All season tires for c43?
I do live in an area that gets below freezing temps in the winter with occasional snow. Would it be a bad idea to go with all seasons as opposed to dedicated winter and summer sets?
And somewhat related, what is the general concensus on size and brand for wheel spacers on these wheels if I'm not planning to lower it. I've tried searching the forums and I've seen so many different opinions...
thanks!
ECSTuning has some (same as Audi fitment) just make sure you get the right bolts. I usually go with H&R.
I'd probably just run the all seasons - there are a few out there that will give even good summer tires a run for their money, otherwise I'd get another set of wheels and tires for a dedicated set-up
I like your idea of doing the 5mm in the rear with thicker tires. Are there any tires you could recommend?
And I assume you mean a more substantial looking tire as opposed to actual different size right?
I would not recommend you to run all season tires as it's a performance sedan and you'll be sacrificing the handling. Also, you mentioned that you live in the area where you get freezing temperatures and all season tires would not be the best route to go.
You should be running proper winter tires instead of all seasons. Hope this helps in your decision.
Also for those who go to non runflats, do you just have some fixaflat in the trunk, or just calling mb roadside assistance?
I mean using the same OEM spec tires, but different tires fit differently on the rim, some wider than others.
And like others have said, the change to runflats is only a marginal improvement in ride quality. The suspension is the main culprit of harshness.
Thx everyone for the helpful replies!
You don't have to agree with me.
The suspension handles abrupt dampening poorly and that is not changed swapping tires. Sure - it is muted but still fairly prominently.
Pilot AS3 may be a good compromise, but I still wont go out on those near freezing temp, especially at night.
The ride will be stiff no matter what tires you put on it. Anyone who claims otherwise is deluding themselves.
For me, changing out the runflats made the ride a tiny bit more comfy. The big difference was handling characteristics.
The AS3+ perform just as well as the stock Contis in warm temps. More importantly, they maintain the same level of performance in cold temps. They also perform exceptionally well in cold wet weather. Considering that we've had over 50'' of rain here over the last 6 months, the cold/wet performance has made me a fan of these tires.
The tests on Tire rack also support this. If I was not able to get the AS3+ I would have gotten the DWS.
The runflats are stored and will be re-installed just before lease return. I will not miss them for one minute.
Has anyone had any experience with the bfgoodrich comp 2 a/s?
It looks like they have good reviews on tirerack and sell for a bit less than the other two...
