C450/C43 AMG
S+ extreme bunny hops fixed. Possible fix for others.
Old Nov 10, 2017 | 01:38 PM
hatata's Avatar
C43 AMG
I had my car in for Winter tires and recall work. Brand new 8,000 KM. Like everyone else i noticed the extreme bunny hops in low gears if you hesitate or modulate the gas in a non committed fashion. I kind of learned how to avoid it by modulating my foot differently but I wasn't convinced it was all me. I asked the dealer to look into it and only update the ECU or Transmission programming if they found a tech bulletin specifically sighting this issue.
They found one for the Tranny based off a bulletin mentioning this issue (should have asked for the SB number). Also they updated the fuel mapping based on the VIN there was a newer version so take that for what you will. I can confirm that I have tried to replicate the lurchiness in low gears in S+ and haven't been able to at all. Feels smoother in lower gears overall and more confidence inspiring knowing i wont look like i dont know how to drive my car as it bucks like a bull when i exit parking lots. So ask your dealer to do the tranny and fuel map updates. My dealer was Mercedes Benz Country Hills in Calgary, AB Canada if you need to reach out and ask them if your dealer gives you the run arounds.
My car is a 2017 Sedan. This is the only issue I had. No rattles, paint or finish issues or fitment defects that I have seen so far.
Hope this helps!
Old Nov 11, 2017 | 12:27 AM
tres55's Avatar
2018 C43
Thanks for the update. Will try taking my 2018 in to see if this resolves the issue.
Old Nov 11, 2017 | 02:06 AM
Dieseldan9's Avatar
2018 C43 AMG Brilliant Blue Metallic
I am having this same problem on my new c43. I will go to the dealer and see if I can get the updates.
Old Nov 11, 2017 | 01:35 PM
VCashmo's Avatar
2017 C43 Coupe
Thanks for the tip, I've been experiencing the same issue since I got my car but have been delaying going in because I wasn't sure there was a fix. Does anyone else have the code/SB number for the fix? So it was both an ECU and TCU update?
Old Nov 11, 2017 | 03:10 PM
hatata's Avatar
C43 AMG
The TCU update was supposedly the fix. The ECU was due to an update not directly related to the issue in their mind. But being in IT I am wary of making too many changes to anything because then I lose continuity of what the fix actually was. So.. I would hazard a guess that any one of those two updates or both may have been the fix in this case we will never know for sure.
Old Nov 14, 2017 | 11:52 AM
DameMD's Avatar
X3 M40i
Hope this helps!
Any chance you could ask your SA to send you an email with the correct TSB? It will be so helpful to have this as a sticky for others that are experiencing this issue.
Old Nov 14, 2017 | 02:09 PM
JR1330's Avatar
C63
Thanks for this post. Hoping to see the TSB.
Old Nov 14, 2017 | 02:11 PM
2017C43's Avatar
2017 AMG C43
Thank you for the post and hoping to see the TSB
Old Nov 14, 2017 | 03:10 PM
JR1330's Avatar
C63
I booked an appointment to address the "hop" on S+ at the Vancouver Terminal location after reading this thread. I wanted them to confirm that there is a software update and I provided my VIN.
The customer care center advisor/guest confirmed there is an update for my car and the one available is related to the "fuel map" so that is the one I'm going to get. I mentioned if there is a tranny software upgrade but she said only one was available based on my VIN.
My appointment is going to be on Dec. so its still awhile. Sorry she didn't tell me the TSB or any reference number so I will ask the service advisor when I get there.
Old Nov 14, 2017 | 10:12 PM
ecmexchange's Avatar
Former Vendor of MBWorld
na
Hmmm, hopefully it takes care of the problem once and for all.
Old Nov 15, 2017 | 12:37 PM
Star4life's Avatar
2017 C43 AMG
i just had my early build 2017 c43 in for updates and all glitches have been fixed with ecu remapping and update, tcu update, and all rattles fixed as well
Old Nov 15, 2017 | 07:24 PM
JR1330's Avatar
C63
Wow that's great news! Can't wait to get my update.
Old Nov 17, 2017 | 05:54 PM
ASH_C43's Avatar
AMG C43 sedan
Can you please share the TSB, ref number, or more info on the exact updates applied to the car?
Old Nov 18, 2017 | 11:02 AM
Lazz83's Avatar
2017 AMG C43, AWE Touring, BMC Air Filters- 2015 BMW X3 3.5i (JB1 Equipped)
Will there still be bunny hops in Sport + lower gears if you get an performance after market ECU tune?
Old Nov 18, 2017 | 11:35 AM
Gungaslow's Avatar
2017 C43 sedan
I have an AMR tune and I got it before any updates were available since I have an 8/2016 build c43 sedan.. I don’t notice any bunny hops with my tune..
Old Nov 18, 2017 | 03:41 PM
2017C43's Avatar
2017 AMG C43
Just had my C43 in today for the "A Service" and they did and update for the fuel system control and trans update. The TSB is GI27.00-P-062828.
Old Nov 18, 2017 | 05:48 PM
Gungaslow's Avatar
2017 C43 sedan
did you ask for the updates or did they do them automatically?
Old Nov 18, 2017 | 06:26 PM
2017C43's Avatar
2017 AMG C43
I asked and they added to the work order and they found a bulletin and updated the software.
Old Nov 20, 2017 | 09:46 AM
Star4life's Avatar
2017 C43 AMG
id have to look at receipt, but i just went in complained about the tranny hesistating at low gears when stopping and also hesistating at 5000 rpm +. The low end required a TCU update. I got the latest version. And the high end prompted a ecu fuel mapping etc update which i asssume is the fuel pump update part. pretty much you need to complain to get updates other wise they dont fix.
Old Nov 21, 2017 | 10:09 PM
na
Well that's kinda scummy...
Old Nov 21, 2017 | 11:01 PM
SkitsversuS's Avatar
2018 C43 Coupe
Just took delivery on my 18 c43 .. so far no hops but im only 200~ miles in. Prob got shipped with all the latest updates.
Old Nov 22, 2017 | 08:58 AM
Star4life's Avatar
2017 C43 AMG
first of all, i actually was getting bunny hops in 1st gear. so i wanted it taken care of. and sometimes upper end did feel sluggish. And the radio even after update still sucks, so i know its hardware at this point.
whats scummy is that mercedes doesnt apply software updates unless you complain. BMW you can go in and ask for updates no problem. I dont have to complain to apple to update my phone (for better or worse lol) they just push it out to me.
With cars that rely so heavily on software for functional AND safety features now a days, updates to the newest versions should be no hassle to get as each revision makes it better and safer.
Old Nov 22, 2017 | 09:01 AM
Star4life's Avatar
2017 C43 AMG
another note to add to this thread. I just put my 18" weels back on with stock run flats and sizes for the winter. there is a .3" difference in diameter between front and back stock, and what do you know, i got some 1st gear lurching and skipping again. On the 19s after update, nothing. I have 235 and 265 on the 19s which are within .1" of each other. I am wondering if under certain speeds with the delta speed between the stock front and rear wheel the computer doesnt know what to do.
do you guys with the oem 19s which have an identical tire diameter have this problem? or is it only guys with the 18s?
Old Nov 22, 2017 | 09:59 PM
na
I meant them being scummy, sorry. Wasn't saying you were.
Old Nov 30, 2017 | 11:25 AM
Lazz83's Avatar
I have the AMG 5 spoke 19" that came with the car, my build was in late December of 2016- No updates and my car bunny hopes like crazy in low gears in S+ though mine are stock diameter 225 and 255. Mine bunny hops so badly it will throw your head back into the headrest.
