C450/C43 AMG
C43 staggered wheels...is there an alternative?
Old Oct 18, 2019 | 11:50 AM
amgmacc43's Avatar
C43
Not an owner yet, but with the numerous (on this website) reports of run-flat issues, tire wear, and the inability to rotate tires with the factory staggered set up (and my need to also run a 'winter' tire package for several months each year, I am interested to know if anyone is running non-staggered set ups on their C43 for simplicity, rotation availability, etc. This car would be my daily driver with no need - or desire - for track days, DE, etc. so I suspect that any handling impact at the upper limits would not be missed. Thoughts/experience would be most appreciated as I continue to agonize over the C43 vs. Audi S4 merits as I've posted elsewhere today. Thank you
Old Oct 18, 2019 | 12:33 PM
Dalle1985's Avatar
W205 AMG C63S
Just buy a square set of rims. But why would you? Yes, you can rotate the tires, but in the end, if you can’t, you’ll just replace one end more often than the other which ends up costing the same. The staggered setup is most definitely a good idea with the power and rear bias and actually My tires wear quite equally although they aren’t rotated.
Old Oct 18, 2019 | 01:25 PM
amgmacc43's Avatar
C43
Dalle - good points. My interest in being able to rotate is that my daily driver - which this will be - is driven 20K plus miles a year and some are reporting as little as 8K miles (I think on the front tires) with the run-flats that they car would come with. I don't know if this is typical because of stock alignment settings or a fun-flat issue.
Old Oct 18, 2019 | 01:55 PM
stockbmw's Avatar
2018 C43
You can run winter size all year around.
Old Oct 18, 2019 | 01:58 PM
amgmacc43's Avatar
C43
Are you saying that the 'winter size' (as recommended by MB?) are not a staggered set up? At least in looking on the Tire Rack website it gives you a staggered recommendation. Happy to hear what the 19" non-staggered size would be - thank you.
Old Oct 18, 2019 | 02:00 PM
stockbmw's Avatar
2018 C43
I am running 225/45 18 during winter
Old Oct 18, 2019 | 02:11 PM
RichardCranium3's Avatar
'16 AMG GTS, '21 AMG GLE53
As long as you switch to an asymmetrical tread pattern, you can rotate side to side. Unless you're tracking or drive on a high percentage of winding roads, this will accomplish the majority of rotation goals.
Beyond driving habits, the two most prominent issues are the factory camber angle and run flats coupled together. I switched to AS3+'s up front at 14k miles. I'm at 38k miles now and I have even wear across full tread width. I rotate left/right every 5-7k. Plenty of meat left.
Old Oct 18, 2019 | 02:16 PM
stockbmw's Avatar
2018 C43
I am doing same with my oem 19" Conti sport 5p which isn't directional.
