Anyone run a piggyback, like JB4 etc , in conjunction with an ECU tune?
Does anyone else have experience of this set up ?
So far have reached out to EC but action or response yet re poor results.
The car is quicker but well off what pre FL C43s are making.
If you already have the flash and want more the JB4 is a great tuning tool. You can add more boost if octane allows, dial up or down boost on the launch, log your tune to see how it's actually running, have active safety systems in place, etc. For 2019 models you may also need the BCM so we can add more WGDC if logs indicate it's required.
Haven't heard or seen any more on it, but Munis, do you know if BMS has gotten Marcus straight and if he's making similar power to other JB4 owners now? If so, then they seem to be adapting to this quicker than the other NA based tuners on this platform.
On the "DRF" I also suspect it's related. We'll have to compare boost vs. WGDC once someone removes it as a test in EU.
Otherwise with bigger turbines etc and otherwise engine, it should be making more, if not the same, and definitely not less power.
Not many 19s C43s have been mapped here in the UK, I dont know of any others, so it's a waiting game.
i have also seen no proof that the filter is not present on ALL cars or at least EU coupe built cars.
Mine is EU in the UK.
Is there another thread re particulate filter?
I'm not sure filter will make difference if back pressure from EU spec EGF is the problem.
New downpipe would be needed but thats a slow to reverse- hardware change.
You are right, Brabus piggyback and Renntech ECU only claim about 40-45 bhp gain on their tunes/ boxes.
I have been out of the tuning group for a while with my recent suspension hooplas. I will check and let you guys know.
and yes PFs has a very high pressure drop and will cause power loss. I used to do a bit of tuning in my younger days, mostly VAG cars, and a 160 bhp diesel would gain around 20 hp extra from removing the DPF before a tune. The % gains were higher than what we saw from decat’ing gasoline turbo cars.
would definitely be interesting to see what removing the PF would do. Should easily provide an extra 25-30 hp if you remove it (I imagine it is located in the downpipe). The updated engine is basically the same unit used in the E43 which Brabus in Germany has been hiking from 401 hp (eu numbers) to 450 hp. So the 19 C43 should produce at least that, if not - I’d blame the difference on the PFs as it is basically the only difference.
JB4 thread : https://mbworld.org/forums/c450-c43-...rformance.html
Build thread showing car : https://mbworld.org/forums/c450-c43-...upe-build.html
That being said, there are countless aftermarket exhaust manufacturers out there offering middle section and rear muffler sets. Using any one of these offerings would automatically mean deletion of the filter as the filter resides in the rearmost part of the middle section. I think the correct people to check with on whether the filter makes a difference to power on the 2019 model are those who have changed the exhaust middle section to aftermarket! I’m sure there should be quite a few on the forum by now?
Currently running Eurocharged tune as well, around 380-390whp on dyno.
here's my result
Mine made 379 whp & 472 W TQ ( lb ft)
Top end is not a vast improvement. Clearly a bottle neck - EGF ?
