C450/C43 AMG
DIY: C43 Oil Change Step by Step Tutorial
Old Oct 12, 2022 | 07:51 PM
  #51
Darrington's Avatar
2015 C400
I’ve done my own oil changes annually since I got it back in 2016. This was the first year using the Mityvac. Best $100 spent!
I got almost 7, stone cold motor.
I love that you can put the rubber stopper at the end of the dipstick tube, and it sucks like a straw! Kudos to the forum for sharing that little tip!
Old Oct 14, 2022 | 06:17 PM
  #52
mcschan86's Avatar
C43 Coupe
I was wondering if anyone would still respond to this.
I can't get the Mityvac's here in Canada but saw lots of positive videos about them. I did use a more solid pump this time around and was surprised at ~7L extraction too.
The first time I did this was when I tried to extract it in cool weather (10C), totally clueless. The key is definitely warm up the oil and plug the dip stick hole with the rubber of the pump if possible.
Old Jun 6, 2023 | 09:47 AM
  #53
GermanCarShow's Avatar
2017 C43, 1966 230SL, 2006 Jeep Rubicon
Reviving this old thread for a tangent topic.
Is there any reason to use a magnetic oil drain plug in this modern engine? I believe the heads and block are aluminum, but is there any iron in cylinder sleeves, pistons, rings, bearings, valve train, cam shafts, crank shaft, etc?
Old Jun 6, 2023 | 10:24 AM
  #54
In addition to my above question, I also have the following questions.
- In this picture from above, does the seal ring (white arrow) getting oiled actually stretch around and fit into the large seal slot (red arrow)? That seems like a big stretch.
- Does a replacement small seal (yellow arrow) come with the filter kit?
- If you use the drain plug, is its washer a reusable one or is it a crush washer that needs replaced each oil change?
Old Jun 6, 2023 | 10:58 AM
  #55
I just called my dealership and they said the crush washer part number is 007 603 014 106. I'm used to working on older cars, this longer part number confused me at first! I also see a longer part number on the filter canister remover socket shown above, so I guess it's just normal now.
Old Jun 6, 2023 | 12:41 PM
  #56
Dammit, I'm answering a lot of my own questions today. I should have spent more time looking at the provided pics and at pics of parts for sale.
- The new filters clearly come with the plastic tower, including the small rubber seal at the tip.
- The filter canister (not the plastic on the filter) clearly has the groove for the large rubber seal. And, the pic I chose to focus on must have an optical illusion, as the seal looks right in the rest of the pics.
Old Jun 6, 2023 | 09:33 PM
  #57
W205C43PFL's Avatar
Wish I came across your questions sooner I would had answered them as I DIY my oil changes but glad you figured it out, for those who come across your post they might find it helpful so not a bad idea of posting your own findings.
Old Jun 8, 2023 | 08:19 AM
  #58
Any comment on the magnetic drain plug?
Old Jun 9, 2023 | 03:08 PM
  #59
RichardCranium3's Avatar
'16 AMG GTS, '21 AMG GLE53
Seal for red arrow location should come with the new filter.
As far as the magnetic plug, other than being out a few extra bucks, what could possibly be the harm in having the extra piece of mind? Schrodinger's Magnetic Drain Plug! Ideally it should never grab anything...but if it needed to, how else would you know?
Old Jun 10, 2023 | 08:36 AM
  #60
W205C43PFL's Avatar
Sorry I kept not being to reply timely, sorry about that. As for the magnetic drain plug like someone else mentioned, it is not a bad idea.
Old Jun 12, 2023 | 11:52 PM
  #61
Cosworth2000's Avatar
2022 E53 AMG
I have one and use it all the time. I just start using when the oil is really hot and it comes out so fast and you can see.
Old Aug 14, 2023 | 09:18 AM
  #62
Hey everyone. I finally did my first oil change. I'm doing my own following track days, just for added engine lifetime health. Still using dealer for scheduled maintenance. I used the topside MightyVac system. Yes, you should arrange the hose & plugs so that you're just putting the rubber stopper at the top of the dipstick tube. The dipstick tube runs to the bottom of the pan, so you don't have to put a hose inside the dipstick tube. After getting about 7L out, I went ahead and put the car on ramps and drained through the drain plug into an old water bottle. I got about 7 oz of oil out! So, this vac method using only the dispstick tube does not get it all out, but since I'll be doing a couple oil changes (track weekends) between scheduled changes, I think I'll keep doing the topside change.
I have not purchased a magnetic drain plug yet.
Old Aug 14, 2023 | 01:20 PM
  #63
Schrodinger's Magnetic Drain Plug is hilarious!
You would have to send off some oil for lab analysis. I've done that before on classic cars.
Old Aug 26, 2023 | 01:05 PM
  #64
W205C43PFL's Avatar
Got the magnetic drain plug yet? Anything to report?
Old Aug 28, 2023 | 02:33 PM
  #65
I did buy one the other day and will be doing another oil change soon (had a great track day at Mid-Ohio!). But it will probably be next year when I do another oil change and look at it. Also, I'm wondering what the most effective way is to keep the dealership from throwing away my special drain plug when they change my oil. Hummmm.....
Old Aug 31, 2023 | 09:04 AM
  #66
W205C43PFL's Avatar
Through DIY but I get it, you might not want to DIY.
Old Aug 31, 2023 | 11:28 AM
  #67
I'm continuing to use the dealership for scheduled service, I'm just doing additional things that relate to track use.
Old Aug 31, 2023 | 07:51 PM
  #68
W205C43PFL's Avatar
I see.
Old Sep 2, 2023 | 07:12 AM
  #69
C43Joe's Avatar
2019 C43
DIYers Keeping your receipts?
Curious if you DIY oil changers are keeping your receipts. If you are not, are you worried about resale value since a potential buyer may not believe you about the maintenance you have performed? I didn't go through with a purchase since the guy claimed he did his own oil changes, plus some other stuff, but didn't have the receipts to prove it.
Old Sep 2, 2023 | 09:52 AM
  #70
I don’t keep receipts, but I’ve recorded everything in the MB maintenance log booklet with dates, where I purchased parts, observations and general notes. If trading in, I’ve never found maintenance records to weigh too heavily (short of exotic tier)…different story for a private sale though obviously.
Old Sep 3, 2023 | 08:17 AM
  #71
If you're asking me personally, I am not keeping receipts of my work because as stated above I still have the dealership do scheduled maintenance.
Old Oct 30, 2023 | 08:41 PM
  #72
jhcole100's Avatar
c43
Great Post!!! Thank-You!
Would you happen to have posted on a Transmission Service by chance??
Old Feb 3, 2024 | 12:51 PM
  #73
BillinBama's Avatar
2020 C43 AMG
I'm in the middle of my change, when I removed the drain plug there was no washer, no leaks either. I'll see if I have a suitable copper washer but if not I'll install without it. Somebody either ran over road debris or ripped the panel to access the drain plug without removing the panel as it has a large chunk removed, jagged edges but I can see a ham-fisted mechanic using pliers to snip off chunks until enough was removed. I'll be ordering a new panel so if anyone has a good source other than the dealer please let me know.
Old Feb 5, 2024 | 07:58 AM
  #74
Prodbyjr's Avatar
2019 W205 C43 Sedan - Socials @Vip.C43
Is this the Mityvac everyone uses?
Amazon Amazon
Old Feb 5, 2024 | 09:29 AM
  #75
BillinBama's Avatar
2020 C43 AMG
I've never really considered using the Mity-Vac oil change suction unit, I've always drained my oil from the bottom of the pan. Recently all my Porsches and BMW's don't have dip sticks anyway(save for the Cayenne which didn't come with one but has a tube which I got a VW dipstick for). I guess I'm old school and like to get every bit of oil and the accompanying sludge that sits on the bottom out of the engine. Plus, I have a MaxJax midrise lift which I have to justify! To each his own, and there's nothing inherently wrong with sucking it out from the top. I've done it this way since I was in my early teens and can't stop now. I'm 75, btw.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
