C43 Rocking Back and Forth
#51
I can do this for fun. :-) It will happen easier if your tranny is not 70 degree warm. The trannies normal running temperature is 73 C Degree.
If you push your foot down and the trannie is warm, it will not do that unless you push and raise your foot to fast before it changes gears.
#52
Solution: Take your foot off the gas, shift to 2nd or put the car in neutral..
In Texas we call this "The Bull"
Lol I had experienced this also but was familiar with the this happening before from my previous sports cars that I owned that were manual transmission. I'm surprised that drivers actually think this is an issue with the transmission and not their foot. It's a short gear, it will happen in any vehicle.
gabe.m (03-29-2017)
#53
Perhaps let the engine/transmission break in a bit before overreacting. I have just a bit over 5000k on mine and it perfect, no issues in any mode, I did not use s+ until I had 3500k on it.
#54
I've had the bucking happen once. Not a good feeling when traffic may be bearing down in you. Easily overcome with the paddle.
I've also noticed that in S+, my transmission doesn't shift to 1st at a stop in every situation until moving forward again.
#55
#56
Car stopped. Step on the gas. Car accelerates really fast for a split second. Your foot stays behind the gas pedal, due to a thing called "inertia". Gas pedal responds very fast, resulting in really fast deceleration of the car, together with the pedal. Your foot, which is moving forward at this point, presses the pedal again, and the cycle repeats a few times.
It can happen with a truck too, in the first gear, due to gear ratios.
This happens when/if you are trying to accelerate smoothly (why the hell would you do that?) in sport+. This is not a Toyota!
Anyways, keep your foot firmly on the gas pedal and it won't happen.
#57
I'm glad this thread got bumped as I had not seen it previously but am experiencing the same issue
Something very similar happens in mine as well in Sport+ but I just figured it was me not being used to the vehicle
I've only had the car for 5 days, took delivery last Friday so just at the very beginning of learning about it. I have not even experimented with paddle shifting yet, still getting familiar with driving my new car
When in Sport+ mode driving between 1-10 miles an hour there is a lot of bucking and jerking around, especially when I'm unsure of exactly what it is I'm doing as far as acceleration/deceleration (navigating an intersection for instance, where I'm gauging/merging with other traffic)
Another example is driving through a gas station parking lot looking for which pump to use and travelling at 5 mph
Now that I've found this thread, I'll pay more attention the next few days and report back
I do think some of it is driver related (as another poster mentioned), these cars do have a lot of power and seem to have very close/tight ratios in the low gears
#58
I haven't had the issue of the transmission jerking while not at a stop, but as mentioned in my thread, I think I have isolated the issue coming out of a stop to the car not shifting into 1st gear. I will be getting some other stuff done soon and will be asking service about this.
#59
#60
I was aware of this thread and so far in 2,000 kms it has happened only once to me.
While turning left at a busy intersection. Car still moving but a brief moment of hesitation judging how fast oncoming traffic was coming... do I go.. should I wait... I decide hesitantly, ok go and the bucking started. I backed out and smoothly applied gas. It was an eye opener...
In S+ the throttle pedal mapping is very sensitive (overly sensitive?) to any movement.
#61
Do you guys get that feeling that the engine runs smoother (less back and forth) as soon as the oil temperature hits +50 to 60 degrees C?
#62
Yes probably it does, but that certainly wasn't the case when I experienced it. It was 45 minutes into a drive, so engine and all fluids were at operating temps for some time.
#63
The outdoor temperature here is always 23-29 C, 75-85F. My car gets above 60C not long after I start driving. I've had it buck after an hour of driving. It also does not like speed bumps....3 or 4 speed bumps in a row in a residential neighborhood, with the slowing and then giving gas and the transmission going between 1st and 2nd gear does not work well with this transmission.
#64
I haven't experienced this whole rocking back and forth thingy yet then...but then again I've had my car for little more than a month!
#65
Only does this in Sport + from a stand still or slight coasting from 1st gear.
#66
Anyone had this resolved? I'm having this issue but in a GLC43. Sport+ will occasionally produce hard rocking/shaking. This has occurred from a complete stop and from a near stop (rolling up to a light and accelerating).
This is not be mistaken with a hard shift. I have driven a GLA45 almost exclusively in Sport+ for the past year and never had this happen or even anything remotely like this. I also used to own a Macan Turbo which I drove in sport+ and never once had this type of bucking occur. This is not a characteristic and is downright dangerous when it happens as it forces you to either jolt around (picture mechanical bull) or decelerate and switch into comfort before being able to resume acceleration.
I'm taking my car into the dealership later this week but if someone has had this looked into and had any kind of resolution then please chime in.
Thank you.
Thank you.
#68
Thank you.
Thank you.
#69
Not sure if you guys have noticed this one: at times there is also a moment of dead pedal when you try to accelerate after decelerating. I've had this problem occur near intersections and when attempting lane changes and its just as scary because you can stomp on the gas and for 1/2 of a second, there is completely no response. A lot can happen in that 1/2 second.
#70
I find when coming to a hard stop, and then flooring it, it feels like the engine is dead. No power, no noise, no building boost, just flat for a second, followed by a more gradual power delivery than usual. It's a bit disconcerting, and probably a safety nanny for the trannie.
#71
Originally Posted by cenzo86
yup
#72
Like other posters, I noticed the behavior once or twice driving in S+ just after I got the car. I assume I adapted my throttle mashing fairly quickly because for the next five months I didn't notice the behavior. Also none In the month since my eurocharged tune.
#73
This has happened to me but only when I am in sports+ mode and travelling slowly through the neighbourhood. It is interesting that when you are just cruising in sports+ mode that it would drop it down to first. I was always taught when driving a manual car to never put the gear into first when slowing down unless you come to a complete stop. I suspect that the transmission has trouble dealing with the low speed in first gear and if you do something unexpected (i.e. accelerate when it thinks you are slowing to a complete stop) it puts it on a bad footing.
Do I think this is a major issue, not really as it only occurs in low speeds and only when you are trying to baby the throttle, not like you would be taking a corner at 10-15 kms per hour and gently accelerate after apex
An easy way to recreate this is change from comfort to sport+ when you are rolling along or starting to accelerate at an intersection. Happen to me a couple of times when I wanted to impress some ladies walking down the street and wanted to pop the exhaust...Serves me for being an idiot...Talk about embarrassing!
#74
I was thinking the same thing.
