C450/C43 AMG
Front/Rear tire size difference
Old Mar 28, 2019 | 12:10 PM
CClement's Avatar
2009 C230
Hey guys, I know the OEM 19s have about a 0.23% size difference between front (225/40/19) and rear (255/35/19)
which is obviously acceptable by MB specs but I'm wondering what % difference starts to be a problem with our AWDs?
I'm looking at front/rear combo that has about 1.07% difference so 0.85% more difference than OEM. Any thoughts?
That's still quite a small difference however thought I'd see what people thought. Thanks.
Old Mar 28, 2019 | 03:57 PM
mjs1190's Avatar
2018 Mercedes AMG C43 (sold), 2025 GLC63s Coupe
The dealer mistakenly but C63 tires on my car 245/35/19 and 265/35/19 which works out to a 1.92% difference which is obviously more than yours. However, it was enough for it to throw off the wheel speed sensors that impacts the traction control and cause the engine to cut power when on flat roads and driving normally. The car would be undrivable for a few miles and then would be fine. When they swapped back to the OE tire size, that issue never resurfaced.
Old Mar 28, 2019 | 03:59 PM
CClement's Avatar
2009 C230
Ya, almost double what I would be but surprised to hear how bad that was. Thanks!!
Old Mar 28, 2019 | 04:04 PM
alexasa's Avatar
c
visually/aesthetically that wouldn't be ideal IMO. But nobody would probably notice. It would bug me though.
Old Mar 28, 2019 | 04:07 PM
CClement's Avatar
2009 C230
The reason I'm asking is that I run 8.5" rims all around for my summers. I need new tires this summer (Pilot Sport S4)
and my current OEM Pirellis run a bit of a stretch in the front, they work but definitely a bit stretched.
If I went 245/35/19 front and 255/35/19 rear, the look would be much improved!
Old Mar 28, 2019 | 04:16 PM
alexasa's Avatar
c
You don't think you can pull off a square set-up with the offset? That'd be my move.
Old Mar 28, 2019 | 04:18 PM
CClement's Avatar
2009 C230
Ya, that is another option, go 255/35/19 all around. Might work well actually. Thanks!
Old Mar 28, 2019 | 08:53 PM
mo11's Avatar
2017 C43
That’s the same size I run up front currently, 255/35 19 Michelin Ps4s on 19x8.5 +30, it’s fine for as long as you’re ok with how close the clearance is from the control arm.
My first setup had a 2.75% f/r ratio, never gave me any problems even at over 100mph speeds. From what I’ve read, for as long as f/r ratio is within 3% you shouldn’t have any issues.
Old Mar 28, 2019 | 09:04 PM
CClement's Avatar
2009 C230
Ok thanks, I might try the square setup.
Old Mar 29, 2019 | 04:48 AM
hlieberg's Avatar
2018 AMG C43 T
I recently read about this on some Norwegian website. For Mercedes I'm pretty sure the 4wd-system allows up to 5% difference in wheel ratio between f/r axle. I was surprised, because I know 4wd-systems on some other brands don't allow any difference at all.
Old Mar 29, 2019 | 08:04 AM
CClement's Avatar
2009 C230
Ya I was told anything under 3% should be ok but then the post above had me concerned. 5% seems like alot but who knows, the dealership doesn't seem to.
Old Mar 29, 2019 | 08:19 AM
hlieberg's Avatar
2018 AMG C43 T
Yes, I also thought 5% seems like a lot. I think it was someone from the official MB importer who said it. I have tried to find the article again without luck. Not that it would help you as it is in Norwegian, but to see if I remember correctly.
Old Mar 29, 2019 | 05:04 PM
CClement's Avatar
2009 C230
My dealership says anything around the 1% is no worry but that's one heck of a difference from the 5%!!
Seems to be alot of different info out there.
