C450/C43 AMG
2017 c43 amg awd front strut replacement
Old Jul 20, 2019 | 07:08 PM
parksteven10's Avatar
2017 c43 amg
hey im working on my 2017 C43 Amg I want to change the springs out but I cant seem to get the front struts out does anyone know the procedure to removing the front struts was able to separate strut from top but the lower arm gets in my way how should I go about this ? also the back springs look easy just remove or loosen the lower arm and the spring should slide out but im having issues with the front if you guys could help me out that would be appreciated don't feel like paying 300$ for someone else to do it when I know I can do it just need a lil hint and ill be omw
Old Jul 20, 2019 | 07:26 PM
TModelle's Avatar
C190
Maybe this will help?
It’s for the air spring strut version, but the procedure should be similar.
Old Jul 20, 2019 | 07:34 PM
2017 c43 amg
that just might work I originally dismissed this video when I found it on youtube cuz its air suspension and not awd but tbh it looks like it just might work thank you
Old Jul 20, 2019 | 07:43 PM
ItalianJoe1's Avatar
2003 CL 600
Same basic steps for coil/air and FWD/AWD. Parts may look a little different but the work is the same. Be careful with that upper control arm nut, it's thin and easy to slip off of. I ground down one side of a box wrench to ensure I didn't smash any fenders taking them off.
Old Jul 20, 2019 | 07:49 PM
2017 c43 amg
nice thanks guys for the help will finish up on Monday and let everyone know how it goes
