W202 AMG Picture Thread
Old Feb 25, 2011 | 05:05 AM
  #1051
lolle76's Avatar
C43 AMG 1999, 190E 2,3
Originally Posted by DRBC43AMG
Hi Jens
Thanks for all the info
Hope we can get a Q & A started and made STICKY!
You're welcome
I know what I would like to pass but believe me
also I know not all of our jewelry pieces....
Old Feb 25, 2011 | 05:23 AM
  #1052
DRBC43AMG's Avatar
Originally Posted by lolle76
My opinion is (if you're interested) that the C32 brake system optically
looks nicer than the original from the C43.
Technically, the C32 brake but no better than the C43 brake rather worse
for the W202. (but are just my thoughts)
Now that is an interesting piece of info. I prefer a good brake system than one which looks nice.
Question to Jens:
What other brake rotors (discs) can be used on the front? The OEM ones are sooooo expensive
Old Feb 25, 2011 | 06:24 AM
  #1053
lolle76's Avatar
Question to Jens:
That's a good question.
It's not really a cheaper alternative is for the C43 if you want something similar.
There are some people who have since tried out a lot.
Popey the user has altered his brakes on his C43, maybe you can ask him once he is satisfied with it.
Better than the original for the same money will not find you.
There are some good providers that offer a larger and visually beautiful brakes but the brakes will cost 700,-€....
Sorry
Old Feb 25, 2011 | 07:18 AM
  #1054
DRBC43AMG's Avatar
Thanks Jens,
Just one last question (for the moment)....
Did AMG offer a LSD (limited slip differential) option for the 43?
Old Feb 25, 2011 | 08:10 AM
  #1055
lolle76's Avatar
[/quote]
was not officially offered slip differential for the C43.
I know but we in the former F1 Safety Car (was the CLK55 W208) had one installed.
Old Feb 25, 2011 | 08:21 AM
  #1056
DRBC43AMG's Avatar
Thanks and great to hear as this question has often been debated on this Forum
Schöne Tag und Wochenende
Daniel
Old Feb 25, 2011 | 08:27 AM
  #1057
lolle76's Avatar
Daniel
Danke, ich wünsche Dir auch ein schönes Wochenende!!!!
Regards
Jens
Old Feb 25, 2011 | 11:06 AM
  #1058
Saaboteur's Avatar
eclectic assortment of cars
yes that is correct and certainly one reason why the C43 is very dear to me as heart!!!
Thank you!
you have been in the wheel arches provide space for something with these tires. but now there are no major body work needed.
if you want I can give you share the opinion of the restructuring measures are sending times (but only in German)
Regards
Jens
Auf Deutsch ist OK! Ich habe ein jahre Deutsch studiert, im universitaet. While I've forgotten most of it now, I can probably still get train tickets to the right destination and order beer and a meal.
Are the fender rolling instructions the same as these?
https://mbworld.org/forums/4319330-post12.html
I have another question for you - what other 17" Mercedes wheels will fit over the C32/55/CLK500 front calipers and 345mm discs? I have these calipers and discs ready to install, and I have learned that they will clear the 17" and 18" Monoblock wheels with a 3mm spacer. But I'm wondering if these wheels will fit:
http://1.bp.blogspot.com/_ew9r9-INcA...s1600-h/03.jpg
Old Feb 25, 2011 | 01:21 PM
  #1059
lolle76's Avatar
YES, the fender rolling instructions are the same as those,
but you´re not suppose to take of the front fender.
i´m sorry, but i´m quite for sure how toanswer this question to you.
i just wanna be on the safe side, so please if possible give me a detailed describtion of your monoblock wheels.
are your wheels 7,5x17 ET ? or do you mean a different size ?
Old Feb 25, 2011 | 02:53 PM
  #1060
Saaboteur's Avatar
Here is a post in my 'build' thread regarding the test fitting of various wheels I have (I have since sold the Carlssons).
https://mbworld.org/forums/4500636-post177.html
I THINK those W203 Sport package wheels will fit, as I understand some CLK500 owners use them, and that car has the 345mm discs.
I'm wondering because I may want to get rid of the 18s and go with 17s year around instead. I have the 17s for winter right now.
Old Feb 26, 2011 | 12:46 PM
  #1061
lolle76's Avatar
i don´t see any reason why the wheels should not fit with your c32 brakes.
unfortunately i don´t know anybody, or any of my friends who have done a similar construction like you just did...sorry.
but again, no problem from my side that this should work the proper way.
Old Feb 26, 2011 | 01:16 PM
  #1062
popey24's Avatar
C43 AMG 5.5 - 396.4HP
the size of my AMG rims is:
front 8,5x18 ET25 with 225/40 ZR18
back 10x18 ET25 with 255/35 ZR18
@lolle
Did you ever check your tires? Seems to be 225/40 and 255/40! Should have some trouble with ABS/ESP.
There is a LSD kit available from Kleemann.
Old Feb 26, 2011 | 01:57 PM
  #1063
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Originally Posted by popey24
@lolle
From what I understand the kleemann LSD is basically a phantom grip which is not a true LSD...
Old Feb 26, 2011 | 03:35 PM
  #1064
KJI3jflarryfe93's Avatar
lolle76
Hallo, habe ich Ihnen eine private E-Mail suchen, bis die rechte Ecke, bekommen Sie 1 Meldung zu sehen (private message).
Grüss
Old Feb 26, 2011 | 04:48 PM
  #1065
svt ricco's Avatar
1999 C43 AMG
Hi Jens
+1!
Old Feb 28, 2011 | 01:03 AM
  #1066
lolle76's Avatar
@lolle
Did you see the right.
that's an older picture. I had been given the mature and since I had not disturbed it was 255/40 instead of 255/35.
no, I never had problems with the abs / esp. the cruise control was not.
but there are long refit the right tires.
with the 255/40 tires me very well liked on the rear axle.
Regards
Jens
Old Feb 28, 2011 | 01:16 AM
  #1067
lolle76's Avatar
Originally Posted by kowalski
lolle76
Grüss
Hy,
i have only one private message from you about the 300KM/H Tachoscheibe.
Gruß
Jens
Old Feb 28, 2011 | 06:32 AM
  #1068
Hy,
Gruß
Jens
Hast du verstanden, meine Fragen zu 300 blatt?
was tun?
Old Feb 28, 2011 | 06:37 AM
  #1069
lolle76's Avatar
was tun?
Hast Du meine Antwort nicht bekommen?
Old Feb 28, 2011 | 07:02 AM
  #1070
LawRens's Avatar
43
page 43: too much text, not enough pics.
Old Feb 28, 2011 | 09:17 AM
  #1071
[QUOTE=lolle76;4543859]Hast Du meine Antwort nicht bekommen?[/QUOTE
ich habe keine ihre private antwort email
Old Feb 28, 2011 | 09:19 AM
  #1072
too much talk 'n' low on pics.
all new w202 amg members where's your cars?
Old Feb 28, 2011 | 04:29 PM
  #1073
phicas's Avatar
C36 AMG
some pics of my C36
Old Feb 28, 2011 | 11:47 PM
  #1074
:[QUOTE=phicas;4544705]some pics of my C36
[/QU
jaaa, wilkommen.
das ist ein schöne silberpfeil!
Old Mar 1, 2011 | 01:26 AM
  #1075
w202mylove's Avatar
Carlsson CM60 EX:C36AMG'96
i am trying to buy this one at the moment.
wish me good luck people i really hope this one is gonne be mine.
You have already rated this thread Rating: Thread Rating: 5 votes, 4.80 average.
