C450/C43 AMG
H&R VTFs Creaking / popping noise from passenger rear
Old Jul 19, 2019 | 02:32 PM
alexasa's Avatar
c
Originally Posted by munis
Just got it done yesterday.
All fronts -2.5, rear driver is at -.275 except rear passenger which sits at -3. As there is no adjustment possible I am stuck with this. Don't know how bad these numbers are. May be you guys can chime in. My height is maxed out in the rear, and 35mm higher that the lowest position in the front. Ride quality so far feels fantastic.
exactly why i went KW - rear has much better adjustability. i​​​​​​​'d probably lower the rear dri​​​​​​​ver to match. i​​​​​​​ can't seem to get accurate measurements no matter how hard i​​​​​​​ try - whi​​​​​​​ch mi​​​​​​​ght be what's happeni​​​​​​​ng i​​​​​​​n your si​​​​​​​tuati​​​​​​​on
everyti​​​​​​​me i​​​​​​​ measure ri​​​​​​​de hei​​​​​​​ght i​​​​​​​t's a bi​​​​​​​t di​​​​​​​fferent because of uneven ground.
Old Jul 19, 2019 | 02:35 PM
alexasa's Avatar
c
Originally Posted by mo11
Ok, thanks!
I’m still on h&r springs, if I remember right my fronts are -2.1° and rears are -2.0°. I did have my alignment guy pull both rear lower arms in by grinding the elongated hole.
It’s been holding up well last time I checked. I’ll probably go with kmac camber kits if I decide to switch to vtf’s.
btw. my camber was -2.2 front and -3.2 rear
Old Jul 19, 2019 | 04:47 PM
mo11's Avatar
2017 C43
Thanks, Alexasa... not to hijack this thread, but are you planning to get camber kits for the rear?
Old Jul 19, 2019 | 05:07 PM
munis's Avatar
2021 Mercedes C63s AMG Coupe
I was talking about my camber previously. Dunno if you though those were the drop in inches haha. I have - 2.5 on the front and -3 in the rear. My previous set of PS4S only lasted 12000km with tons of inside wear.
Old Jul 19, 2019 | 06:14 PM
mo11's Avatar
2017 C43
Those 12,000km included some track days, right?
Old Jul 19, 2019 | 06:26 PM
alexasa's Avatar
c
check toe too then
Old Jul 22, 2019 | 10:55 AM
  #32
munis's Avatar
check toe too then
Toe is good after alignment. I am actually facing a very strange issue. May be you might be able to chime in.
When I am getting on an inclined pavement from the street at an angle, as in turing into a steep pavement (does not happen over the the normal ones) I am heard a metal on metal scraping sound when getting on the surface. I got off the car and checked what just happened. And looked like my passenger front wheel was fully loaded (compressed) and extremely tucked in, while my driver front and passenger rear was completely off the ground, with rear driver also compressed, the front passenger side being the most compressed though. I have a 5mm spacer in the front making a resultant ET of 30 with a 8.5J front wheel. Never had this issue before the H&R sport springs even though the car sat lower than it is currently. It is almost like the current springs have been cut short, so it pulls the tire off the ground much sooner than before, I dunno if that makes sense. But the thing that bothered me was the scraping sound, I have heard it before when the inner side of my wheel was hitting the suspension knuckle over the its very characteristic bump.
I have lifted the car off when I put the spacer in and there was a good a 3 to 4mm space between the wheel and the suspension knuckle at its tightest point. I verified this is the gap while the tire was on a flat surface (loaded wheels) during alignment. Is it technically possible for this gap to decrease when one tire gets compressed a lot? Cause ever since I got the spacer, I have never heard the wheels rubbing the inner knuckle ever. Super weird.
I guess I have to extra careful getting into inclided surfaces going forward. But I Have no idea what else I can do, cause my steering was pointing completely straight while I heard this sound, so it definitely was not my tires rubbing on the inner fender. Also my traction control light came on while I was trying to go over the surface. Probably because one of the tires were freely spinning.
Old Jul 22, 2019 | 11:07 AM
  #33
alexasa's Avatar
c
are the springs in this VTF setup stiffer than the lowering springs? that metal sound might be the springs hitting each other - many times they put a sheathing on them to reduce this (as seen below in clear surrounding the springs).
fronts on the HAS setup also have helper springs - are those suppled with the VTF and were they installed? (sometimes people leave these out to get a lower set-up)
helper springs
Old Jul 22, 2019 | 01:56 PM
  #34
munis's Avatar
helper springs
The springs are not stiffer for sure as the car feels more compliant overall and much more comfortable. I do not think the H&R comes with with that small spring in the buttom in the fronts.
Old Jul 23, 2019 | 02:40 PM
  #35
TModelle's Avatar
C190
Originally Posted by Sethseb
I thought so. Thanks for your help. I'm going to instal my VTF on Monday with SFG Autohaus. If you don't mind, how much did you lower yours?
Could you take a pic of the VTF spring set so that we can have a photo reference for the future. When I get my KW HAS set, I will post a photo here. That way, in the future, anyone can compare the two offerings before buying.
In my search for adjustable springs for the C43, most of the websites selling VTF and HAS only show stock photos of their product and not the actual C43 kits.
So I think it would be great to actually be able to see them.
I’m getting my HAS kit in about a months time, because Germany is out of stock at the moment and they have to be produced.
Old Jul 23, 2019 | 03:07 PM
  #36
alexasa's Avatar
c
i'd be happy to supply a picture of the HAS - i've adjusted the height about 7 times now lol
i have these for now:
Old Jul 23, 2019 | 08:52 PM
  #37
Sethseb's Avatar
2018 c43 amg
I didn't get a chance to take a picture of my VTF but here's a picture I had before that I downloaded from one of the suppliers.
The ride is the same compared to the stock springs. So far, I love it. I will be putting my 20 inch rims in the next 2 weeks and might have to adjust the height.
Old Jul 23, 2019 | 08:53 PM
  #38
TModelle's Avatar
C190
Thanks!
Old Jul 23, 2019 | 08:55 PM
  #39
TModelle's Avatar
C190
Very often rather than not, the pictures on retailers website are just stock photos. Sometimes they even state that the photo may not be of the model that your purchasing. Are you certain that’s what your set looks like?
  #40
Sethseb's Avatar
2018 c43 amg
I wrote it in the post above. Also kevin knows. Tell him lower mine the same as the blue C43 you did.
Thanks for your help. Got it installed yesterday and I love the drop. Same height as yours. Kevin and his team did an amazing job. We might have to adjust it after I install the 20 inch rims.
Old Jul 23, 2019 | 10:56 PM
  #41
Sethseb's Avatar
2018 c43 amg
Yes
Old Jul 24, 2019 | 01:37 AM
  #42
TModelle's Avatar
C190
Yes
Someone earlier mentioned that there is no helper spring in the front, while your picture shows that there are 4 helper springs. I think that’s just a stock photo and might not be the same.
Old Jul 24, 2019 | 01:11 PM
  #43
munis's Avatar
No problem! 20 inch rim is a bit too much in my opinion. But each to their own. Which rims are you going with?
Old Jul 24, 2019 | 01:12 PM
  #44
munis's Avatar
I do not think my set had those small black springs.
Old Jul 24, 2019 | 01:59 PM
  #45
munis's Avatar
Actually I need to verify if my setup has helper springs or not. The absence of helper springs will explain my problems:
https://raceland.com/news/springs-10...er-spring.html
@Sethseb Can you pm me your phone number, We can verify this together then. Should have gone with the HAS. Damn it.
Old Jul 24, 2019 | 02:20 PM
  #46
alexasa's Avatar
c
thus why i asked. helper springs are great for full droop situations. But they can also be "built" in with a more condensed coil section.
i'm not sure if VTF is supposed to have them or not - or if they have them built in to the primary spring.
Old Jul 24, 2019 | 02:38 PM
  #47
munis's Avatar
I am confirming this in a bit. Just got off the phone with my distributor. They told me there is supposed to be 4 helper spring that is supposed to come with the setup. May be they missed it for mine? Or I do have them, but I cannot see where they are for the life of me.
Old Aug 3, 2019 | 10:40 PM
  #48
Sethseb's Avatar
2018 c43 amg
Savini BM14 brushed silver. I'll post some pix.
Old Aug 3, 2019 | 10:46 PM
  #49
Sethseb's Avatar
2018 c43 amg
100% sure.
Old Aug 4, 2019 | 02:04 AM
  #50
TModelle's Avatar
C190
It’s a shame they don’t make them for Estate or Cabriolet.
