Engine oil discussion again.
Old Jul 26, 2024 | 06:04 PM
AassBayer's Avatar
'01 E280T 4M
Hi folks.
I’m trying to figure out the best oil for my upcoming oil change on my ’98 C43. The manual states to use oil compliant to 229.1. However, some say that 229.1 is kind of obsolete and that I could – or even should - use oil as mentioned in 229.3 or 229.5. What are these lists? Are they revised over the years so that 229.5 is the one to go by these days?
My car is now 26 years old and of course lubricants develop. Therefore, recommendations also might change. I see that…
I had a discussion with a friend that previously worked with jet turbines. He had attended an oil seminar a while back regarding lubrication of jet turbines. Of course, they pay much attention to this aspect as they work with high performance machinery. He talked about some threads in the oil that held the lubricant elements in the oil together. The stronger and more resilient these threads were, the better the oil. These threads where torn down by temperature, age and other factors, and reduced the oils ability to lubricate over time. If this is the case, then I would assume that there are great differences between all the oils on the market. Tables 229.1, 229.3 and so forth only mention the producer and 0w-40, w5-50 etc. I find this very strange. Someone should really be able to tell us what the best oil for our old engines would be…
Old Jul 27, 2024 | 03:32 AM
DRBC43AMG's Avatar
You can dig around in here and find all the specifics
Mercedes-Benz Operating Fluids
MB recommends Mobil1 0w-40 or equivalent for the W202 M113 engine. If you live in a hot climate, go for a 5w-50 weight.
Old Jul 27, 2024 | 06:52 AM
cm60k's Avatar
beside "Mobil" 0W-40, also "Castrol "Edge" 10W-60 is super awesome, i've been using it since around 20 years..
-;-ZAYED-;-
Old Jul 28, 2024 | 03:11 AM
DRBC43AMG's Avatar
-;-ZAYED-;-
I guess that's the perfect solution for where you live Zayed
Old Jul 28, 2024 | 03:53 AM
cm60k's Avatar
Exactly Daniel, you always the BEST
-;-ZAYED;-
Old Jul 29, 2024 | 04:14 AM
AassBayer's Avatar
'01 E280T 4M
I'm aware of the Castrol Edge 10W-60 and got a tip about that. Kinda, like if you want to be really, really, really sure, go with this oil.
Old Aug 17, 2024 | 03:01 PM
MattCordell's Avatar
C43 AMG with a tune up
229.3 or 229.5 is no problems to use.
If your engine is in good condition you can go with 0W-40 engine oil.
If you have engine issues you can go with a thicker oil like 5W-40
If you don't have oil leaks but will have some day?
FYI, most engines will have oil leaks from rear main seal or front seal where the harmonic balancer sits on crankshaft.
If you fix oil leaks on time you could do an oil treatment with Omega917 gasket rejuvenator.
Most parts shops sell this gasket treatment.
You need to calculate how much you need to put in the engine for 7,5L engine oil.
Info you can find on the bottle.
Old Aug 17, 2024 | 10:15 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
And if it's an M113 you will have leaks at the valve cover gaskets at nearly every point in your life.
Old Aug 18, 2024 | 06:51 AM
DRBC43AMG's Avatar
I can confirm. Mine at 100'000km was leaking, Changed the gaskets and then with more than 310'000km when I sold my 43, it had not leaked again.
The rear main seal though was weeping a bit when it went to the new owner
Old Sep 26, 2024 | 12:28 PM
edhu's Avatar
'98 C43
Agreed, I've done mine recently at 150,000 miles.
I replaced the gaskets along with the breather and valve covers themselves.
Old Sep 26, 2024 | 12:29 PM
edhu's Avatar
'98 C43
I need to do my rear main seal. There's visible oil in that area but no leaking onto the ground.
Old Sep 28, 2024 | 03:54 AM
DRBC43AMG's Avatar
Common issue, but if it doesn't drip on the floor, I would forget until you have to either remove the engine or transmission.
