not starting after fuel filter change
Old Nov 23, 2023 | 05:10 AM
Samuel Joseph's Avatar
w202 c43
Question not starting after fuel filter change
Ive recently replaced the fuel filter on my 98 c43 and when trying to start the car, nothing! It's as if there's no fuel pressure in the system. Does this mean I need a new fuel pump or is there too much air in the system. Any ideas?
Old Nov 23, 2023 | 05:25 AM
Scottieinoz's Avatar
Mercedes Vito 113CDI
If you had no issues before changing then it is most likely air, Just crack the injector lines by a quarter turn and turn the car over untill fuel is coming out the car will likely start and run rough and just tighten each injector line 1 by 1 and you should be all good.
Obviously watch for rotating parts when working in and around a running engine
Old Nov 23, 2023 | 05:29 AM
w202 c43
thank you, what do the injector lines look like?
Old Nov 23, 2023 | 05:34 AM
your a newbie for sure, They are the small lines. Not sure if you are common rail or old school mechanical injector . I would guess the latter. There is small lines about the size of a drinking straw that go from a pump on the end of the engine somewhere and run to the cylinder head. If its a 4 cylinder you will have 4 lines, 6 then 6 lines etc
Old Nov 23, 2023 | 05:42 AM
w202 c43
For sure, I've just turned 19 and my plan is to be driving the c43 in about may but for now it's a project
Old Nov 23, 2023 | 05:48 AM
You will get there, You tube is your best place to start
Old Nov 23, 2023 | 02:22 PM
speed43's Avatar
1999 C43 Amg
Did you make sure you installed the fuel filter correctly? I think it has an arrow to show which way the fuel flows….
Old Nov 23, 2023 | 04:13 PM
DRBC43AMG's Avatar
Correct if I recall
Old Nov 24, 2023 | 01:02 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
New filter installed backwards, most likely. It only allows flow in one direction.
