C450/C43 AMG
DIY C43 oil/filter change
Old Aug 11, 2017 | 12:55 PM
1Gunner's Avatar
2020 C43 sedan(hers), 2021 Porsche 992 TurboS(his)
Question DIY C43 oil/filter change
Any tips and pointers from fellow DIY'rs would be appreciated.
Car is at 7500kms or ~4600 mi on factory oil and filter.
Like oil type, oil filter PN, tools needed, etc...
Old Aug 11, 2017 | 01:46 PM
Star4life's Avatar
2017 C43 AMG
in for answers. Mine is at 2700 miles. Will be getting there soon! I am assuming its a standard #2 oil filter socket and 13mm bolt drain plug. For the first one im gunna do drain method. Others I may get a mity vac and suck out the top.
Old Aug 11, 2017 | 03:53 PM
equetefue's Avatar
17' C43 Sedan
MityVac here. Clean and painless
Old Aug 11, 2017 | 04:15 PM
NYCSoiL's Avatar
2018 GT R; G82; M340
Mercedes don't want you to replace the oil before you hit 10k miles…
Old Aug 11, 2017 | 07:39 PM
likerage's Avatar
C450
Well no I believe they want you to replace it before 10k. That's a bit different.
Old Aug 14, 2017 | 09:35 AM
Star4life's Avatar
2017 C43 AMG
there is nothing wrong with doing a break in oil change before 5k miles. after that 10k on a full synthetic is reasonable. Sooner if you hoon/track the car around. Make sure you are getting the special filter that is NOT paper. Paper oil filters should not be driven much more than 5k miles.
Old Aug 14, 2017 | 01:59 PM
mau108's Avatar
C43 AMG Sedan
I did my first oil change at around 5000 KM. Used a topsider extractor to extract oil through dipstick (next time around I am going to do this and also unbolt from under the car to see if anything does come out). Used a Mann filter, I will probably go with a filter form Mercedes since its only 2 bucks more then the Mann was here in Canada.
