2018 C43 18 AMG wheels offsets
I'm looking to buy a 2018 C43 wheels and tires.
I saw couple of pics for 245/40/R18, but couldn't find the information for the other tires yet from the seller.
However, The model wheels 661 5-spoke wheels with black accents, what would be the offset values? I want to use them on my 2014 E350 4Matic
Please help with this info. TIA.
https://mbworld.org/forums/c450-c43-...ent-guide.html
from current stock setup 245/45/17x8.5j (probably) to code 661 above:
front:
Compared to your existing wheel, this new wheel will have an inner rim which is 27.7mm further away from the suspension strut. The outer rim will poke out 2.3mm more than before.
rear:
Compared to your existing wheel, this new wheel will have an inner rim which is 1mm closer to the suspension strut. The outer rim will poke out 1mm less than before.
with this setup above, will it hurt the vehicle?
front:
rear:
