C450/C43 AMG
2019 Mercedes-Benz C43 AMG: In-House Initial Testing Results
Old Jan 17, 2019 | 09:24 AM
AMR Performance's Avatar
Former Vendor of MBWorld
18 MB E63S AMG - 17 MB C43 AMG - Much more!
Talking 2019 Mercedes-Benz C43 AMG: In-House Initial Testing Results
Source: https://shop.amrperformance.com/2019...-benz-c43-amg/
TOPIC:
The new 2019 Mercedes-Benz C43 AMG 4-Matic comes with the 3.0L BiTurbo V6 engine that we have been accustomed to in its pre-19 C43 AMG vehicles. However, the new model comes with a new face-lift consisting of a new designed grille, revised front bumper, revised rear bumper, a new wheel design and some changes to the interior as well, giving the vehicle a new look. With the "new look" comes some changes to power. The new model has a bump in power from the advertised 2017-2018 models at est. 367hp to a new est. 385hp.
Were did this power increase come from?
This new power has created quite the buzz. From speculation of larger turbochargers to just adjustments made to the vehicles ECU software. AMR Performance engineers were able to take a deeper look into the vehicle's ECU logic and mapping as some data acquisition (data logging) done in-house on our DynoJet 424xLC2 dyno.
What did the 2019 Mercedes-Benz C43 AMG do on our dyno?
After multiple vehicle runs, we were able to get an average peak power of 321whp (power at the wheels) and 332wtq (torque at the wheels). Solid numbers for a stock Mercedes-Benz 3.0L BiTurbo vehicle.
How does this power plot compare to the previous model?
The question that everyone is asking. So lets overlay the stock 2019 Mercedes-Benz C43 AMG power plot over the 2018 Mercedes-Benz C43 AMG.
2019 Mercedes-Benz C43 AMG Peak Numbers: 321whp (power at the wheels) / 332wtq (torque at the wheels)
2018 Mercedes-Benz C43 AMG Peak Numbers: 308whp (power at the wheels) / 330wtq (torque at the wheels)
As you can see from the power plot above, the 2019 Mercedes-Benz C43 AMG pumps out an addition +13whp (power at the wheels) and +2wtq (torque at the wheels) over the previous model.
Were did the additional power come from?
Mercedes-AMG had tweeted a while back that "...both vehicles use the same turbocharger system just a different state of tuning. However, the new face-lift model gained additional performance thanks to a higher charge pressure".
The statement made by Mercedes-Benz, was in fact, accurate! We monitored boost readings directly from the intake manifold after the throttle body giving us a direct reading as to what the motor is seeing. The 2019 Mercedes-Benz C43 AMG saw 13psi were as the previous model (2017-2018) Mercedes-Benz C43 AMG saw 11psi.
Our engineers monitored the ECU's data acquisition as well as evaluated the ECU's mapping which showed very small changes to ignition timing and fueling but nothing major enough cause a power effect giving the true statement that the BOOST increase was giving factor to the additional power gains.
More results to come. Stay tuned!
Last edited by AMR Performance; Jan 17, 2019 at 05:15 PM. Reason: added more graphs
Old Jan 17, 2019 | 10:06 AM
Dieseldan9's Avatar
2018 C43 AMG Brilliant Blue Metallic
well that settles that now doesn't it
what I find strange is the lower numbers of HP and TQ of the 2019 in the beginning of the rev range.
It "looks" like they are using a bigger turbo aka lag but they are not, strange.
I am surprised they did this as the 18s low end grunt and TQ is one of the best things of this car
Old Jan 17, 2019 | 10:16 AM
alexasa's Avatar
c
So you'll be able to tune the power curve to match the low end torque from the 2018, right? or at least similar?
Are they using higher quality compressor wheels/bearings for reliability at the higher power numbers?
Old Jan 17, 2019 | 01:38 PM
MVEOVR's Avatar
2019 AMG C43 Sedan
Thanks for this! I was just thinking how these would compare on a dyno the other day.
Old Jan 17, 2019 | 03:30 PM
sieglo's Avatar
TBD
Yeah the 2019 curves quite frankly don't look as good as the 2018s. Somewhat disturbing. MB playing games.
Old Jan 17, 2019 | 03:33 PM
alexasa's Avatar
c
Or AMR is incompetent. I'll be interested in seeing other results.
Old Jan 17, 2019 | 03:44 PM
sieglo's Avatar
TBD
Well I've owned both a pre-facelift coupe and now a 2019. I'm at 965 miles, so I'll be able to post my "butt-dyno" results soon enough.
Old Jan 17, 2019 | 03:51 PM
GuardianVA's Avatar
'19 C43
Granted those charts may not be scaled correctly, but am I the only one that noticed the torque and HP don't cross at 5252 for either graph on the 2019 vs 2018....
Old Jan 17, 2019 | 07:58 PM
waisoserious's Avatar
GLC43, X P100D, S P100D, CT200H
Well I hate to say I told you so. But I told you so.
Old Jan 17, 2019 | 08:02 PM
Bro....its the same....Benz is not going to dedicate time and resources to 20bhp for the same product cycle that is ending in 1.5 years when they can just increase the boost.
Old Jan 17, 2019 | 08:16 PM
sieglo's Avatar
TBD
Does seem a bit hard to believe that the 2019 doesn’t develop full boost until 3600 RPM.
Not only that, but the torque indicator in the AMG menu of my car hits ~375 ft lbs (measured at the crank presumably) under less than full acceleration at pretty low RPM. Maybe the data from that gauge is just BS, but it definitely doesn’t jibe.
Old Jan 17, 2019 | 09:26 PM
https://mbworld.org/forums/c450-c43-...ml#post7564593
