AMG C43 Rear Brakes
Thanks,
Theflynkd
Then while you have the pads off you can compress the piston.
They are tight fitting some times, but I usually find that if the caliper is not just right, the parking brake actuator will be against the upper slide mount and cause it to be slightly angled. This will cause binding while trying to place the caliper over the pads.
If moving the actuator around and verifying it isn't touching the caliper bracket, I sometimes just place the piston against the inner pad and compress the piston (squeezing with my hands) until there is just enough clearance to slide on. After it's on, it usually moves freely and makes you think "why the..."
Be sure to 'EXIT FITTING POSITION' in the instrument cluster afterwards.
Good luck and there really isn't any tricks to this.
How do I access fitting mode in my 2020 c43 AMG to retract the rear calipers.
