C450/C43 AMG
C43 Brake Issue!!!!
Old Mar 9, 2018 | 01:56 AM
w205_C43's Avatar
Mercedes AMG GT 2020
C43 Brake Issue!!!!
I've had my car for about three months now. I've put 3300 miles so far and I'm starting to hear my brakes squeak. Anyone having the same problem? What should I do?
Old Mar 9, 2018 | 04:20 AM
Dieseldan9's Avatar
2018 C43 AMG Brilliant Blue Metallic
Not sure if same issue but my brakes started squeaking and I gave the calipers and rotor area a good power wash and cleaning and it solved the problem.
Old Mar 9, 2018 | 08:56 AM
Standingoten's Avatar
C450
Read my thread about the same issue on my C450. No fix for it. They even changed pads and rotors.
Old Mar 9, 2018 | 08:57 AM
RichardCranium3's Avatar
'16 AMG GTS, '21 AMG GLE53
It's not uncommon. There are several posts/threads about this. Unless you're feeling something odd in the pedal, are hearing grinding noises, or are getting a light on the dash, nothing to worry about. Somewhat typical on performance oriented brakes.
Old Mar 9, 2018 | 02:45 PM
Star4life's Avatar
2017 C43 AMG
side effects of performance brakes.
Old Mar 11, 2018 | 07:08 PM
Cosworth2000's Avatar
2022 E53 AMG
My C450 did it also. Mercedes changed it under warranty and it never happened again.
Old Mar 13, 2018 | 04:19 AM
w205_C43's Avatar
I just didn't expect this to happen with the car at 3K miles. Couple days have passed by and it went away. Hopefully, its resolved.
Old Mar 13, 2018 | 09:07 PM
C43Ayemgee's Avatar
2018 C43 AMG
I think you're fine, My brakes were squeaking the first week, and occasionally they do (i only have 1600 miles). Like someone said, its the only side effect of performance brakes.
Unless you hear and feel a grinding noise then its time to change them.
Old Mar 14, 2018 | 04:46 PM
Ownly's Avatar
C43
FYI, brakes are fully warrantied for 2 years. Even if you use them up, they'll change them before 24 months.
Since they're AMG brakes, the procedure requires a road test and post-test verification so they may keep the car for two days.
Old Mar 15, 2018 | 12:28 AM
FirstMBAMG's Avatar
C43 AMG Coupe
Same issue comes up every so often. I wrote a post that someone responded to but typically for new cars with performance brakes there is a bedding process for the brakes in order to break them in, helps them squeal less.
Perhaps you can dig up those old post and find the person who responded.
Old Mar 17, 2018 | 07:48 PM
Dieseldan9's Avatar
Is that for all cars or do I have to have a maitnence plan?
Old Mar 17, 2018 | 09:34 PM
Ownly's Avatar
C43
I don’t know about base models but all AMG cars have brakes under standard warranty for the first 24 months. That being said, I only know this about Canadian cars. Warranty in other countries may be different.
