Still With This Issue
Old Jan 6, 2023 | 12:30 PM
speed43's Avatar
1999 C43 Amg
Since I purchased my 98 C43 I been having this issue.
In the dash there’s a yellow light that turns on when a light bulb burns out. Won’t show unless I turn the head lights on.
Every single light in the car outside and inside work perfectly. Even the license plate light. ALL the lights on the car work.
What could be causing this light on dash to turn on? Causes no issues but very annoying. Thanks.
Old Jan 6, 2023 | 01:06 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
could be a crusty connection somewhere, like in those tail light boards or maybe the headlight connector plugs
Old Jan 6, 2023 | 03:33 PM
speed43's Avatar
1999 C43 Amg
Good idea, I’m going to have to unplug every light bulb and check those connections.
That might do it because I don’t know what else it could be. Thanks Sulacos.
Old Jan 7, 2023 | 05:45 AM
DRBC43AMG's Avatar
Agree could be a crusty connection as you say, and could also be a warped bulb support as those warp over time with the heat coming out of the bulb. That's one reason I installed LED bulbs everywhere. Never had any more issues, nor blown bulbs
Old Jan 7, 2023 | 07:23 AM
speed43's Avatar
1999 C43 Amg
Where did you buy these LED”s?
Old Jan 7, 2023 | 07:49 AM
BVC500's Avatar
2016 GLC300 & 1991 500SL
Could also be a short somewhere. For example, the casing around the wires inside my headlamps deteriorated with age causing a short and triggering the cluster warning, despite the headlamp still working.
Old Jan 7, 2023 | 08:19 AM
speed43's Avatar
1999 C43 Amg
Originally Posted by BVC500
Could also be a short somewhere. For examples, the casing around the wires inside my headlamps deteriorated with age and caused a short and triggering the cluster warning, despite the headlamp still working.
I hope that’s not the problem. But I will check that out too. After doing what you guys are suggesting I want to get those LED’s. My white C43 has them but I bought the car like that.
Old Jan 7, 2023 | 08:21 AM
BVC500's Avatar
It's a pain trying to reach the wires inside the headlamp buckets. I sold the car shortly thereafter after my mechanic (dad) said he was tired of working on old cars!
Old Jan 7, 2023 | 08:36 AM
speed43's Avatar
1999 C43 Amg
I know how he feels. But I really like these cars so it’s different for me. I enjoy the work, as long as I fix the problems I’m good. But issues like this can start to get to you. Specially since it’s been like this for at least 6 years. But I will find the problem for sure
Old Jan 9, 2023 | 06:03 AM
DRBC43AMG's Avatar
Got them from a company in France, but you should have a source closer to you I imagine. Make sure to get the good quality ones which don't throw codes after fitting them
Old Jan 9, 2023 | 10:41 PM
speed43's Avatar
1999 C43 Amg
Ok thanks Daniel.
Old Jan 28, 2023 | 03:08 PM
Just_w202's Avatar
Clk430/c230
Bulb
Check the wattage of the bulbs or loose connections. Wrong watt bulb can damage circuit
Old Jan 28, 2023 | 03:26 PM
speed43's Avatar
1999 C43 Amg
Sounds good thanks. I’m waiting for the summer to continue checking this issue. But I have great info this time to go by. Thanks.
Old Feb 4, 2023 | 04:30 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I got my LEDs from http://www.aznoptics.com/
Old Feb 4, 2023 | 05:16 PM
speed43's Avatar
1999 C43 Amg
Thanks. I looked at that website and looks like you need to know just what you’re looking for. I have no idea what to buy if it don’t say w202, which I did t see. If you have the time please send link to what you actually ordered. Thanks.
Old Feb 4, 2023 | 05:30 PM
I believe I IM'd AZN Optics on here and they told me what I needed
Old Feb 4, 2023 | 05:37 PM
speed43's Avatar
1999 C43 Amg
I see , I will get in touch with them when the time comes. Thank you.
