Performance Exhaust Retrofit complete
If you see my reaction and thought I was offended, then reading your post again tells me that you truly were offended since this guy's opinion on what exhaust to put on his car, differs from yours. I mean I wasn't "offended" in the slightest. But using your very own logic, apparently you are. Sorry to learn that a complete stranger adding an exhaust has the ability to affect you on a personal level like that.
I guess I should ask OP.
2021 Mercedes C63s AMG Coupe
But the PE has far better built quality than any of the aftermarket options by a long mile.
Yes there are part numbers for individual sections. Mid pipe, taile pipe, mufflers and such. And you are right, they aren't cheap. The only reason this one was cheap because it was coming from a donor in a junky. How many C43s equipped with PE can you find in the junkyards? We probably don't even have one.
I did not check with mercedes about buying the parts from them. here is a pic of one of the mufflers that has a part number on it.
If you cant get the numbers im happy to drive my car on ramps and get all the part numbers, just shoot me a message. The bracket that was different was not stamped from what i saw.
Nice thread. Thanks for sharing!
Spaggettio (07-09-2018)
Hi Alexasa,
#32
#33
Nice post. I do have a question about the hoodup of the module that you got from the donor car. How did you connect it to get power and did you install the button also?
I have a C450 and purchased the Armytrix exhaust with valve control but I leave the value open all the time. I can see from your pictures that the Armytrix and the PE look a like with the large center pipe. I think the only big difference is the weight as the Armytrix center pipe is titanium which makes it very lite in weight. On the other hand, this is a great write-up as I also had a guy who purchased my C450 Exhaust for his C400 and noticed a difference in sound. No cracks or pops but a deep rubble and louder startups including louder revvs even during high speeds. He was very pleased that the C450 Exhaust made a difference on his C400. If you had purchased the C43 PE it would have cost you $1200USD so getting is for cheap is a good step.
Also we need write-ups like this as a Auto Enthusiast forum so there should be no haters here. Many would be scared to take the step this guy did for fear they will loose money. Further to that, he shared his experience for others who were thinking the same thing. "Maybe I should have purchased the PE when I bought my C43". I think everyone should purchase the PE when they purchase the C43 AMG. For me, I wanted more sound from my C450 as I loss some sound with the Lorinser Tune however Lorinser recommended that I change my exhaust to a better breathing exhaust for maximum hp.
Great work and thanks for sharing.
Retrorog (12-09-2023)
#34
I didnt end up hooking up the power button or the valve controller in the boot. For the power button, you need to replace the center console and have it programmed which MB would not do. The wiring for the valve controller in the boot is "stitched" into the main loom also, i took one look and thought im just going to bolt it up and cross my fingers it sounds the same. The valves are open all the time which makes startup louder. The sound characteristics of my car is the same as my friends with factory PE, my car is louder at lower RPM and make more pops etc at lower RPM. For 1200AUD I got lucky.
Cosworth2000 (11-26-2018)
#37
2019 AMG C43 Sedan
https://www.mercedesvin.com/
NJC63Fan (02-12-2019)
#39
#41
i already have the AWE touring exhaust, could i just buy the PE computer module and plug it in? The AWE is exactly like the PE exhaust but without the flaps. I'll have to figure out how to trick the PE module into thinking the flaps are open
#42
#43
Hi guys. I am from Hong Kong with non PE C43. I think I might be the only one in this forum retrofitted the PE exhaust by purchasing it from MB factory in Germany. Yes, my local garage helped to order the PE and installed it for me. Installation was a easy job. I finally picked up the car today and as said by Spaggettio, it transforms the car at all. When I first drove, the car feels strange to me because its sound super aggressive, the pops and bangs are really sharp. I kept watching the youtube for PE C43 for whole year and should already have had feel about it. But in reality, it likes 3 times louder than what I expected. The sound and pattern is exactly the same as those in youtube shotting PE C43.
Actually, I would like to point out that, even the sound is amazing by now, I quite miss the quiet mode because in low rpm, even if in ECO mode, there is some drone. However, my garage said they cannot straightly adopt the market switch to turn it on and off. Seems the motor mounted on the PE exhaust requires a computer to operate rather than simply direct control. So, I hope is there anyone have some knowledge about this and recommend a way forward. Thank you guys!
BHawk (12-04-2022)
#44
Great work on being able to order it. Have you heard the PE exhaust from a car that came with it from factory? I was also very surprised when I heard my friends car which he order the PE from factory it was very loud for a stock car, you can not judge by videos. This is why it is MB made it quieter in the new facelift model.
The gear changes and pop and bang you have would be the same volume as a factory fitted car. The exhaust is a little bit louder low RPM because valve always open you can not do anything about it as it very difficult to try to retrofit the valve controller and button etc.
Also it will get louder if you get an ECU tune.
Hope this helps
#45
#47
Hi Matt,
Hope this helps
Hope this helps
My garage is asking the supplier in Germany to see if there is any handy device be able to do the switch. I will keep you guys update.
CA400 (03-16-2019)
#48
To the OP, thanks for a great write up on the U78 Switchable Exhaust retrofit.
You mentioned the following:
What other points and observations would you include in that list?
Do you find that there was any valve opening relationship with respect to Throttle Position, or just RPM? Possibly your point number 4 has WOT taken into consideration.
Can we assume that in point number 4, below 4000rpm is just as quiet as Comfort mode and is also 30% opening from idle to 4000rpm, or is it louder at idle than Comfort?
You did not mention your observation in Sports mode (non +).
I have worked on and designed a similar controller for a mid-90's Porsche 993 Varioram intake manifold retrofit with a lot of success, so I do see some potential in this as a project. It had 3 intake manifold valves that worked as a function of, and opened at various stages of, RPM and/or Throttle Position.
Would be great to develop a logic/truth table for the behaviour and program a controller, so if you could give me more input that would be great!
- When car is off valves are open
- When car is started valves automatically close after 3 seconds or so
- When in comfort with exhaust button on valve open 30% or so
- When in sports + with exhaust button on valves open 100+ after 4000 RPM and full load and are variable at other RPMS
#49
Hi Alexasa,
#50
This is great information as i'm thinking not getting the PE option added to the vehicle I'm looking to spec out tomorrow for a 2020 MY order.
