remote window open close not working?
seems weird. this "hidden" feature worked for my car before.... walking away from the car, hold the lock key and all the windows/roof close. hold the unlock and everything opens...
for whatever reason, this isn't working on my car any longer. i tried it 10 times. nothing. stuff wont close or open. am i missing something? is there a way to resync the remote? has anyone else had issues with this?
i do remember, when first trying this, it wasn't working from certain angles.... ie - rear of the car, couldnt see the signal or something like that. but worked 95% percent of the time... currently working 0% of the time and i hate having to walk back to the car if i forget to close something. curious to hear others' experiences...
I dropped both keys on my old w205 at different time and remote open/close no longer worked.
I cringe whenever I drop my current keys and test them right away... So far so good.
thanks for chiming in.
If you have keyless entry you can try holding your finger on the door handle. If you hold it long enough the windows should start moving.
the batteries were just replaced under warranty as well, eco start is working well. kind of why i figured it was a sync issue or something... maybe the dealer reset something when it was in for service and i have to reprogram the key? (that was my initial thought at least). if it continues to not work, i will just bring it up during the next oil change service.
I had the same problem and was driving me crazy, I have a c350e and tried the following and it worked for both keys, as I have keyless entry I rarely stick the key into the ignition, and thought to try it out may be it charges or a kind of sync will happen. So inserted the key and started the car, left it running for a couple of minutes and it worked again.
dynamac (09-29-2023)
2020 E 300 Coupe and 2019 GLS 400
I know this is 4 yrs late, but in the hopes of helping anyone with this issue, chances are the windows need to be re-synced again after battery replacement. The process should be listed in the manual or found in the forum.
Surge (05-15-2024)
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
Automatic lowering and raising of the windows with the key on my 2019 AMG GTC worked perfectly until a few weeks ago.
Keeping my hand in the door handle and starting the car with the key didn’t work either.
Will try replacing the key battery; but the key otherwise works fine (ie to lock/unlock from the key buttons)…
Received 2,843 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
