C43 Tires
My C43 with about 11k miles already has very worn front tires. The back seem to be fine. I'm thinking of going with the Michelin PSS's for a replacement set, but still a little hesitant to go to non run flats since there is no spare. I was going to get a slime kit for emergencies however.
i hate the run flats because they are loud, harsh and have worn out way too fast. Are there any other runflats worth a crap? Or should I just go with the Michelin and not worry about the lack of a spare. I had the Michelins on my old C350 and was happy with them
Anyone else have these and what is your experience with them?
[see the video attached below]
Run-flat tires are essentially non-repairable (and more expensive, often horrible riding, noisy, have a shorter life, etc.). Had I kept the factory-installed run-flat tires, this event would likely have cost about $300 USD and taken at least a couple of hours because run-flats are expensive and it would likely have required a replacement/rebalance at a garage.
However, we don't use run-flat tires. I currently have on my nice new winter tires 'n rims. In preparing for a flat-ture event, I put two types of equipment in both our cars.
A "Slime" kit (paid about $65 USD each via Amazon). It involves injecting a fluid into the tire-stem then inflating the tire. The fluid then forms a temporary hole-plug so you can drive a few hundred miles. To me, this is a "last resort" because it does require that you dismount/clean/repair/remount/balance the tire within a short time/mileage after you've been saved by this. Apparently it's very messy to clean out, afterwards (it lives up to its name).
However, I also put a Dynaplug kit in our cars (paid about $35 USD each via Amazon). If you can find the hole, you can use this tool to insert a soft-rubber "sealing plug" into the hole. Since this puncture left an audibly-loud hissing hole, it was easy to locate and the Dynaplug tool nicely sealed the puncture. The Slime-kit pump re-inflated the tire and all was well. We weren't even very late getting to see the grandkids.
If you look at the Slime-kit picture, you may also notice that it has plugs, but their insertion tool is big and can damage the steel and other belts, especially in high-performance tires. The Dynaplug is much less likely to cause damage.
In my mind, the Slime kit would get used if you're "in a bad way" (pouring rain, stranded, middle of nowhere, etc.) and you're unable to locate the hole to Dynaplug it. Though, if you can't hear it leaking, it's likely the leak is slow enough that you could just stop when the pressure drops 10 psi, over-inflate a bit via the pump, then drive for another 20+ minutes while it deflates, again. Of course there's also the scenario where you get multiple punctures at once and exceed the number of Dynaplugs on-hand.
This event was "bad" in the way any flat-tire experience is not good, but (not having had a flat while travelling in over 20 years) it also served as a test of the equipment and a nice demo for my wife regarding what to do in such instances (of course, she says she knows what to do ... just call me or AMA).
Oh yeah, it was also "good" in that the cost of the flat-tire stuff for both cars ($65+$35 USD = $100 USD) has now "paid for itself" and paid a bonus, given that a run-flat tire replacement would have been a lot more. How's that for a glass/tire half full view!
Thanks in advance for the links.
[Slime's own site is pretty bad!]
I just got my TireRack delivery and not a minute too soon. My fronts are nearly bald and it's cold as a well diggers shovel here in NYC today.
I paid under $900, delivered, for these Michelin Pilot Sport a/s 3+. These seemed like the best all around for my use. I'm not tracking the car, and it will see snow.
TR even include a road hazard replacement for anything you may hit while driving that blows out your tires.
I haven't gotten to mount them just yet, but they are sitting here next to me in my office. Ahh, the smell of freshly vulcanized rubber in the air.
I just added that Dynaplug kit to my Amazon cart, because you never know. I've had the OEM runflats for a year and a half without catching a nail, but I'm certain I will get one as soon as I mount these and take a trip without a repair kit.
You guys do know that the slime kit will destroy the TPMS sensor, right?
Says so right on the bottle not for TPMS sensor vehicles...
