AM
Seed's Avatar
C43 AMG
thats a beautiful car. I live in California.
Old Aug 11, 2022 | 12:08 PM
PJmak's Avatar
Thanks .
Im in Northern Cali in Sacramento area. Are you up here somewhere?
Old Aug 11, 2022 | 02:18 PM
Seed's Avatar
C43 AMG
do you have a part number and or invoice to share?
Old Aug 11, 2022 | 03:07 PM
x463's Avatar
A2028880323. I paid $36 in Sept of 2019.
Old Aug 11, 2022 | 03:09 PM
Seed's Avatar
C43 AMG
thats the original insert
Old Sep 5, 2022 | 01:02 AM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
The E-class insert is available for $60 from Mercedes: https://classicparts.mbusa.com/oem-p...Y4LWdhcw%3D%3D
