Downpipes loosing power.
2021 Mercedes C63s AMG Coupe
Guys, there is a general consensus that downpipes for this car looses power. It has been seen multiple times on the dyno previously that using the same tune (tuning file contains the same boost curve), minus the tuner shutting off the CEL, the car made around 10hp less with downpipes, which is ofcourse counter intuitive.
Now I have some guesses why this happens. I know the car keeps track of exhaust manifold pressure/ flow, so when it experiences a flow that is beyond the calibration limits, the ECU might cut some timing reducing the power.
Now EC has gone past this problem as they are making more power now using downpipes and same boost curve (we can check boost curve of an EC tune using an OBD dongle, so we know the boost curve looks the same). So obviously they have figured out how to get past this issue, but for competitive reasons they kind of would not share how they did it, obviously.
What I am asking is, may be one of the guys here knows what can be manipulated to get past this issue? It was hinted that it can be done manipulating the wastegate valve position.
It's possible, yes. Especially when no adjustments to the tune is made. Happens all the time when N/A cars put exhausts on their cars but don't tune for it and end up losing power. But you really shouldn't lose top end power, should just affect low end torque.
Are there any back to back dyno's when they added changes to account for downpipes?
^^^This.... Which is why I haven't installed my downpipes yet as I am waiting for BMS to allow access to other parameters/functions of the Jb4. If downpipes are anything like headers, for my G37S coupe and sedan I had to retune once headers were installed because I definitely felt the loss of low-end torque. I keep telling people that I don't think downpipes on our car are just plug and play. You may be loosing power because the ECU is trying to adapt for the extra air flow. You will get the noise and sound form the DP but you may be running to rich or lean if you don't make any tune adjustments for them. I do 90% mostly city driving and I definitely do not want to lose my low-end torque.
Definitely curious to see about this as I have a set of downpipes sitting at home now but have yet to install them as these issues are making me weary.
Do they only lose power when doing a generic tune, or when dyno tuned as well? If someone’s doing a custom dyno tune then I would presume they wouldn’t still lose power right? Or has this not been tried yet?
