C450/C43 AMG
Leaking rear shocks
Old Feb 25, 2020 | 11:51 PM
shaungrey's Avatar
C43
Leaking rear shocks
Took my car in for service and was told both rear shocks are leaking and will be replaced under warranty. Is this a common issue on our c43’s? Should they be doing an alignment after changing the shocks? Car only has 16,000 miles on it!
Old Feb 26, 2020 | 03:35 PM
stockbmw's Avatar
2018 C43
Changing out any suspension should warrant an alignment job, but if I am paying for it, shocks aren't needed.
Lowering springs on other hand changes the height while resting and will need an alignment.
Try demanding one but I wouldn't push it to ruin your relationship with the dealer.
Old Jul 31, 2021 | 04:34 PM
newlocoman's Avatar
C43 AMG
few months ago I had to change both rear shocks because they were leaking. Today in the service they told me again the rear shocks are leaking. please help me , What could be happening?
Old Jul 31, 2021 | 05:27 PM
AhEmGee's Avatar
2004 E55 K Wagon &. '96 SL500
When I had my H&R sport springs fitted garage told me the left rear shock had a slight leak.
So sounds like a common problem.
As my car is lowered doubt it will covered under warranty now 🙄
Old Aug 2, 2021 | 10:14 PM
newlocoman's Avatar
C43 AMG
In the service recently told me that daily use of the sport + suspension on the road could be the cause of shock absorber failure , because it should be use only in closed tracks. what do you think about this?
Old Aug 3, 2021 | 03:30 AM
Ramsino's Avatar
C43
I think that is BS. There is nothing in the manual that warns of such a thing and even if it were true, then it is stupid on Mercedes to even put that Sport+ button there if it was not mechanically designed to withstand it. The C43 is not an all out sports car or a pure track car, so that should not be an excuse.
I also had leaking rear shocks and leaking differential as well when I took my car in for its 1st year service. They changed it out and everything was covered under warranty of course, but that's still not good.
Old Aug 3, 2021 | 08:37 AM
newlocoman's Avatar
C43 AMG
I agree with you, but they sent me to review page 243 of my user manual and there it explicitly says that the sport + mode should only be used on closed tracks. I'm going to change the shock absorbers again, but I don't want it to happen to me again
Old Aug 3, 2021 | 10:00 AM
alexasa's Avatar
c
I've been lowered for 2+ years driving to work in, exclusively, sports+ mode on roads under construction with no issues.
Old Aug 3, 2021 | 10:03 AM
RichardCranium3's Avatar
'16 AMG GTS, '21 AMG GLE53
Same here - just rolled 60k miles, almost all in S+
Old Aug 3, 2021 | 12:12 PM
Ramsino's Avatar
C43
Dang you are right! I do remember reading this in the manual now. I thought that this was the case due to less traction control and that being dangerous on public roads, but I didn't expect this to mean that it would affect the shocks.
