Active Sound???
Here is the original retrofit thread:
https://mbworld.org/forums/c450-c43-...-complete.html
What is true though is that the exhaust button turns on a switch that tells the ecu to start retarding ignition timing to create the pops and bangs. It also opens the valves to let the exhaust gases escape more freely (and louder).
The ECU being related to the burbles and backfire is 500% correct and widely known. Since it is directly related to the fuel trim which is controlled by the ECU. Everybody should have known this without even investigating.
When I installed my vivid tuning box I had to plug into fuel sensor. I lost all pops and bangs and I have the PE.
The speaker **** is garbage the car is all real sounds
When I took off the vivid the car sounds the same again
However, as noted by a few posters who have done some work on the audio system, the AMG's have "Engine Sound Control Unit" wiring to the amp, that is not present in the non AMG cars. The AMG cars' amps are branded AMG (why else would the amp be different for AMG and non AMG cars) User @gunnysack posted when he redid the audio system and had an error, he could hear noises coming from the speakers, with the volume all the way down, only in sport mode or on heavy throttle in comfort mode. He rectified this with some firmware updates on his new equipment, but it is clear that there are some signals going through the audio system relating to throttle and mode.
I don't have definitive proof, and I can't distinguish noises from the speakers while I'm driving, but the AMG specific amp and "Engine Sound Control Unit" is at least circumstantial evidence of some artificial noise.
