Gas pump troubles?
My dealer told me they will check it out but that this is likely normal and caused by MB's new fuel filler design. This sounded like nonsense to me, but sure enough my loaner C43 does exactly the same thing.
What is this insanity? MB designed a new fuel filler that doesn't work properly with most pumps and is just telling folks to live with it? The only other car I've owned with a remotely tricky fuel filler was a 35 year-old BMW. I can't fathom why this issue would be acceptable on a brand new Mercedes.
Nozzles in in NY stations for example will fit perfectly on our cars.
These don't fit properly:
These the ones that fit perfectly:
Other than that, I've never had a problem. Now that I say that, it'll happen to me when I fill up on the way home today....
On the other hand, I have the same problem guys. The way around is starting to fuel slowly into the tank. Like don't pull the pump handle all the way in. Slowly increase the flow up to 10L, after putting in 10L like this, you can go full in with all the flow and it should not shut off.
Worked for me till now. Let us know if you guys figure out a better way.
Took car to dealer for service B. Two years old. 7000 miles. Had in Hawaii last two years. Barely drove. Different gas pumps there. OLD kind. So nice. Came back to Ca with car. Can NOT fill or even put gas in tank. Takes 20 min. Hand is chopped up, tank not full. Just like other cars on here. Dealer kept it THREE days. Took it to various gas stations. Said nothing wrong with it. Now that I get it back, I SWEAR they put some new black plastic filler partition in the car. It was NOT there before! I now pull in ANY gas station. Stick fuel filler in tank. Pull back so auto fills. Go sit in car on internet or phone. IT fills, stops and VOILA, the car is full. Don't tell me they didn't "do " anything to it. But glad they did..I think I see a brand new black plastic filler in the tank. Call me crazy ( everyone else does) but that's my experience. I was about to get RID of it because its my only car in CA and I was getting frustrated at the pump every single time. Now, no problem. Explanation when dealer claims they did nothing to it, and had NO problems filling it? HOGWASH is my explanation. Why'd they have my car three days, giving me FREE Mercedes to drive while they only were doing oil, rotate tires, etc. then ....THREE days????
Obligatory "that's what she said".
