C450/C43 AMG
Exhaust Flap Module
Old Mar 19, 2019 | 01:24 PM
  #51
SirJmon's Avatar
2019 C43 AMG
I noticed with the 2019 face lifted car the PE is quieter until you hit around 3500-4k. I love the sound and the volume from that rpm to redline. I would love it if this module helped in those lower rpms. Does anyone with the 2019 have it installed and does it help?
Old Mar 19, 2019 | 10:10 PM
  #52
jonathan358's Avatar
2018 Mercedes C43 AMG Coupe
Now that it is Spring, I really want to hop on this but it is just too damn expensive for a simple on/off switch.. $450 CAD to hold open the flaps?!?
ASR, give us a group buy, I am sure we can get at least 5 members on board!
Old Mar 20, 2019 | 07:29 PM
  #53
SirJmon's Avatar
2019 C43 AMG
Also, does this work for the sedan as well?
Old Mar 20, 2019 | 08:45 PM
  #54
CClement's Avatar
2009 C230
Ya works as long as you have the PE, I have it on my sedan, one of the simplest mods out there, worth it 100% if you ask me.
Old Mar 20, 2019 | 09:04 PM
  #55
SirJmon's Avatar
2019 C43 AMG
Did I read correctly, the facelifted(2019) c43 have a different one than the one posted?
https://asr-component.de/startseite/...1_mit_schieber
Old Mar 21, 2019 | 01:54 AM
  #56
waisoserious's Avatar
GLC43, X P100D, S P100D, CT200H
Would you guys believe that my car didnt have the PE, so i had to fit an aftermarket exhaust. But I got tired of always having to fiddle with the on/off remote (also the low rpm drone when the valves are open at 1500rpm was insane) so I had to separately buy an OBDII valve controller so the valves would open at a certain RPM?
Basically the exact opposite of you guys lol.
Old Mar 21, 2019 | 02:08 AM
  #57
matt pun's Avatar
C43 AMG
Same here. I retrofitted the PE but want it be quiet sometimes.
Old Mar 21, 2019 | 02:13 AM
  #58
The low rpm drone was so bad i ended up driving with the exhaust off half the time. And pressing the button became too much trouble after a few weeks. Felt like I was "trying too hard" if that makes any sense.
Sounds great above 4k rpm though. The OBDII automatic controller makes the exhaust 10x more enjoyable imo.
Old May 29, 2019 | 10:04 AM
  #59
jfromthenorth's Avatar
c43
I'm a bit late to the party here, but I had a quick exhaust question for you. I just picked up a new 2019 c43 and regarding the exhaust, I find it doesn't pop/crackle nearly as much as the 2016-2018 model. Granted I need to break her in so i'm keeping in under 4k rpm, but still, even in S+ with PE open (against dealer recommendation, but hell, I need to test the damn thing) I'm seeing virtually no pops, and when it does, they are barely noticeable. Did you experience anything similar by any chance?
Old May 29, 2019 | 10:37 AM
  #60
c43
Old May 29, 2019 | 09:04 PM
  #61
Dieseldan9's Avatar
2018 C43 AMG Brilliant Blue Metallic
I have read but I can not confirm but there might be a filter in exhaust muffling the pops and bangs.
The module will increase the sounds of the bangs because it opens the flaps fully
Old May 29, 2019 | 09:34 PM
  #62
Silverbird's Avatar
2019 C43 Wagon
Hang in there - I just passed the 1,500km mark yesterday. break in complete.
When I picked it up, I had the same thoughts, but there was a marked change in the exhaust (even <4,500 RPM) at the ~800km mark. I noticed the pops, bangs, and burble picked up a ton.
Also keep in mind that it needs the revs up a bit to pull off those tricks; even in S+ it's pretty civil <2,000 RPM.
Dang is it fun now though. the sound is awesome.
Old May 30, 2019 | 11:58 AM
  #63
c43
Well that's definitely reassuring. Thanks for sharing. I'm only at 150kms over here, so 1500 seemed like forever just to find out I was going to remain disappointed. Now at least with your feedback I can cruise through June knowing the best is yet to come.
Old May 31, 2019 | 01:21 PM
  #64
SirJmon's Avatar
2019 C43 AMG
As others have said, yes, it will pick up once you can open it up. I don't get many cracks and pops until around 3500 and higher. Above 4k rpm it gets pretty crazy.
The flap module was a nice little upgrade. Once above 4k the module isn't doing anything because the flaps are open 100% stock anyways. Where it helps is below 4k and start ups.
Old May 31, 2019 | 01:50 PM
  #65
AMGiggity's Avatar
nothing
Is there a similar option for C43s without PE, so it is always loud regardless of driving mode?
Old May 31, 2019 | 05:43 PM
  #66
SirJmon's Avatar
2019 C43 AMG
Unfortunately, no.
Old Dec 28, 2020 | 12:04 PM
  #67
Patapii's Avatar
C43
Hi. I hope it is not too for me to join this discussion. I recently retrofitted the PE exhaust by purchasing from Germany. The problem now I face is that the flaps cannot be closed because they have no connection with the central console, notwithstanding it is what I want to make the retrofitted works simple. Sometimes I found it is too loud when I need a quiet cruising after work. Does this ASR component solve my problem?
From their website, ASR can close the flaps by using comfort mode(number 2 on the remote). So it's possible but you need to provide a power supply to the ASR module, also wires from ASR to the flap servos on both mufflers.
Old Dec 29, 2020 | 08:49 AM
  #68
CClement's Avatar
2009 C230
I'm assuming since you retro-fitted the PE exhaust, you would have all the components of the PE exhaust, just without the button on the center console.
If that's the case then the ASR should work fine. There are 3 settings on the ASR module. Fully open, fully closed and stock setup so yes, you can close
them as you wish at a push of a button. But as the post above says, this assumes that the power is there. Everything is in the module that is under
the bottom of the trunk. ASR just plugs directly into there, it's a 2-minute install.
Old Feb 20, 2021 | 11:38 AM
  #69
lkfwong's Avatar
2019 AMG C43
Hi - If the center console PE button is off/disabled, and ASR remote is set to 100% open, would the valve be 100% open?
I am trying to understand the dependency on the center console PE button being on or off.
Thanks,
Old Feb 20, 2021 | 02:54 PM
  #70
skim7x's Avatar
Mercedes-Benz E63s AMG
Thanks,
Interior button doesn't make a difference. Valves so whatever ASR module tells them to do unless you have the valve module in disabled mode
Old Jan 29, 2023 | 10:13 AM
  #71
JonnyM's Avatar
2019 c63s
Originally Posted by Star4life
once i have my module for my other business done, I can recode it and add the correct plugs and can get these to you guys for under $200 USD easy. and it will be us based
hey bud I was wondering if there’s anything you have so far I’m in Australia and man to get these here are super expensive and don’t know what the best option is
Old Jan 29, 2023 | 10:23 AM
  #72
JonnyM's Avatar
2019 c63s
hey you meantioned OBD2 controller ? Where can I find and how much if it’s worth it
Old Aug 23, 2023 | 02:47 PM
  #73
jhcole100's Avatar
c43
Can anyone pls tell me how to order from ASR? Their website is in German and I cannot seem to get thru their check-out process? tia
Old Aug 23, 2023 | 03:10 PM
  #74
skim7x's Avatar
Someone can correct me if I'm wrong, but I believe ASR sells exclusively through renntech for 10 times the price now... I would recommend going Cete route IMHO. It's more seamless integration but does requiring hardwiring into a car module and is more difficult to reverse. But also it's much less expensive since it doesn't have the renntech tax
Old Aug 23, 2023 | 03:14 PM
  #75
jhcole100's Avatar
c43
Okay, I get it now! I was trying to buy it at the less expensive price! Thank you!
