MST Intake Question
MST Intake Question
There was a thread a while back, when the intake was new, and there were a lot of theories, criticisms of the dyno, etc. Fast forward a bit, has anyone used their intake and if so, what gains have you seen?
Im wondering the same. Im close to ordering the BMS intake. MST looks like it would get just as much heatsoak as BMS if that is a conern. Also MST does not change the inlet pipe which is said to be one of main restrictions. I also would love to hear some more experiences particularly about BMS. There are some interesting tests BMS has conducted on their n54 platform with their DCI intakes and they proved they didnt have hugher IATs. Either way lets here from some folks with either intake systems!!
I installed my BMS intakes in December 2019 on my pre-facelift c43, about a week before getting a stage 1 tune.
Anecdotally, I like my BMS intake - but I cannot speak to actual performance increase. I have not dyno’d the car and any gain is too small to register on the butt dyno. I like the increased sound during spool. Also, I have not perceived too much heat soak with mine (popping the hood and doing a hand test after long commutes, stop and go commutes, or after hard driving).
Former Vendor of MBWorld
2004 E55 K Wagon &. '96 SL500
Shame after all this time there are no before and Dragy or 1/4 mile slips, same day dynos, after having a BMS or other intake fitter.
This is something I did immediately when I first had my car remapped, had updates maps and when I removed by OPFs from the exhaust.
This is the only way to quantify any performance improvement. If people want them just for sound may as well drill holes in the airbox.
Can BMS chime in on if this could help underhood temps and IATs particularly with open element intakes under the hood. I found this on c63 forum it was posted by Zaccomposites(another maker of intake system for c63). They removed a section of the hood seal to allow hot air to flow out of the back. There was some debate about negative pressure and sucking air back in under the hood causing turbulence. BMS would live ti hear any negatives or positives in regards to this. Thanks.
Our turbos are obviously mounted differently.
Did you notice any difference in engine temp or IATs? Any negatives? How do you like the BMS intake?
