Does the C43 , pre FL or FL have fake interior speaker engine noise?
"The powerful sound of a Mercedes-AMG is an unmistakable signature, from its snarling startup growl to its assertive throaty rumble as its unleashes its power. Computer-controlled vanes near the tailpipes of the AMG exhaust system also let the driver escalate its sound at the push of a button, while the system's free-flow design delivers an audible celebration of power with every upshift, downshift and rev."
So if you have this option installed, its just basically opening and closing baffles to either enhance or mute the sound. I remember reading an article a while ago about this but can't find it now. Since it is an AMG tuned only engine, maybe the exhaust portion is also tuned by them in a similar manner.
The rear mufflers with integrated flaps are of the same design as the ones on the C63, minus the center flap in the front section of the C63.
Obviously the extra practicality too.
I'm sure they'd sell well In the US, don't see the logic of selling them in Canada and not US.
not the exhaust system. It controls the muffler flaps. The wires go from the control unit to the muffler flaps. Are you saying that the same control module controls flap angle and outputs audio?
Good luck when you change the Audio System in your C43 and suddenly your ears are getting BLASTED away by the speakers
Have fun using Google: A2059006226 , A 205 900 69 28
Edit: Also want to point out that this hasn't been confirmed with non-PE cars as far as I'm aware. I'm non-PE, so I'll test over lunch today and report back.
On Cabriolet and Coupe there is a control unit specifically for PE. I discovered this after Malar pointed it out. However, on Sedan and Estate, the control unit Specific to PE is not there. There is a sound generator, but I don’t think one can conclusively say it’s exhaust sound being piped into the sound system in Sedan and Estate. Maybe noise cancelling? But it’s confirmed that Coupe and Cabriolet have a PE sound generator.
1) C43 all variants have a Sound Generator Control Unit.
2) Only C43 Cabriolet and Coupe additionally have a Switchable Exhaust U78 Sound Generator and only if equipped with option B63 it has a Engine Noise Over Speaker Sound Generator Control Unit.
3) C43 Sedan and Estate do not have U78 and B63 specific Sound Generators.
A2059006928 is found only in Coupe and Cabriolet C43, and is not a PE sound generator, it’s an engine noise generator. 🤣
There is a specific sound generator for PE exhaust, and it is not fitted on PE equipped Sedan or Estate. So I can definitely say the exhaust sound isn’t piped into the cabin in those instances.
Haha
Haha
