W202 AMG Picture Thread
help me out!! What are you lowered on/pad size...looks sick! Love the wheels!
now you have an even level stance with this H&R spring/spring pad combo?
not that hot look butt up in the air and the front is lower?
my euro c43 have #2 =9mm pads front and rear from factory.
I have bought a new set of #1 =5mm front and #2 =9mm pads when I drop my car, maybe I bought too thin pads and should have gone for thicker ones?
If you really like the look with the spacers on your car, I would say get your tires stretched next time you're due for new tires. See my wheel in the front is 225/235 and I had them install 215 so it's not a dramatic stretch but it gives it a little more flexibility. In the back I am planning on stretching them a lot more, now I have 265 tire and will stretch it out to maybe 235. Then I will be able to install the 20mm spacer and it shouldn't rub.
Oh and also I think Bilstein and H&R have different stiffness design for different models, I'd check on that as well because if you drive my car, it does not bounce much at all it's pretty stiff and that too gives me ability to go around without rubbing, plus the sway bars and tie rods are all on there.
Check what is installed and what isn't and figure out what you want it to do.
My original plan was for it to stay still where ever I wanted it to go, and to be able to take out 15mph corners at over 50mph and I did it.
Everybody has their own taste, and I think I could answer that question for myself lol! Yeah the bumper was on the car when I bought it, not sure where the previous owner got it from.
Width and offsets also the width of the tires.
and I saw some clips of your car on youtube, the exhaust is amazing. Is the car stock??
.. they are 18", just perfect size for W202 in my opinion.
J/K
