C43 DME Tuned vs S4 Pulley, Intake, Tune
Subscribe
Dec 20, 2017 | 05:32 PM
We raced when I was stock and we were door to door...
Then raced again after a DME Tune.
https://www.youtube.com/watch?v=iBET9-x_4L4&feature=youtu.be
Reply 0
Dec 20, 2017 | 06:04 PM
You should try the C63 next.
Reply 0
Dec 20, 2017 | 08:33 PM
Hey Joey, what numbers did you put down? I was thinking of going with DME as well but went Eurocharge.
Reply 0
Dec 20, 2017 | 09:16 PM
Im curious as well, the website says theres a +33hp gain from their tune, which is really low for a remap. But the graph shoulds closer to +50hp?
Maybe the 400hp rating is at the wheels? Did you do any other tests? 0-60, 0-100, Dyno baseline vs tuned?
Reply 0
Dec 20, 2017 | 10:45 PM
Impressive to pull on a modded audi but more importantly what wheels and offset u running that fitment is strong
Reply 0
Dec 21, 2017 | 09:16 AM
Quote: You should try the C63 next.
Yes once the weather gets better here in NJ I will race the C63, then plan on tuning the C63 with DME also!
Reply 0
Dec 21, 2017 | 09:17 AM
Quote: Hey Joey, what numbers did you put down? I was thinking of going with DME as well but went Eurocharge.
I have their C43 Canned Tune, not a custom dyno tune. I will consider to get the custom tune next year.
Shoot me a DM if you need a contact from DME located in North NJ.
Reply 0
Dec 21, 2017 | 09:18 AM
Quote: Im curious as well, the website says theres a +33hp gain from their tune, which is really low for a remap. But the graph shoulds closer to +50hp?
All the drag strips are closed here, I will take it in April.
Reply 0
Explore
Dec 21, 2017 | 09:21 AM
Quote: Impressive to pull on a modded audi but more importantly what wheels and offset u running that fitment is strong
S63 AMG Replicas, 5x112 19x8.5 & 19x9.5 with 15 MM spacers all around from ECS.
Reply 0
Dec 21, 2017 | 05:41 PM
No I believe it is 400hp at the crank. This flash from DME is claimed to produce 400 hp and 430ish tq. It probably only equates to a 20 whp gain from stock which would explain the slight win by the tune Mercedes. I believe OP mentioned he ran the car stock and was neck and neck.
A proper flash and it would be bus lengths from the Audi, based on what OP claimed was stock, and now that we see a bench flash.
Reply 1
Dec 21, 2017 | 09:07 PM
Quote: No I believe it is 400hp at the crank. This flash from DME is claimed to produce 400 hp and 430ish tq. It probably only equates to a 20 whp gain from stock which would explain the slight win by the tune Mercedes. I believe OP mentioned he ran the car stock and was neck and neck.
Wow...how much was this tune then? Those numbers are number you'd expect to see from like an conservative entry level piggyback or something, not a full remap.
Reply 0
Dec 21, 2017 | 11:16 PM
Quote: Wow...how much was this tune then? Those numbers are number you'd expect to see from like an conservative entry level piggyback or something, not a full remap.
This is what I was wondering. I thought that both races were going to be on the video and at first, I was thinking I was watching the stock 43 against the S4 lol. Suffice to say, I was a bit confused when the vid ended until I realized that was a "tuned" 43. I'm not familiar with this DME company but I hope that this tune wasn't more than the ~$300 piggy-backs. I would feel OK with spending $300 for 30-40whp but anything higher and I would feel robbed!
Reply 0
Dec 22, 2017 | 08:41 AM
That makes pretty good sense to me, IMO.
That's a B8 s4, last generation, and they ran low 12's with mods of that nature. Most tuned C43's are running low 12's...
Reply 0
Dec 22, 2017 | 08:19 PM
That's not what we're pointing out. It's the fact that he stated they were "neck and neck" when the 43 was stock, and now that it's been tuned, he's only pulling 3-4 car lengths on him. That's a pretty weak power increase for a tune. Like I said earlier, it would be fine if it was a $200-300 piggy-back, but I'm guessing that is not the case...? IDK
Reply 0
Subscribe
Currently Active Users (1)
