C450/C43 AMG
C43 2017 Wont crank/won't start!
Old Oct 23, 2018 | 12:56 AM
JohnC43amg's Avatar
C43amg Year2017
Angry C43 2017 Wont crank/won't start!
Hi Guys
I am very new to the site. I bought a C43 2017 brand new 8 months ago running fine till the last couple of days ago.
so far twice happened when starting the Engine it won't crank or do anything.
then I waited a min then try again the engine starts fine.
I haven't phoned the dealer yet. but does anyone experience this issue?
Please help..
Thanks in advance.
John
Old Oct 23, 2018 | 01:12 AM
waisoserious's Avatar
GLC43, X P100D, S P100D, CT200H
Originally Posted by JohnC43amg
Hi Guys
Please help..
Thanks in advance.
John
Maybe you should have phoned the dealer first?
Is the battery dead? Does it make any sounds? Does it sound like the engine is choking or just silence?
Old Oct 23, 2018 | 01:49 AM
JohnC43amg's Avatar
C43amg Year2017
When I hit the start button the dashboard lights come on but Engine is silence.
then I wait after 30 seconds and try again then Engine starts ok.
I don't understand what this could be..
Old Oct 23, 2018 | 02:09 AM
AMG C43 3LV6's Avatar
AMG C43 3LV6
Dont need to understand what it is, take it immediately to the dealer its still under warranty.
Old Oct 23, 2018 | 03:06 AM
MarcusDubya77's Avatar
Veteran: Army
19 C43 Coupe, XC 60
Sounds like an ECU fault of some sort.
Old Oct 23, 2018 | 03:11 AM
guhvies's Avatar
2017 C43 AMG Saloon
Dumb question, but is your brake pedal fully pressed in when hit the button to start?
Old Oct 23, 2018 | 08:15 AM
JohnC43amg's Avatar
C43amg Year2017
yes good point ,when you press the brake pedal it is fully pressed.
Old Oct 23, 2018 | 08:26 AM
sieglo's Avatar
TBD
There's no such thing as a dumb question on this board.
Old Oct 24, 2018 | 01:06 PM
Abohunu's Avatar
W205 C250 2016
Actually if you press START and right away you depress the break pedal the engine will stop. For some reason the ECU will stop the ignition process if you don't wait a few seconds after the pressing START + break.
Old Oct 24, 2018 | 06:23 PM
jonathan358's Avatar
2018 Mercedes C43 AMG Coupe
Yeah, like others have said, just make sure you depress fully. It's sensitive like that...
And for me, an intermediate-length full press of ignition, never hold or quickly release the button.
Old Nov 2, 2018 | 11:11 PM
Tirgoman's Avatar
2023 AMG EQE 53
I would bet it a Mis-adjusted brake light switch or the car has lost some vacuum. The brakes use engine vacuum and if it sits when you press the brake peddle it's not enough to activate the brake light switch so the ECU tells the engine e to crank, safety thing. Try really pressing hard and if it cranks go to the dealer and have him find the vacuum leak or adjust the brake light switch. My wife's MB had this problem
Old Nov 2, 2018 | 11:29 PM
HTXgearhead's Avatar
2018 C43 sedan
Yes there is.
https://mbworld.org/forums/c-class-w...k-what-do.html
Old Nov 3, 2018 | 12:13 PM
CA400's Avatar
C400
Originally Posted by HTXgearhead
HAHAHAHA
Old Nov 3, 2018 | 12:17 PM
CA400's Avatar
C400
I agree with making sure the brake pedal is fully engaged. Also is the key inside the car fully? I sometimes am in a hurry and just stick my right foot in to press the break pedal and reach for the start button while the key is in my left pocket. The car doesn't read the key until I sit and put my left leg in. I do this when I run out to warm the car up.
Just a though!
Alex
