JB4 Firmware update 0-60 Results
The following 2 users liked this post by HTXgearhead:
AMG C43 3LV6 (11-11-2018),
RichardCranium3 (11-12-2018)
The following 2 users liked this post by luka43:
Doubletap99 (06-25-2019),
MaverickC43 (01-28-2022)
#57
what Size tires and rims ? Do I need 18s? Or can I accomplish the same with 19s? Gotta little confused cause some dude at the top of the forrum said u need 18 in forged wheels or something to achieve those numbers. Do u have an IG by any chance ??
#58
Tires will make as much, or more of a difference, based on grip and launch ability. A set of wider or stickier tires will be a more efficient way to add a tiny bit of performance, both in a straight line and laterally, than any wheel change.
But to answer your question: No you don't need 18s to make similar performance numbers.
#60
so what else can I add other than the jb4 and e30 to see low 3.1 or 3.2 0-60 times ? Would Water meth injection help ? Would downpipes ? Can I even pair downpipes with the jb4 ? And can I still run map 2 if I’m mixing 91 octane and e85 to make e30. There’s no 93 in cali
#63
#64
Terry gave out a firmware upgrade few days ago. Pretty consistent results now in map 7. I am sure I can hit much lower when I fiddle my own map. But overall the car has gotten much more stronger since the update. Pretty sure I can improve my previous time with this. Will be pretty sweet to finally get into 11.4s by spending just 800 canadian dollars (500USD haha). Trap might suffer a bit, car has much better low end now.
PS: The time at the bottom are my stock times without JB4. I should also add that my car is pretty lowered (H&R sport springs is giving different heights to different people). So I have some excessive camber issues, (around -3.5), which really does not help with grip. Also my car is running on 19"s, which some of tuner's best times are not set on (usually super light 18s).
#65
JB4 Map Guide as of v6 firmware:
Map 0: Disables tuner
Map 1: Up to 4psi over stock peak, suitable for all 91 octane+ fuels
Map 2: Up to 5psi over stock peak, suggested for 93octane+
Map 3: Up to 5.5psi over stock peak, slightly more aggressive version of map2
Map 4: Up to 6psi over stock peak, suggested for E30+ or unleaded race gas mixtures
Map 5: Up to 7psi over stock peak, holding more boost to redline, suggested for E30+ or unleaded race gas mixtures
Map 6: User definable map, boost over stock entered on user adjustment page
Map 7: WMI (water/meth injection) progressive map for BMS FSB integration
Map 8: Low boost VALET map
#66
What mods will u be doing to the m340 to get it to the low 3s 0-60?
I don’t think it’s that much quicker than c43
im not c43 fan boy, it’s a great car and I love it but has its issues.
it seems to run faster times than listed in some articles
the fl top speed limiter sucks!!!
