Exhaust is going quieter and it is definitely not in my head
S+ also seems a lot quieter, with the pops and bangs only happening when you drive aggressively.
I'm hoping that because the software update reset everything, it has some relearning to do and will go back to how it was...but from everyone else's comments I don't hold out much hope.
Is there anyway to see what software version your engine/transmission is running? Could dealer mode access that info?
@munis, did you manage to solve the problem?
I always found that after I fuel up, I use Shell 91, the car gets louder. Both exhaust and engine noise. Could be the cold fluid running through the system.
My car does not have the fuel system update, does anyone know exactly what that changes? I want to get it just to have the latest software but as most of you have experienced, nagging dealers is the only way...
I found that if I continuously run map 5 or 7 with my JB4 though (and ECU adapts), the car will pulls like it has a deathwish on it and sound effing loud until the temp drops below 0C. If I switch back to stock, car becomes quiet below 5C again.
I know you had a reply that was pretty specific but I recently just got an update last week and my car is noticeably much quieter and I was wondering if anyone has found a fix or if theres a way to get mercedes to fix this.. they've already told me the update they did wouldnt have done anything to the loudness of the car but its noticeably quieter.. feel like I'm going crazy but I bought the car for the cracks and pops. I want them back any info helps! Weather conditions havent chanced much here in the past week so I know it has to do with the recent update
Why do cold metal plates make less noise?
If the backfire sounds less pronounced, it could be that the cold metal is dampening the sound quite a bit. I guess we are both stuck waiting for warmer weather to test this theory
Are you throwing the car in Sport+ when you use high octane gas, but not low octane?
On a side note, if I do pump 94 octane, it does get much louder and kind of gets its voice back. But even then I feel it isn't as loud as before.
When I first got the car, it made a bunch of kids cry rivers because they though someone was shooting people around. Girls would scream in fear and boyfriends started to pull their girlfriends to the side of the road as if the car is going to explode.
All that still happens, but way fewer in number. And I am missing it. What gives?
