C43 AMG Oil Change (For those who wants to do it a bit early)
I think some of us here usually like to take a more conservative approach to oil changes than the factory recommended schedule and do it a bit earlier than what is recommended. I will be hitting 10000km in a week and I plan to get mine done then. Just the oil and filter change and then I will go back to MB for the Service 1 @ 20k.
We can just generally discuss some oil preferences, and what you guys usually use. I will probably be going with Mobil 1 5W-40 Euro Spec, which meets the MB229.5 standard. Please feel free to suggest something otherwise.
Also does anyone here know the exact amount of oil this car needs during an oil change?
Any info is appreciated.
I used Mobile 1 0-40W. I changed it at just under 6000mi (1st oil change).
I used an electric extraction pump. I bought the filter element online. I didn't use MB brand, instead I purchased from one of MBs OEMs with their house brand on the box. This got me the exact same product for a little over half the cost. I did not need a filter strap wrench to remove it. I just unscrewed it by hand. It was snug but it came off with a little persistence.
There is a DIY on the W205 forum for changing oil with an extraction pump. A search should find it.
I think some of us here usually like to take a more conservative approach to oil changes than the factoryrecommended schedule and do it a bit earlier than what is recommended. I will be hitting 10000km in a week and I plan to get mine done then. Just the oil and filter change and then I will go back to MB for the Service 1 @ 20k.
You can climb under if you want, but it's just personal preference and has no bearing on the efficacy of the oil change.
Waste of money and a risk of warranty voidance. But hey, whatever makes you happy I guess.
Nobody made any claim about the longevity of the oil. The reason for the early change is either:
1. Many do not trust running a full interval for the initial (break-in) oil change. I am in this camp.
2. Some people do not trust extended oil change intervals...period. Personally, I think this is a bit old school but it is important to note that not all synth oils are equal. Regardless, early oil changes are never going to hurt an engine unless you screw something up.
I'm OK running mobile one out to 10K miles. I've been doing it for many years in vehicles ranging from a 3cyl 1st gen Honda Insight to an 5.4 F150 Lariat and a Toyota econobox. Mobile 1 works just fine at extended intervals. People over on Bob Is The Oil Guy have posted oil analysis on Mobile 1 out to much longer intervals then 10K and the properties were still nominal.
https://www.bobistheoilguy.com/forum...s.php?ubb=cfrm
And as far as "the dumbest yada yada yada on a car forum".... You may not be able to think outside of the box and imagine different scenarios, but a car manufacturer could feasibly void a portion of your warranty for using a non MB approved oil and/or filter; or over/under filling. Most often in a situation when you're on a lease and you have prepaid/mandatory maintenance. If something goes south on the motor, and they can prove it's possibly due to a DIY oil change (or whatever project), you bet your *** they will.
I've heard this through the forum grapevine that it happened to someone with a Gallardo. Had to pay for a ~$80k motor out of pocket.
Mr. J, I dunno I have seen several videos where it said using oil extractor does not get rid of all the oil. Out of the two which one do you think is better? If the easiness of it is not in question?
I have one on my F150 and it makes life and DIY oil changes so much simpler!
Changed the oil at 9500mi yesterday...
7qts Mobil1 0w-40 synth - $48.24
Genuine MB oil filter - $20.40
Saved $230 over visiting the stealership
as said above, with todays full synthetic oil, there is really not a worry about breaking down the oil before 10,000 miles or even 15,000 miles. but if you track car or drive harder, its usually advised to change at 10,000 miles max.
I do a break in early oil change to get out any metal and debris from engine break in. working at an auto supplier and seeing the crud we take out of pans after a break in dyno test really encourages the early break in change on a new car. just my .02 cents. its pretty cheap peace of mind if doing yourself especially if you plan to keep car a while.
It's exactly what I have and works great for cars, lawn mowers, ATVs, pressure washers, Jet Skis, boats etc..
I would not want a bigger one even if they came bigger.
i notice there are sizes for c300, c63, c63s
i believe the c63s use the same size.
I used 5W40 in mine when I changed it and that is in mercedes spec 229.5.
Are we saying that both oil weights are correct?
What is the factory fill weight?
BTW I changed my break in oil at 1500mi, say what you want but I do this with all of my vehicles. I bought some Race Ramps for $220 to get at the car from underneath- I will never use a vacuum pump out of the dipstick, that,s just me- I love to wrench. You have to remove a plastic panel to get to the oil drain plug and the filter is easily accessible from the engine bay.
I used Amsoil European Formula 5w40 and the original MB element.
Surprising that after 1500mi the factory oil was black already, not filthy black but dark colored, my Amsoil after 5000mi is still clear gold.
BTW my opinion, but every manufacturer finds way to cut costs, so maybe the factory fill oil is a lesser quality than a reputable brand I can buy off the shelf.
Anyway like they said its cheap insurance for $50 it cost me. I wipe my *** with that
