C450/C43 AMG
Performance Exhaust Retrofit complete
Old 07-19-2019, 08:08 PM
  #51
TModelle's Avatar
C190
Originally Posted by Conv_GSDriver
This is great information as i'm thinking not getting the PE option added to the vehicle I'm looking to spec out tomorrow for a 2020 MY order.
It is much cheaper to spec the PE from factory than to retrofit it later.
Old 07-19-2019, 08:12 PM
  #52
Conv_GSDriver's Avatar
'18 Audi A4
I posted elsewhere but my question was is this worth it? it doesn't seem to add HP/TQ over non PE equipped models, its basically to regulate the sound? looking at ordering one tomorrow and originally had that as option but from what I can read from the merc site it does not seem to add gains other than the sound part. that is what i'm trying to verify or is there more to it than just that?
Old 07-20-2019, 07:36 AM
  #53
Spaggettio's Avatar
C43 AMG
Yes it is just sound but it transforms the car. basically crazy not to spec it
Old 08-11-2019, 09:09 AM
  #54
Olly21's Avatar
c43
Quick question
Originally Posted by Spaggettio
Hi All,
First of all i would like to say thanks to a few members who helped adding their 2 cents were possible, you know who you are.
Long story short I impulse bought my car over an RS3 for a great price and didnt check the options on the car. After some time realised i need more sound and power from it. Added a racechip (hate on it if you want) which added performance gains. Started looking into exhausts and found that nothing really matches the sound of the PE in the aftermarket options.
By no means am I a mechanic or tuner this is just what I learnt about how PE cars operate the exhaust.
  • Mercedes will not retrofit this and you will see why
  • When car is off valves are open
  • When car is started valves automatically close after 3 seconds or so
  • When in comfort with exhaust button on valve open 30% or so
  • When in sports + with exhaust button on valves open 100+ after 4000 RPM and full load and are variable at other RPMS
  • There is a controller in the boot that controls these valves
  • All the characteristics of the PE exhaust are driven by the exhaust and valve controller
  • I contacted some tuners here in sydney and they said "we cant see a difference in the base map between car with and without PE"
Luckily for me there was this wrecked c43 amg with the PE as option.
After alot of discussions with other members and google research the theory was that most of the aspects of the PE exhaust i.e cracks on gear changes and burbles, pops and bangs were from ECU and a little from the exhaust. No hard evidence just theory.
The first idea was to get everything from this wrecked car.
Wiring + connectors
Special valve box thingy?
I soon came to realise the loom is "stitched"? into the main loom.
So i bit the bullet and bought the exhaust, I was ok if the car just sounded a little deeper but really was chasing the characteristics of a PE optioned car POP bang crack whatever you call it.
Difference in exhaust from cat back to muffler left side AMG right side standard sports exhaust. MAKE SURE YOU GET BRACKETS FROM PE OPTIONED CAR OR WILL BE FABBING SOME UP.
All bolted up first start in Sport+
https://youtu.be/GAPCxaT67zg
First drive not knowing what the outcome was going to be, I was very happy with the result
https://youtu.be/GeAnVjbUCgw
Warm eco startup at home trying not to **** of my heavily pregnant wife or neighbours
https://www.youtube.com/watch?v=IraAaDgpE2s
Driving around like a goose
https://youtu.be/UtxqAXIHan8
Tunnel
https://youtu.be/O9O3xAcilcQ
In summary, this has transformed the car. There is no drone on the motorway with the valves always open. Met with a friend earlier tonight and we drove both cars (his car has PE from factory). We could not notice any difference in exhaust note or power between the two cars (all done by butt dyno no dragy or cool tools available).
Ive had quite a few messages on the facebook page and just hope this helps whoever the next guy is thats trying to figure all this out.
Dave
Appreciate this thread is a year or so old but did you also purchase the mufflers?
I’m looking to do the same thing and am interested to know if it was just the centre pipe and cat back section or the mufflers as well? As far as im aware the mufflers are also different?
Thanks for such a great write up!! 👍
Olly
Old 08-12-2019, 07:38 PM
  #55
Spaggettio's Avatar
C43 AMG
Olly
Hi There,
Yes everything from the cat converters back. Midpipe and mufflers
Old 08-22-2019, 02:27 AM
  #56
Ben Wild's Avatar
C43 AMG
Part Numbers
Hey Spaggettio,
first of all I would like to thank you for showing all of us, how the retrofit is made and whats needed. I think that helps a lot of C43 AMG drivers all around the globe.
Now I am doing the same as you did, but I only got the rear-end mufflers without the H-pipe thingy. I wanted to weld them onto the standard U21 mid-pipe.
What misses, is all the electrical stuff... ECU, wirings and button. I found out the following part numbers with your post and on other pages:
Button for center console: A2059057009
ECU in the trunk: A2059000227
What I wanted to know now: Are there any part-numbers for the wiring/loom between the electrical stuff? In my opinion you need a wiring from the ECU to the button in the front and a wiring from the ECU to the motors of the exhaust-flaps. Please correct me if I'm wrong.
Furthermore, did you do the coding of the U78 by yourself, or did you have an expert who did this for you?
It would be awesome if you could help me here, because I don't want to make something wrong.
Thank you in advance!
Old 08-23-2019, 06:26 PM
  #57
Spaggettio's Avatar
C43 AMG
Originally Posted by Ben Wild
Hey Spaggettio,
Hey ben,
Sorry didnt see this reply. I also messaged you on FB as i saw your other post.
I looked to add the valve controller and button. The issue was that I was told by MB specialist that the whole loom in the car is different part number. It does not plug into the valve controller and then plug into another connector. It goes from the valve controller and stitches into the main loom. This is why MB will never retrofit for you. You would have to rewire the whole car and then have a MB specialist do the coding. Too hard so i just bolted it up and it sounds the same as if you had PE from factory with the valves open all the time.
I would suggest you get the mid pipe because I dont know if its going to sound the same with the single mid pipe? Also another thing is that you will have to slightly bend the heatshield under the car or also replace that.
Thanks!
Old 12-15-2019, 02:02 PM
  #58
David Barrett's Avatar
C43 2019
Hey ben,
Thanks!
Did a solution to this ever turn up i.e. a different way of remote controlling the flaps?
I am looking at getting a retrofit PE Exhaust rather than go third party but worried that at some point I might want the car in quiet mode and have to get under it with a stick to manually close them.
Old 05-18-2020, 11:33 PM
  #59
stockbmw's Avatar
2018 C43
Anyone know what material OEM AMG performance exhaust is made of?
Old 05-19-2020, 12:14 AM
  #60
TModelle's Avatar
C190
Stainless steel.
stockbmw (05-19-2020)
Old 11-14-2020, 07:34 PM
  #61
Trekt43's Avatar
C43
Did you ever identify these parts numbers TModelle? They're ellusive
Old 11-21-2021, 09:44 PM
  #62
f.majdalz's Avatar
2015 C400 ( W205 )
Any one knows if a C63 cat back exhaust can fit on C400 ?
C400 exhaust is like the non PE 2017 C43 .. it has 2 resonaters.
I dont need the valvetronic thing. I'm fine with it open all the time if it works.
​​​​​​Please see below.
Old 11-21-2021, 10:31 PM
  #63
anomen's Avatar
2017 C43 Coupe
I imagine you could make fitment work having a local exhaust shop trim/adjust for you. Its sound quality that I couldn't guarantee.
Old 11-22-2021, 12:25 AM
  #64
Trekt43's Avatar
C43
I did this, at least with the c63s mid-pipe to a set of c43 performance exhaust mufflers. The front end (part that connects to downpipes) of the mid-pipe 100% has to be cut. You'll have to take the front tips from your c43 mid-pipe, cut them, cut the front part of the c63 mid-pipe, and weld them. You also have to weld a new hanger hook to the midpipe. From memory the c43 perf mufflers were a direct fit to the c63 midpipe.
If you were going to go with c63 mufflers too, I know it has been done. A guy posted a vid of it on facebook. It sounded decent (obviously c63 exhaust does not make the car sound like a c63... just so we're all clear). Personally I think the c43 mufflers are key. The extra h pipe on the 63 mid-pipe gave my c43 a more v8 sound (again, nothing like the c63) bout only at idle, almost like it was cammed, at revs it sounded more like the stock perf exhaust but louder and a little less organized without that muffler on the mid-pipe (which I believe contains an x-pipe in it).
f.majdalz (11-22-2021)
Old 11-22-2021, 12:35 AM
  #65
f.majdalz's Avatar
2015 C400 ( W205 )
Thanks for sharing your experience, the reason why I'm asking because the market is full C63 exhaust but you find nothing for the C43, i believe the C43 one like you mentioned will be plug n play.
I was hoping i can find this set ( the one on left ) with mufflers :
But I'm not finding any... I'm not looking to get a C63 sound .. i know we can't it's V8 vs V6 but I'm just trying to enhance my setup, I'm already tuned but the car sounds like aprius 🤣🤣.
Old 11-22-2021, 03:22 PM
  #66
SilverBullet18's Avatar
C450,GLC 63,VW GTI
I know its a bit pricey but get yourself the L.E.M Performance exhaust replica and you'l get the best of both words.
Old 11-22-2021, 04:31 PM
  #67
Darrington's Avatar
2015 C400
Some great details in this thread.
I’m thinking about cheapin’ out, just replacing the mufflers with some dynomax super turbos.
https://www.dynomax.com/mufflers/sup..._diameter1=155
Old 11-22-2021, 04:38 PM
  #68
C450,GLC 63,VW GTI
Or do the bmw rear box mod. You'll keep the internal resonators in place and have a rear straight pipe. (No drone)
Darrington (11-22-2021)
Old 11-22-2021, 07:40 PM
  #69
C43HeartBoost's Avatar
C43
I can confirm from hearing Trekt43’s exhaust in person, it sounded great IMO.
Old 11-26-2021, 09:35 AM
  #70
ttapposs's Avatar
W205 C43 AMG
Bro can we have the AMG Performance Exhaust system part number to see if its possible to order it?
Can it be ordered from a mercedes retailer? Also did you install the exhaust button on your console also?
Old 11-26-2021, 10:06 AM
  #71
C450,GLC 63,VW GTI
Its about 1300-1500 per muffler (you need 2)
1500 for the midpipe
And 250 about for the brackets.
You cannot add the button because you need to program it. along with the kristonics sound module to control the whole setup..
So that puts you at 4,100 +without tax or shipping.
I rode along in a Car with a PE retrofit and honestly you don't need the valves controlled. It's pretty tame with basically no drone in the highway with everything open.
Its very expensive to get from the dealer brand new.
Old 11-26-2021, 10:17 AM
  #72
ttapposs's Avatar
W205 C43 AMG
So what can i do instead of purchasing it from the retailer. I have imported the car and it arrived today.
I decoded online the VIN of the car and it mentioned sports exhaust system and i wrongly thought that this was the AMG PE.
So now im a bit dissapointed as i really wanted the car with AMG PE.
Old 11-26-2021, 10:26 AM
  #73
C450,GLC 63,VW GTI
Other than purchasing everything from the dealer, you can try to find one used online. But its difficult as it's pretty rare and prices are around 3000+ for the set (remember you have to pay shipping as well).
The closest thing in the after market is the Logos Engineering Motorworks PE-Replica which I'm currently running. It's louder than the PE (OEM PE has 2.5" piping and the Logos PER has 2.75") but also has the same tone as the original PE.
It has electronic valves so you can close them for an extra quiet ride.
Old 04-14-2023, 02:13 AM
  #74
hrcalx's Avatar
C43 amg
Does anyone have the resonator from a Performance exhaust for sale?
Old 04-15-2023, 07:09 AM
  #75
W205C43PFL's Avatar
Received 2,453 Likes on 2,088 Posts
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Not mine but someone listed it for sale yesterday: https://mbworld.org/forums/market/839284
Quick Reply: Performance Exhaust Retrofit complete
