C450/C43 AMG
C450/C43 Wheel Fitment Guide
Rating: Thread Rating: 3 votes, 5.00 average.
Old 08-20-2018, 12:09 PM
  #176
Synarchist's Avatar
2017 C43 W205
Originally Posted by CClement
Front would be fine, rear your going to stick out too far.
Thank you for the heads up!
Old 08-23-2018, 11:11 PM
  #177
NYCSoiL's Avatar
2018 GT R; Tesla M3P
What are your thoughts on 19x8.5 +25 in the front?
Old 08-24-2018, 07:28 AM
  #178
CClement's Avatar
2009 C230
That could work dropped but I'd go +30 or so to be safe. +25 might push you a little beyond flush and you definitely
don't want that look. I had that in the rear when I had 15mm spacers and it drove me crazy so I ordered a set of 10mm
ones and now it's perfect. Let me know if you'd like me to take some close-up pics to show.
NYCSoiL (08-24-2018)
Old 08-24-2018, 09:13 AM
  #179
C43amg-sedan's Avatar
C43 amg
FITMENT
VFF-107 FRONT 19X8.5 REAR 19X9 , GOING TO LOWER THE CAR ON H/R AND TIRES WAS THINKING OF 235/40/19 AND 265/35/19, WILL THE FITMENT RUB? WHAT SPACER/OFFSET WOULD BE RECOMMENDED? THANKS
Old 08-24-2018, 10:53 AM
  #180
SPONSOR
thewb's Avatar
www.wheelsboutique.com
The V-FF 107 for your car comes in 19"x8.5" ET 35 || 19"x9.5" ET 46 with recommended tires of 225/35/19 || 265/30/19. If you were to follow the recommendations from Vorsteiner's engineers then the fitment is guaranteed without any rubbing. These are out of stock but pre-orders are being accepted for the next shipment. They will sell out before that shipment arrives. If you're interested in purchasing contact me at 786 249 0127 ext. 2109 || David@WheelsBoutique.com
Old 09-20-2018, 11:43 AM
  #181
mo11's Avatar
2017 C43
255/35 295/30 on 19’s
Recently switched from 20’s to 19’s. My previous setup were 20x8.5 +32 offset with 245/35 front, and 20x10 +55 offset rear. The tire diameter was getting too tall it was affecting how quick i could take off from a stop.
After doing some calculations on tire diameters and the lust to get wider tires without risking the 4matic f/r ratio. I decided to switch to 19x8.5 +30 offset front, and 19x10 +55 rear. Matched it with 255/35 and 295/30 Michelin Pilot Sport 4s, respectively. I knew the diameter would fit since my 20’s were taller. I’m still on H&R springs and as usual the concern was the suspension up front and the wheel well in the rear.
When I first saw the tires for the rear, I really thought there was no way it would fit in the back. Even the guys in the shop were crossing their fingers, hahaha!
So, to those who dare to drive with these tolerances, I’ll be attaching pics and how the car looks. I do have very slight rubbing on “C” mode on dips, but who ever drives on “C”, anyways, hahaha! Sport+ is preferred mode but still slight rubbing on big dips, and only the fender liners. Nothing touches the chassis and paint. I can say, the tire widths outweighs the slight rubbing.... very negligible.
Wheels: VSForged VS-06, forged monoblock, brushed aluminum.
Fender gap front,
Fender gap rear,
Fender clearance: front,
Rear,
Now to the gnarly part...
suspension clearance: right front,
Left front,
Rear inner fender clearance,
I’m very happy with the results!
I know it’s not for everyone, but I hope this helps anyone willing to go this route...
Thanks to everyone who posted their specs and pics on this thread. I know it helped me a whole lot!
The following 3 users liked this post by mo11:
Dieseldan9 (09-21-2018), GuardianVA (09-20-2018), Patton250 (09-12-2019)
Old 09-22-2018, 09:18 PM
  #182
chan1011's Avatar
2019 E300 4Matic, 2021 AMG CLS 53 4Matic+
Thanks to @star4life and everyone else on this forum, the knowledge and information here really helped me make an informed decision, albeit an expensive one!
So far the wife and I are really happy with the results and wanted to share another successful option for our cars
Front - BBS CIR 2004 - 19x8 ET44 w/ BBS 10mm Spacer & BBS Lug Bolts
Rear - BBS CIR 2201 - 19x9 ET42 w/ BBS PFS Hubcentric rings & BBS Lug Bolts
Old 09-23-2018, 11:53 AM
  #183
jonathan358's Avatar
2018 Mercedes C43 AMG Coupe
Sorry if this is in the wrong place but I am looking at the Vorsteiner V-FF 107 wheels that come in 19x8.5+35mm Front & 19x9.5+46mm Rear. Manufacturer suggests 225/40/19 front tires and 265/35/19 rear tires. All this on stock suspension.
I have purchased Continental ExtremeContact Sport tires in 235/40/19 Front and 265/35/19 Rear.
A tire distributor as well as another member suggests adding a 3mm spacer for front caliper/knuckle clearance. With that 3mm spacer, will the setup look flush ENOUGH? Since I am completely changing the fitment, I might as well adjust stance as well. Will adding a larger offset work if needed? I am not looking for crazy wide stance nor am I able to lower due to snow and ice.
Any help is appreciated, thanks in advance!
edit: Suggestions on spacer and lug bolt brands would be great.
Old 09-24-2018, 02:40 PM
  #184
mo11's Avatar
2017 C43
All your specs look good to me... Wheels, spacers and tires should give you a flush fitment.
The only thing I would confirm is if the wheels you are getting have a ball or cone seat. Most aftermarket wheels drill them with cone. If you need to get new lug bolts, I would check out RAD Otis Inc. LA website.
Good luck! And don't forget to post pics, once your setup is complete.
jonathan358 (09-24-2018)
Old 09-26-2018, 03:22 AM
  #185
MarcusDubya77's Avatar
19 C43 Coupe, XC 60
Subscribed.
Old 09-28-2018, 09:30 PM
  #186
mcschan86's Avatar
C43 Coupe
I'm trying to spec a winter set (18") for 2017 C43 coupe. Is there a known aftermarket set that doesn't require spacers? only a rims-tires setup?
Old 10-01-2018, 10:53 PM
  #187
mcschan86's Avatar
C43 Coupe
I'm trying to figure out if 18x8 (PN: A2044013902) for the front and 18x9 (PN: A2044014002) for the rear can fit the 2017 C43 Coupe. They look similar to the OP's first post but the not sure if they are the same part numbers. Wheels are from the previous gen but I can't find specs on them (?).
I also wonder if I would need spacers to set up these wheels. Planning this for a winter setup
Old 10-13-2018, 06:30 PM
  #188
tmoneyC450amg's Avatar
2019 E63S
Appreciate everyone's input in this thread. It is quite informative
I'm trying to figure out if I can match 235/35/19 and 265/30/19 instead of 235/40/19 and 265/35/19 on 19x8et30 and 19x9et45 wheels. Reason being so is because Im leaning towards getting the Conti ExtremeCOntact DSW06 all season ultra performance tires
Thanks!
Old 10-15-2018, 10:29 AM
  #189
mo11's Avatar
2017 C43
Thanks!
Yes, you can. You just might not like the fender gap, if you’re on stock height. Lowered, it’ll look better.
Old 10-15-2018, 03:45 PM
  #190
2019 E63S
Thanks for your response mo!
Yea, I'm planning to keep stock height (due to the horrible roads and my non-ramp, street curb entrance to my apartment building's garage.
In that case, I might have to opt for slightly thicker sidewalls and wider wheels.
What you guys think of this setup:
19x8.5 with 245/40/19 striving for et29-32
19.9.5 with 275/35/19 et-42-45
would the 8.5 and 245 conti DSW's rub in the front? I know the 245 conti's are as wide as the 235 PS4S..however, I do wish to keep A/S tired because I don't want to deal with switching out rims for the seasons.
Old 10-15-2018, 05:32 PM
  #191
alexasa's Avatar
c
I ran that tall of a tire and would never have done if I could of changed it.
Would keep the rolling diameter within ~1.5% of stock and no more. Car felt a bit floaty and steering sharpness decayed.
Old 10-16-2018, 01:02 PM
  #192
RichardCranium3's Avatar
'19 CLS450
FYI to all: Save $100 on $400 purchase through Discount Tire's ebay shop. Linky > https://www.ebay.com/rpp/67626 - Expires Oct 28th
Also, I know it's somewhere in the bowels of this place but search isn't finding it. Do 265s on stock rears, stock height, stay issue free without spacers?
Old 10-16-2018, 09:55 PM
  #193
Yes.
RichardCranium3 (10-17-2018)
Old 10-18-2018, 03:19 AM
  #194
2019 E63S
Ok guys, so I went into my local wheel shop who's been in the biz for over 25yrs...I was presented with two Niche wheels that would fit the C450/43: Niche Misano and Niche M203 Vosso in matte black.
Because I've read a post here mentioning how the Misano's were not such a great fit, I decided to go ahead and order the Vosso in 19x8.5 and 19x9.5.
Also, because I'm going with performance all season Conti DWS, I'm limited to either 225/40x265/35 or 245/35x285/30...The shop went ahead and ordered the latter.
Should I have opted for 225/265 instead and be +~.5% larger diameter than stock or go with the larger/skinnier tires and be -~1.8% diameter smaller than stock?
Thanks for all your help guys, much appreciated!
P.S. I just realized that the OEM wheel diameter for the 18s is 25.79 and 19s is 26.09. Thus going with the 245/285 combo would situate me much closer ~-0.01% of OEM 18s diameter...
Old 10-18-2018, 08:07 PM
  #195
alexasa's Avatar
c
You'd probably want to be at +31 (+/-1mm)
What's the offset? That's a lot of tire for stock suspension and without it being dialed you'll either poke or rub inner suspension.
I like to upsize diameter on stock suspension to close fender gap, and 225 on 8.5 is a bit stretched for stock ride height. So it's kind of a toss up.
Old 10-20-2018, 04:07 PM
  #196
2019 E63S
Just made the first attempt to fit the new wheels today and the front did not fit as the wheel is 19x8.5 et42...the shop also didnt have MB spec spacers available either.
Theyre planning to order the same wheels in et25 to see if it would fit because they installed a Lexani 19x8.5 et25 and said they were fine.
I saw my tires that came in 245/35 and 285/30 and they looked super skinny. I do hope they fill out more when it's pumped up. Even so, the diameter will be 25.73 on the 19s, slightly less than the OEM 18s (25.79). Not sure how that's gonna look
Old 10-26-2018, 06:36 AM
  #197
2019 E63S
Ok guys, just got my new wheels installed yesterday:
Niche Vosso m203 19x8.5et35 19x9.5et42
Continental DWS 06 245/35/19 285/30/19
Stock suspension
here is what ended up happening:
Attempt #1: supplier sent the wrong offsets for the front (19x8.5 et42) so we ordered in a set with et35 and et25
Attempt #2: et25 was way too aggressive for the front and my installer is very reluctant to use hubcentric spacers so we've decided to custom drill the 5x4.5 bolt pattern with inserts to achieve a 5x112 19x8.5et35 wheel. We added a 3mm spacer for extra clearance from the control arm and added a hubcentric bore ring to fit the 72.5m bore of the wheel.
Here are the results:
C450/C43 Wheel Fitment Guide-photo82.jpg
C450/C43 Wheel Fitment Guide-photo738.jpg
C450/C43 Wheel Fitment Guide-photo445.jpg
Click image for larger version
C450/C43 Wheel Fitment Guide-photo835.jpg
C450/C43 Wheel Fitment Guide-photo529.jpg
C450/C43 Wheel Fitment Guide-photo691.jpg
C450/C43 Wheel Fitment Guide-photo669.jpg
C450/C43 Wheel Fitment Guide-photo227.jpg
C450/C43 Wheel Fitment Guide-photo976.jpg
C450/C43 Wheel Fitment Guide-photo743.jpg
C450/C43 Wheel Fitment Guide-photo10.jpg
C450/C43 Wheel Fitment Guide-photo641.jpg
C450/C43 Wheel Fitment Guide-photo786.jpg
C450/C43 Wheel Fitment Guide-photo744.jpg
Attached Thumbnails C450/C43 Wheel Fitment Guide-photo156.jpg   C450/C43 Wheel Fitment Guide-photo247.jpg
Johnyturbo (02-19-2021)
Old 10-26-2018, 08:04 AM
  #198
alexasa's Avatar
c
Stock suspension
LOL, no way in hell that redrilling, still using a hubcentric ring and a spacer is a better option to just using a proper hubcentric spacer.
But glad it worked out for you.
Old 10-26-2018, 08:27 AM
  #199
2019 E63S
actually, I'm still in belief that my wheels are rubbing against the control arm nub. I'm gonna go in and suggest I get a 5mm spacer put on to give me a et30.
The shop even suggested to grind down the control nub to gain clearance, but I am all against that option.
We'll see..I'll have to bring it in tomorrow because I just took some closer pics this morning and it certainly feels tight in there, about 1mm of clearance if not less...it's enough to fit a ID card and that's about it. I can squeeze the id card in between the wheel and the control arm, and it will stay there.
I hope a 5mm spacer will solve the problem
Old 10-26-2018, 09:00 AM
  #200
Whoever designed that upper control arm is an idiot. I keep having second thoughts of purchasing an 8.5" et 35 now...
I might just go for a whole different wheel just so I can use a properly sized spacer or one that doesn't require spacers at all.
The following 2 users liked this post by jonathan358:
Patton250 (09-12-2019), questern007 (02-24-2024)
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: C450/C43 Wheel Fitment Guide
