C450/C43 AMG
C450/C43 Wheel Fitment Guide
Rating: Thread Rating: 3 votes, 5.00 average.
Old 11-14-2018, 01:29 AM
  #226
MarcusDubya77's Avatar
19 C43 Coupe, XC 60
Originally Posted by alexasa
You can do that if you're lowered, but stock ride height on 19's max I would go in the rear is 12mm.
front will have issues the second you go over 5mm because those small of spacers are not hub centric, and 10mm (when hubcentric comes back into play) is just borderline too much, IMO.
I meant tire width 265 vs 255 and 235 vs 225.. Sorry for the confusion
Old 11-21-2018, 11:33 AM
  #227
Csandoval1988's Avatar
C450
I have read through most of this forum and have realized that for the front ideally 30-35 off set for fronts and 45-50 for the rear is the way to go so if anybody could assist me in this set up I would greatly appreciate it since I want a second opinion before jumping the gun on purchase.
varro vd06x
19x8.5 et 30 wrapped in 245/35/19 pilot sport 4s Front
19x9.5 et 45 wrapped in 285/30/19 pilot sport 4s rear
or
Zito zf01
19x9 et 25 wrapped in 245/35/19 pilot sport 4s Front
19x10 et 45 wrapped in 285/30/19 pilot sport 4s rear
thanks in advance for your help!
Old 11-22-2018, 07:56 PM
  #228
JasonGinWV's Avatar
'19 C43 and TBSS
Again, since I'm still waiting on my '19.... Tire thoughts.
Anyone have any negative thoughts about 225/40 19's front and rear on stock wheels? Tire manufacturers recommended wheel width fit both stock wheel rims as they suggest 7.5 to 9 inches.
I've gone back and forth on which way I'd like to go several times! Just wish the car would get here so it'd force my hand and I could stop thinking about it.
Thanks!
JasonG
Old 11-25-2018, 09:34 AM
  #229
Bigwaves's Avatar
C43 AMG
I am at the same place - following this very post closely.
Old 11-25-2018, 11:41 AM
  #230
19 C43 Coupe, XC 60
Can anyone confirm if the C63 forged multispoke will fit?
Old 11-27-2018, 01:56 AM
  #231
19 C43 Coupe, XC 60
"The C43 brakes are tricky, you need to run a slightly aggressive offset to clear the brake. We've sucessfully cleared the brake by running 19x8.5 +28 19x9.5 +48. It fits flush if lowered ."....Is this correct? This would be on 235/40 and 265/35 tires....
Old 11-27-2018, 02:43 PM
  #232
alexasa's Avatar
c
That rear fitment is conservative, especially lowered. Can easily go 5 - 8mm more aggressive if not more if you're trying to push the boundaries. Especially considering that is very aggressive front fitment.
Old 11-28-2018, 02:50 AM
  #233
19 C43 Coupe, XC 60
Will it break flush up front? Trying to avoid if possible.
Old 12-20-2018, 11:29 AM
  #234
Dieseldan9's Avatar
2018 C43 AMG Brilliant Blue Metallic
Looking at the AXE CS LITE in 19 by 8.5 AND 19 by 9.5 both the same offset of 40.
According to website and carID these will fit???
What do you guys think?
Car is stock not lowered
Old 12-20-2018, 12:22 PM
  #235
alexasa's Avatar
c
No. 8.5 needs to be et32>x>et28 depending on tire for stock height. Can go more aggressive if lowered.
Old 12-20-2018, 05:07 PM
  #236
Dieseldan9's Avatar
Thank you alexasa
Old 12-20-2018, 05:46 PM
  #237
tmoneyC450amg's Avatar
2019 E63S
What psi are you guys running on 19s non runflats?
I have 40 all around on 245/35/19 and 285/30/19
Old 12-20-2018, 06:58 PM
  #238
mo11's Avatar
2017 C43
38psi (f ) and 36psi (r), 255/35 19f ; 295/30 19r on Michelin PS4s
Old 12-21-2018, 02:02 AM
  #239
19 C43 Coupe, XC 60
I think I might have asked before, but what are the specs on your wheels? Are you lowered?
Old 12-21-2018, 05:47 AM
  #240
alexasa's Avatar
c
19x8.5 +30 offset front, and 19x10 +55 rear. Matched it with 255/35 and 295/30 Michelin Pilot Sport 4s
Old 12-21-2018, 07:43 AM
  #241
19 C43 Coupe, XC 60
It he lowered at all? I can't tell with all of that delicious meatiness.
Old 12-21-2018, 08:15 AM
  #242
alexasa's Avatar
c
read thread man. Yes. he's on springs.
Old 12-21-2018, 08:28 AM
  #243
mo11's Avatar
2017 C43
Sorry, ‘got busy yesterday. Yes, lowered on h&r springs.
Old 12-21-2018, 06:10 PM
  #244
2019 E63S
Damn, I should lower my psi then lol. maybe 38f/37r since it is the winter after all
Old 12-25-2018, 09:11 PM
  #245
JasonGinWV's Avatar
'19 C43 and TBSS
Still thinking about options... A square snow setup now since I really like stock 19's for summer!
Is 18x8 42mm offset front and rear with 225/45 close enough to stock sizing to be plug and play? Online offset calc's show minimal difference.
https://www.ebay.com/itm/18-C43-AMG-...!-1:rk:13:pf:0
Thanks again!
JasonG
Old 12-25-2018, 11:41 PM
  #246
alexasa's Avatar
c
Thanks again!
JasonG
no, need to be around et30 to work.
Old 12-26-2018, 12:02 AM
  #247
JasonGinWV's Avatar
'19 C43 and TBSS
Well hell. I thought I was understanding the offset and everything needed to pick some out. I guess I'm just not getting it.
Thanks for the fast reply sir! I'll keep looking.
JasonG
Old 12-26-2018, 08:05 AM
  #248
JasonGinWV's Avatar
'19 C43 and TBSS
What about these?
https://www.ebay.com/itm/18x8-Wheels...4AAOSwF25bJZzs
18x8 et32, MB replica style?
Thanks,
JasonG
Old 12-26-2018, 08:22 AM
  #249
alexasa's Avatar
c
What about these?
Thanks,
JasonG
pretty close to comfortably say yes. I ran 19x8 et30 with a 245 and scrubbed material off the inner shoulder. So, you'd have less tire bulge but less inner clearance.
Old 12-26-2018, 10:23 AM
  #250
JasonGinWV's Avatar
'19 C43 and TBSS
Thanks again! I think I'll hold out then until I find a 18x8 et30 to try and be a little more cautious.
JasonG
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: C450/C43 Wheel Fitment Guide
