C450/C43 AMG
Does the C43 , pre FL or FL have fake interior speaker engine noise?
Old 07-23-2019, 09:00 AM
AMGiggity's Avatar
nothing
Originally Posted by RichardCranium3
Confirmed by two separate owners in the C43/450/400 general WhatsApp chat that removing fuse 424 in the trunk panel makes an impact on cabin exhaust noise. Call it whatever you want, but the cars makes additional noise through the speakers to enhance the exhaust sound in the cabin with PE.
Edit: Also want to point out that this hasn't been confirmed with non-PE cars as far as I'm aware. I'm non-PE, so I'll test over lunch today and report back.
You done with your lunch? I have the non-PE and curious if speakers pump engine sound into cabin.
Old 07-23-2019, 09:01 AM
Conv_GSDriver's Avatar
'18 Audi A4
Well, after driving one equipped with it, I played with the windows, bringing them up and down. It would be difficult for an audio system in a car to, other than super high end stuff, to fake the inflection in sound when the cabin seal is broken.
Old 07-23-2019, 09:03 AM
TModelle's Avatar
C190
I’m non-PE too and 2019 Estate model, I tried to locate that fuse and found that I don’t have that fuse, so I couldn’t try.
'18 Audi A4
Yes that's a long lunch. I want that job.
Old 07-23-2019, 09:06 AM
'18 Audi A4
Also hope that fuse is not the one that powers the baffles to open or close cause that will definitely have an impact on sound by not opening or closing.
Old 07-23-2019, 09:13 AM
TModelle's Avatar
C190
The flaps are run by a separate controller and is separate from that fuse.
However, I’m not entirely sure yet if the 2019 have that fuse.
Conv_GSDriver (07-23-2019)
Old 07-23-2019, 12:34 PM
  #32
gcurnew's Avatar
C43 lol
The fuse box in the trunk is different on my 2019 C43 with PE.
As you can see in the images, there are 3 fuses "assigned" to the Sound System (471, 473, 483) with only one installed in my car the 40A 473.
Trunk fuses in 2019 C43 with PE
Fuses related to Sound System
Location of Sound System fuses
Old 07-23-2019, 01:34 PM
  #33
TModelle's Avatar
C190
Coupe, Cab, Sedan or Estate?
Old 07-23-2019, 01:39 PM
  #34
gcurnew's Avatar
C43 lol
Coupe.
Old 07-23-2019, 01:41 PM
  #35
RichardCranium3's Avatar
'19 CLS450
Finally back from lunch
I wanted to drive around for a day to make sure I was actually hearing what I was hearing and it was not just in my head. I made several 8 stops over the last 24hrs, each time pulling or replacing the fuse for the next leg of the trip so I had some immediate comparisons on the same or similar road conditions. All driving was done in S+, manual mode, and suspension in comfort (how I typically drive). I have a fairly high level of confidence there is some sort of audio intervention happening. Immediate reactions upon pulling the fuse at lunch yesterday was an increase in overall road/wind noise, significantly more prominent initial turbo spool/whistle noise, and a noticeably quieter low/mid-RPM roll out. The bottom half of the RPM range is significantly quieter on casual acceleration. Low RPM-full throttle/boost, and top half of the band are seemingly unchanged.
I looked back on the feedback in the WhatsApp chat from the people with PE that did this same exercise and they had similar experiences, only a bit more heightened since the PE is physically different as well.
TL;DR - Back to back comparison, fuse in = more engine hum/drone in cabin at lower RPMs; fuse out = elevated but calm road noise, quieter under driving Mrs Daisy conditions staying in bottom half of RPMs, whistlier/twirlier turbo intake noises, no change in WOT conditions.
Old 07-23-2019, 01:52 PM
  #36
TModelle's Avatar
C190
Is yours a 2019 model, or pre-FL? Cos there are two of us here so far with 2019 models without that fuse and the fuse box is diffferent.
Old 07-23-2019, 01:56 PM
  #37
'19 CLS450
2017 sedan
Old 07-23-2019, 02:01 PM
  #38
TModelle's Avatar
C190
So it seems the 2019 model doesn’t have that fuse for both PE and non-PE equipped versions. Perhaps the FL model doesn’t have piped in sound after all. This all good and new info, I’d say. It’s a good thing this thread was started and the OP asked a good question, otherwise we’d have never known.
Old 07-23-2019, 02:20 PM
  #39
alexasa's Avatar
c
Does the FL coupe/cab have it?
Old 07-23-2019, 02:22 PM
  #40
TModelle's Avatar
C190
According to one of the posts above, 2019 Coupe with PE does not have the fuse.
Old 07-23-2019, 02:24 PM
  #41
TModelle's Avatar
C190
Originally Posted by gcurnew
Coupe.
Good info. Thanks!
Old 07-23-2019, 04:44 PM
  #42
SirJmon's Avatar
2019 C43 AMG
I have a 2019 sedan and no fuse either.
I'm pretty confident there is no sound coming from my speakers.
Old 07-23-2019, 08:03 PM
  #43
evoi19's Avatar
Current: 2019 C43 Old: 2016 C450
Chill out Francis...jesus
RichardCranium3 (07-24-2019)
Old 07-24-2019, 09:24 AM
  #44
TModelle's Avatar
C190
I think we've pretty much confirmed now that the 2019 FL model doesn't have the sound generator fuse whether PE or non-PE.
The following 3 users liked this post by TModelle:
buco (07-24-2019), gcurnew (07-24-2019), PFEAMG (07-24-2019)
Old 07-24-2019, 02:30 PM
  #45
AhEmGee's Avatar
2004 E55 K Wagon &. '96 SL500
I have very acute hearing and was certain this was the case. Thanks to all for checking.
Old 07-24-2019, 02:44 PM
  #46
netboy's Avatar
2003 C320 coupe/c450 in Feb 2016
does open the driver door while stating S+ mode make the speaker sound output louder? haha
sometime i want to hear the exhaust, i start my C450 on S+ mode while driver door is opened, the sound is louder compare to door and windows is closed.
Old 07-26-2019, 03:12 PM
  #47
AMGiggity's Avatar
nothing
Maybe already answered but does anyone know why car sounds louder in S and S+ especially S+ (coupe, non PE)? I am almost certain speakers are playing a role.
Old 07-26-2019, 03:29 PM
  #48
gcurnew's Avatar
C43 lol
Do you have a 2019 or a pre-FL C43?
Old 07-27-2019, 11:15 AM
  #49
'19 CLS450
I’ll still say, with a degree of caution, it could be the synthetic noise is amped up a bit in S/S+, but it’s also important to realize that idle varies depending on mode as well. The additional +/- 200rpms in S+ will inherently make more noise than Comfort/slippery/eco.
Old 07-27-2019, 11:22 AM
  #50
TModelle's Avatar
C190
My 2019 Estate non-PE sounds exactly the same in Comfort, Sport or Sport+. It’s an extremely quiet car in any setting or RPM. Only the shifting program seems to change, RPMs are held higher as you go up to Sport+. That, and maybe some throttle pedal sensitivity.
eatmydust (12-01-2020)
Quick Reply: Does the C43 , pre FL or FL have fake interior speaker engine noise?
