C450/C43 AMG
C43 Rocking Back and Forth
Old 12-06-2017, 02:01 PM
  #101
1Gunner's Avatar
2020 C43 sedan(hers), 2021 Porsche 992 TurboS(his)
Originally Posted by DRLC43
I am not sure if someone is inadvertently pressing and letting up on the accelerator, which is what is happening in these situations, that is a throttle mapping issue?
Really?! So this problem begins and ends with driver inadvertence in your mind?
Funny how another German car with 600HP can be smooth as silk in sport+ no matter how inadvertently the throttle is depressed .....but a measly 372HP sedan will kick and buck like a rodeo horse with the same driver on occasion.
I stand by my comment, the throttle mapping is far to sensitive on the C43 in Sport+. Shame on Mercedes for not rectifying such a simple solution.
Old 12-06-2017, 04:01 PM
  #102
SteveE400's Avatar
2015 E400 and 2015 GLK350
I don't think this is a driver-induced issue at all. In fact, there may be two separate issues in play. Please note that I do not have an AMG model, but I do have an E400. Some things in common with the C43 and GLC43, namely M276DELA30 twin-turbo V6 engines.
I think that the "dead spot" when you let off the throttle and then step on it again - only to find that there is no response, is most likely an issue with the engine/transmission control systems and software. The car "thinks" you are going to stop. Then when you don't stop, it takes too long to get back into motion. This has been an issue with many "drive-by-wire" throttle implementations at least since my 2001 LS430. Some are worse than others, and the MB is one of the worst I've driven. Nobody has a real fix for it, and MB will only focus time and money on it if enough people complain.
The second issue I note is what I call "surging." This is when you step on the gas from a dead stop and hold constant pressure on the accelerator, but the car accelerates, slows, then accelerates again -- as others have said, it feels like a novice driver with a manual transmission. This MAY be related to the turbochargers and their pressure management hardware/software. The turbo's may be over-boosting, which causes the waste gates to open and bleed off excess pressure to the atmosphere. When this happens, acceleration falters until the system catches up and the boost level is again within safe parameters for the engine. In my car, this happens more often in 'E' mode than in sport (in Sport mode, it quickly accelerates past the problem zone). The only solution I have found is to use less throttle when pulling away from a light until the engine gets to about 1800 RPM, then after that it seldom happens. Driving these cars smoothly is not easy.
This may all be related to the combination of the turbos with the higher performance intent of these cars, as I do not notice either of these anomalies with our normally aspirated 3.5L GLK350.
Old 12-06-2017, 05:04 PM
  #103
jonathan358's Avatar
2018 Mercedes C43 AMG Coupe
The acceleration (Force) of a 600HP car and the C43 is not that far off. Give or take ~0.5 seconds of 0-60 times, the AWD C43 can cause Driver Induced Oscillation just as easily. Physics acts the same in both regards.
edit: This is not to say I disagree with your statement about it being a throttle mapping problem; it very well could be. But because you brought up HP, it seems as though the were inferring it to be the difference in HP.
Old 12-06-2017, 10:22 PM
  #104
agchenry's Avatar
2018 C43
This topic has come up be fore (exteme spot+ Bunny hop tread I think) and the op in that thread got problem solved at dealer with a software update
Old 12-06-2017, 11:17 PM
  #105
DRLC43's Avatar
C43 Cab
As I said in my original post, the early production models had problems which I believe were corrected with software updates according to the posts. These people were having problems with acceleration from a dead stop and also problems with the car getting stuck in gear, downshifting etc. . I was responding to another post which an owner referring to how his wife had similar problems based on what he though was her trouble with her Uneven application of pressure in the accelerator and then trying to correct for it once the car bucks. I am only saying that this has happened to me on occasion and it was me not the car. Given that the original issues seem to be almost a year ago and others were receiving software updates to fix the problem, I am assuming that the 2018s already have the updated software. If you are saying that this problem is still happening in 2018’s, than post something about it, but from what I have read and based on my car I do not think this is a current problem.
Old 12-07-2017, 09:45 AM
  #106
1Gunner's Avatar
It's closer to 2 seconds difference 0-60 between my 991.2 Porsche Turbo S and my C43, which is HUGE... both cars are twin turbo, both are AWD. The C43 is not even in the same zip code as 991.2 Porsche TTS in quickness (acceleration)
The person I responded to was stating the C43 issue was a byproduct of quickness.
Old 12-07-2017, 09:55 AM
  #107
DRLC43's Avatar
C43 Cab
That was me and the language was imprecise. Ok what I meant was that you have a powerful car and very sensitive throttle response. If you look back at most of the posts on this several people have noted that this is a problem not isolated to the C43 but can occur in any car or even a truck or motorcycle) with a powerful engine and very low gearing. It is an issue were there is oscillation on the accelerator. I was really responding to the post where someone going to back out of a purchase because they thought the transmission was defective.
Old 12-07-2017, 12:47 PM
  #108
Shouldn't rule out driver error so quickly. There are a lot of other factors in play as well such as suspension, seats, seating position, ect... (Just the overall handling of a car)
Although the Porsche Turbo S is hands-down faster, the C43 is still powerful which can cause users to have this problem. It also weighs nearly 500lbs more. Therefore, the force of a C43 is higher relative to the power:weight ratio of the Porsche.
Again, I am not ruling it out to throttle mapping/transmission problems as there have been many cases of this happening.
Old 12-07-2017, 01:16 PM
  #109
1Gunner's Avatar
Although the Porsche Turbo S is hands-down faster, the C43 is still powerful.
Saying C43's throttle issues it's purely driver induced is erroneous in my view.
Was only using Porsche as it's an example of an extremely FAST but also silky smooth on delivery no matter what situation, whereas the C43 is not anywhere near as fast or quick in direct comparison, yet it still exhibits this crazy throttle jouncy tendency in S+.
Being a PCA instructor (and a schedule A race license holder) who owns both cars, I'm pretty confident my seat positioning and throttle control might be above the average enthusiast and yet I've gotten this bucking and rocking in the C43 occasionally. I drive around it now, but my point is... why should I need to make an effort to do this when MB could adjust throttle mapping to correct this annoying Sport+ issue.
A simple tweak would make the already enjoyable C43, even more of a driving pleasure than it is already.
Old 12-08-2017, 11:07 AM
  #110
coladin's Avatar
2014 C63 507, 2012 R350
I have an appointment coming up for my C43 transmission issues. The car slips like a burnt clutch, won't shift at redline in 1st(5000rpm), get strange error codes in red. I have been lucky enough to tape it while driving (I know, but on a deserted street at night) as it seems to happen only once a day. The first time. After that , it is good to go typically. I was told I had a software update a month after I bought it and brought it in, but it seemed to work only for a little while. Ultimately, this transmission is ruining the experience only if you like to plant it off the line, which for a car like this, one would like to be able to do that.
Old 12-08-2017, 04:17 PM
  #111
Big Goober's Avatar
2017 AMG C43
Yep, going back in also. We’ll see what they have for me this time.
Old 12-13-2017, 11:58 PM
  #112
turismo1's Avatar
C43 AMG
I just bought a c43 and im having this issue that you guys are. I like driving in S+ because of the exhaust, but this rocking back and forth is annoying as f***. Usually this happens when Im at a dead stop and I accelerate at 20% throttle. Most commonly im doing this when i'm making a turn, so im not going to mash the throttle and get the car to shift up fast or i'll probably activate traction control or spin out a bit (i assume).
I dont have the rocking back and forth if i give the throttle 5-10% or give it 100%. Is there a way to avoid this issue from what you guys have seen so far?
Old 12-14-2017, 12:47 AM
  #113
FirstMBAMG's Avatar
C43 AMG Coupe
Turismo, there is apparently an update that MB can do to adjust for this but they won’t automatically offer it or look for it (there is a recent thread around here about it). As far as solving in the meantime, it is part of the automatics ability to handle shifting gears in a tightly tuned sports car, and they didn’t do a great job when the car is trying to downshift (like making a turn or rolling through a stop), and you hammer it. It’s not great at reacting. Very easy “fix” is to let off the gas slightly, give the car time to understand it’s going the other way. OR better fix is to shift to accommodate the flooring it, that will alleviate it.
Old 12-14-2017, 08:32 AM
  #114
1Gunner's Avatar
Same happened to me several times in same scenario... VERY annoying indeed for a car of this calibre to behave in this manner.
Here's a work-a-round.... When in Sport +, from a dead stop upshift to 2nd gear before you start into the intersection. There's lots of torque with the turbo engine that it pulls nicely in 2nd gear from a dead stop.
Old 12-14-2017, 08:40 PM
  #115
Nc43's Avatar
2018 C43 Sedan
Me three. Drives me nuts and I hate that it makes me look like some tool who can’t drive a stick. I’m taking mine to the dealer over the holidays and asking for the fix. Does anyone have the name of the fix? I can’t seem to find it from these other threads...
Old 01-11-2018, 04:29 PM
  #116
C43_1995's Avatar
M3
Just chiming in to say that I have this problem too, Sport+ light gas in 1st or 2nd makes it buck back and forth wildly. I have an '18, so they obviously haven't updated the new models yet. Going to go to the dealer soon, as it's started happening (albeit more rarely) when I'm in Sport mode as well.
Old 02-20-2018, 08:43 PM
  #117
MBkent's Avatar
C43 AMG
It just happened to me today at the traffic light coming out from a complete stop in Sport +. It is a 2018 with 1.6k miles...less than 3 months old. The car wouldn’t go, just chok back and forth. It recovered after I changed it to Sport mode. Terrible experience, hope it won’t happen again.
Old 02-20-2018, 08:55 PM
  #118
Former Member
removedCFGaccount's Avatar
CLS
Let’s hope your Racechip helps. It does smooth out the shifts on my c450.
Old 02-20-2018, 10:34 PM
  #119
I hear that you can upshift manually to stop the jerking.
Old 02-21-2018, 02:45 PM
  #120
leojhartiv's Avatar
C43 AMG Coupe
I got this solved via the dealer. Mentioned this thread or another with references to a known TSB and they upgraded the software/firmware/whatever. Haven't noticed a problem since.
Old 02-21-2018, 03:04 PM
  #121
Former Member
CLS
What he said.
Old 02-21-2018, 04:56 PM
  #122
MBkent's Avatar
C43 AMG
Racechip was in Sport or Race mode when it happened
Old 02-21-2018, 04:58 PM
  #123
MBkent's Avatar
C43 AMG
Thanks, will keep monitoring before bringing it in. Finger crossed it doesn't happen again.
Quick Reply: C43 Rocking Back and Forth
